Hemi 4 speed clutch setup
#2221779
12/27/16 07:02 PM
12/27/16 07:02 PM
Posts: 753 Louisiana
Spyphish
Louisiana
OK we have a 528 hemi with a 4 speed in a 66 Coronet. It has a 6 cylinder Z bar bent in a wreck we think. It works but the pedal will not come all the way up unless I pull it with my foot. So I presume it's wearing the TO bearing. There are 2 holes in the down bar of the Z bar, we are in the top with the clutch rod. Try the bottom??? What are we doing wrong? I have never set a single disc RAM street clutch. Thanks
CALMED THE QUAKE!!!(AGAIN!)
Re: Hemi 4 speed clutch setup
[Re: Spyphish]
#2221852
12/27/16 09:46 PM
12/27/16 09:46 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It works but the pedal will not come all the way up unless I pull it with my foot. Is there a spring between the throw out fork and the bellhousing? "Fork return spring" in the pic below.
[Re: John_Kunkel]
#2221886
12/27/16 10:57 PM
12/27/16 10:57 PM
Spyphish
Louisiana
Thanks guys. Unfortunately the frame is tweaked and pulled the best we can. Z Bar not perfectly horizontal but seems to be functional. The return spring we have was not on properly so that may fix it. That sketch helped. Will give an update tomorrow. Thanks again.
[Re: Spyphish]
#2222022
12/28/16 02:18 AM
12/28/16 02:18 AM
Posts: 5,447 So Cal
Sinitro
So Cal
Note that in 66 there was a couple of different Z-Bars, they were the same width but the tab for mounting the rod pushing back to the clutch fork is slightly different. In my 70RR I had major alignment issues for the Z-bar pulled it out and took it over to our local Mopar guru. He pulled out (3) different Z-bars all same width but each had the tab in a slightly different position. U want the one where the rod pushes back in parallel with the bell housing. U mite want to call Dan or Wayne over @ Brewers for more specific info. Brewers Performance 937.947.4416 Just my $0.02...
[Re: Sinitro]
#2222048
12/28/16 03:17 AM
12/28/16 03:17 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
As stated above Brewer Performance can help. Their web site list the different components for your application. Linkage { there are different lengths } might be the same but I think the bell crank is different.
