tig welding #2222602
12/29/16 02:36 AM
12/29/16 02:36 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Going to do some welding on aluminized exhaust tubing. Does the aluminized coating need to be removed in the weld area or can it be tig welded as is?
Re: tig welding [Re: rowin4] #2222656
12/29/16 10:01 AM
12/29/16 10:01 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I'm pretty sure it has to be cleaned off. That coating is only there as rust prevention. Best thing to do would be to cut a couple of inches off and do some test welds.
[image][/image]
Re: tig welding [Re: rowin4] #2222705
12/29/16 12:18 PM
12/29/16 12:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I've always found aluminized tubing to weld fine without any removal of the coating.
Re: tig welding [Re: TRENDZ] #2222713
12/29/16 12:44 PM
12/29/16 12:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Remove the coating.. it will gas you for one thing
wave
Re: tig welding [Re: rowin4] #2222744
12/29/16 01:47 PM
12/29/16 01:47 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Its not zinc. Aluminized exhaust tubing is made to be welded.
Re: tig welding [Re: TRENDZ] #2222747
12/29/16 01:51 PM
12/29/16 01:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It will put off a white smoke
wave
Re: tig welding [Re: rowin4] #2222751
12/29/16 01:57 PM
12/29/16 01:57 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Zinc does, aluminized doesn't.
Re: tig welding [Re: TRENDZ] #2222753
12/29/16 02:02 PM
12/29/16 02:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When welding you want the metal to be clean
for the best weld.. alum in steel is debris
and makes for a crappy weld... can it be done..
sure.. I have done plenty at work when I was in
a hurry.. didnt turn out nice but it works
wave
Re: tig welding [Re: rowin4] #2222798
12/29/16 02:56 PM
12/29/16 02:56 PM
Ohio
lockjaw-express Offline
Ohio
I have been tig welding for years...make sure to remove the coating, even aluminum. Any kind of coating will gas off, and in some cases make you sick or can kill you!
Galvanized coatings will cause lung cancer...I know two people that died of cancer from breathing gases off of welding. Beryllium Copper will kill you dead very quickly.
Take the safe way out, always remove any coatings.
My 2 cents, Mark
Re: tig welding [Re: rowin4] #2222802
12/29/16 03:05 PM
12/29/16 03:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've done it. Not the best results. TIG welding likes for the material to be clean. Aluminum and steel don't like each other when trying to weld something. Grind it off or get some raw steel pipe and bends. Not hard to find.
Re: tig welding [Re: rowin4] #2222828
12/29/16 03:36 PM
12/29/16 03:36 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Mine was TIG welded by a friend of mine and he used stainless rod and it looks great.
[img] [/img]
Re: tig welding [Re: rowin4] #2222831
12/29/16 03:39 PM
12/29/16 03:39 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
No weld fumes are safe. I am not suggesting that you should breathe any fumes. All I'm saying is the fumes are no more dangerous than welding either steel, or aluminum. The zinc coatings in galvanized steel are very dangerous. Never knew about the beryllium copper. Wouldn't have ever considered welding it, but glad for the info.
All I can tell you is aluminized tubing welds like any steel tubing, is sold as directly weldable, and other than the fact that the aluminum rises to the top of the puddle, working with it takes no additional steps. I've never had an issue with its appearance or strength. Your results may vary.
Use as much caution as you see fit. If you don't mind the extra work of removing the aluminum, go for it.
