Re: soild cam guys
[Re: Mr.Yuck]
#222182
02/12/09 01:29 PM
02/12/09 01:29 PM
Posts: 3,151 Central NC
gch
Central NC
P.S. I know the book says .028/.032 just checking if anybody has any tips, hints to making it run better.
Start at the factory settings.If you need more low end loosen the lash a litttle.More top end tighten it a little.
Re: soild cam guys
[Re: Dodgem]
#222185
02/12/09 02:02 PM
02/12/09 02:02 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
aluminum Heads??
nope ported 516's w/ 2.14/1.81 valves. These are Cat 1.5's if it makes a difference.
Re: soild cam guys
[Re: Mr.Yuck]
#222186
02/12/09 02:05 PM
02/12/09 02:05 PM
Posts: 1,532 off the grid
340B5
off the grid
There was a post a couple days ago. Was named "Tight valve lash" They were using less than recommended. I would leave the exh a couple thousands looser being it runs hotter.
Yeah, it's got a smallblock.
Re: soild cam guys
[Re: gch]
#222188
02/13/09 02:36 AM
02/13/09 02:36 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I think you have it backwards. Tighten the lash is like advancing the cam which will help the low end and loosen the lash is like retarding the cam to help top end.
I have run the MP .557 at .024 and my car seems to like it. It calls for .028 and .032. Ron
Re: soild cam guys
[Re: 383man]
#222189
02/13/09 09:10 AM
02/13/09 09:10 AM
Mr.Yuck
Brookeville, Md
Ron, do you have int and ex at .024?
Re: soild cam guys
[Re: mopar dave]
#222191
02/13/09 10:34 AM
02/13/09 10:34 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
when you loosen lash it creates more torque and when you tighten it creates more top end.
Tight=big cam loose=small cam.
Re: soild cam guys
[Re: RemCharger]
#222192
02/13/09 10:46 AM
02/13/09 10:46 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I ran mine at .024/.026. Iron heads tho.
Re: soild cam guys
[Re: moper]
#222193
02/13/09 11:21 AM
02/13/09 11:21 AM
Mr.Yuck
Brookeville, Md
yeah I have iron heads too.
Re: soild cam guys
[Re: mopar dave]
#222194
02/13/09 01:14 PM
02/13/09 01:14 PM
383man
Balt. Md
No actually when you loosen the lash it retards the cam timing which can help top end depending on where the cam is at. When you tighten the lash its like advancing the cam timing and moving the power band lower hence more low end. Ron
Re: soild cam guys
[Re: Mr.Yuck]
#222196
02/13/09 01:36 PM
02/13/09 01:36 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I set both the intake and the exhaust the same, most because I'm lazy and don't want to keep up with the 2 different feeler gauges. I just pick something in the middle and go with it. So if it's .028 and .032 I just use .030. I just bracket race so it's not that important. Just keep them set and make sure they aren't moving is what is important to me.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: soild cam guys
[Re: 383man]
#222197
02/13/09 01:47 PM
02/13/09 01:47 PM
RemCharger
Sk. Canada
Ron thats an interesting thought pattern. However, when you loosen the lash you are retarding the valve opening event ,AND advancing the closing event meanwhile reducing the overall valve open duration. Therefore making the cam seem smaller to the engine. The reason your motor responds well to the tightened lash is it wants a bigger cam, or duration at least.
