Page 1 of 3 1 2 3
odd vin or not? #2221925
12/27/16 11:51 PM
12/27/16 11:51 PM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
I've spent the day with an old friend and was curious about how His car would decode... it doesn't on any decoder website.
Someone at one time stamped 8 and 4 on the tag. With that on there it decodes as a'63 Chrysler 300J. His dad gave him the car before passing and was always under the impression that it was an original maxwedge. I never thought it was, just a v8 Sport Fury.
Re: odd vin or not? [Re: 52savoy] #2221946
12/28/16 12:37 AM
12/28/16 12:37 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
The factory stamped the 84. First two digits are correct and the first three designate the car as a Chrysler, V-8 engine, C body, 300J, 1963. Fourth digit designates Lynch Road MI assembly plant, and last six numbers are the sequence/serial number.
Re: odd vin or not? [Re: 52savoy] #2221949
12/28/16 12:39 AM
12/28/16 12:39 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
Those are hand stamped and don't match the other stampings. Is that how C-bodys were done? The car is a '63 b-body!
The sequential numbers match other info on the car though.
Re: odd vin or not? [Re: 52savoy] #2221950
12/28/16 12:41 AM
12/28/16 12:41 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Say what???
Re: odd vin or not? [Re: 52savoy] #2221951
12/28/16 12:44 AM
12/28/16 12:44 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
the 8 and 4 are recessed numbers as opposed to the raised numbers following. The 8 and 4 appear to be made by a chisel or a scribe of some sort.
A '63 Sport Fury would decode as 343XXXXXX......
Re: odd vin or not? [Re: 52savoy] #2221957
12/28/16 12:52 AM
12/28/16 12:52 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
That's correct. First two digits, which designate the model, are stamped that way.
VIN numbers are 10 digits in 1963.
Re: odd vin or not? [Re: 52savoy] #2221964
12/28/16 12:58 AM
12/28/16 12:58 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
but it's a Sport Fury and should decode as... 3= Plymouth V8, 4=Sport Fury, 3= year
This car has been a drag car for at least 45 years....the time I've been around the car.
Re: odd vin or not? [Re: 52savoy] #2221967
12/28/16 01:00 AM
12/28/16 01:00 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
On the fendertag under 'BDY' there should be a three digit code. The first two, (in this case), should be 84.
You sure it's not a '3'? An 8 makes it a C-body Chrysler.
Re: odd vin or not? [Re: 52savoy] #2221969
12/28/16 01:02 AM
12/28/16 01:02 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
I'll check
Re: odd vin or not? [Re: Bull1tt] #2221970
12/28/16 01:05 AM
12/28/16 01:05 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
Re: odd vin or not? [Re: 52savoy] #2221976
12/28/16 01:13 AM
12/28/16 01:13 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Looks like the VIN tag should start with a '3' according to fendertag. When I first saw the tag, thought it was an 8. Should be a 3, and would be a Plymouth.
All VIN tags on 1962-5 cars have the first two digits stamped on the tag later, once model is designated.
Re: odd vin or not? [Re: 52savoy] #2221982
12/28/16 01:19 AM
12/28/16 01:19 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
so what are your thoughts on the discrepancy ......?
Re: odd vin or not? [Re: 52savoy] #2221987
12/28/16 01:23 AM
12/28/16 01:23 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I'm no expert, but we should get some 63 Plymouth vin tags posted to look at the '3' first digit. You think it was accidentally stamped as an eight...
Re: odd vin or not? [Re: Bull1tt] #2221996
12/28/16 01:34 AM
12/28/16 01:34 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it's "simply" a mis-stamped VIN tag - no c-bodies at Lynch Rd. for '63
3431150314 is a 1963 Plymouth Sport Fury Super Stock (MAX WEDGE)
HC auto, "ermine white" w/red interior, heater, AM radio
Re: odd vin or not? [Re: 52savoy] #2221997
12/28/16 01:34 AM
12/28/16 01:34 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
I don't know what to think. The title has the vin as 3431150314!... oh...GREAT!
Re: odd vin or not? [Re: 52savoy] #2222000
12/28/16 01:38 AM
12/28/16 01:38 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
This is a picture of my 65 Fury cop car vin tag - the first 2 letters are different than the rest.
Re: odd vin or not? [Re: 52savoy] #2222006
12/28/16 01:47 AM
12/28/16 01:47 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the last 8 digits 31150314 were pre-stamped (from the back) on the VIN tags, the first 2 digits were added (from the front) when the car line and model were finalized.
3 = 1963
1 = Lynch Rd. Detroit, MI assembly plant
150314 = VIN sequence number (started at 100001)
50,314th assigned VIN at Lynch Rd. for 1963
Re: odd vin or not? [Re: 52savoy] #2222007
12/28/16 01:47 AM
12/28/16 01:47 AM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
So it is max wedge car after all... I never thought it was because there aren't any choke cables. I guess the car should be restored instead of leaving it as is..
Re: odd vin or not? [Re: 52savoy] #2222008
12/28/16 01:49 AM
12/28/16 01:49 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
If you go to MyMopar.com, you can do a free download of a 63 parts book. The VIN tag is broken down on page 4 (INF-5).
Re: odd vin or not? [Re: 6bblgt] #2222011
12/28/16 01:53 AM
12/28/16 01:53 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
3 = 1963
Lynch rd? Parts book calls it Plymouth plant - Detroit. Same place?
But for it to be a correct VIN for the car it needs to start with a 3 not an 8.
Page 1 of 3 1 2 3
