Need dependable roller lifters #222118
02/12/09 01:12 PM
02/12/09 01:12 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
I have 572-13 Indy heads with 948-16 Comp Cam springs.
The springs have a seat load of 332 psi and an open load of 949 psi.
The cam is 815 in and 800 exh on the lift.
I need a really good set of offset roller lifters that i can use for pushrod oiling and dont have to bush the block.And it is also a mega block.
Any recommendations would be greatly appreciated.
Re: Need dependable roller lifters [Re: sc301v] #222119
02/12/09 01:22 PM
02/12/09 01:22 PM
AndyF Offline
AndyF  Offline
Call the guys at Best Machine. They have a private brand roller lifter that will do exactly what you need.
I'm not sure why they don't advertise these lifters but they have them.
Re: Need dependable roller lifters [Re: sc301v] #222120
02/12/09 01:32 PM
02/12/09 01:32 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Look into Isky red zone lifters. I got them from Scott Brown. They are offset on the intake with pushrod oiling and my block (KB) is not bushed. I run some healthy spring pressures but I don't recall the exact numbers.
Re: Need dependable roller lifters [Re: sc301v] #222121
02/12/09 01:49 PM
02/12/09 01:49 PM
Crane Ultra or Jesels
Re: Need dependable roller lifters [Re: Bigcube] #222122
02/12/09 02:03 PM
02/12/09 02:03 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
ISKY RED ZONE I AGREE (MY MACHINE SHOP INSTALLED THEM IN MINE) - ALSO MEMBER OU812 OWNS AND OPERATES A MACHINE SHOP http://www.immengines.com AND HE SEEMS REALLY SHARP AND KNOWLEDGEABLE. HE MAY BE A GOOD PERSON TO ASK.
Re: Need dependable roller lifters [Re: Cab_Burge] #222123
02/12/09 04:35 PM
02/12/09 04:35 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Re: Need dependable roller lifters [Re: sc301v] #222124
02/12/09 04:48 PM
02/12/09 04:48 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Anybody got any part #s for any of these lifters.
The websites arent showing much on the mopars.Not that i can see anyway.
Thanks again
Re: Need dependable roller lifters [Re: sc301v] #222125
02/12/09 05:47 PM
02/12/09 05:47 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Comp 892 lifters for pushrod oiling I run valve spring pressures at: 450lbs closed,1280lbs open!
ive been running them for years at 8400 rpms.and rotate them out at 150 passes,Never broke one!!!
Re: Need dependable roller lifters [Re: boatracer572] #222126
02/12/09 06:04 PM
02/12/09 06:04 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Are those a full bodied lifter or do they have the cutout.
I found some 829s but couldnt find the 892s
Re: Need dependable roller lifters [Re: sc301v] #222127
02/12/09 06:44 PM
02/12/09 06:44 PM
AndyF Offline
AndyF  Offline
Thanks again
Call Best Machine.
Re: Need dependable roller lifters [Re: sc301v] #222128
02/12/09 06:45 PM
02/12/09 06:45 PM
San Jose Ca.
San Jose Ca.
The comp 892 lifters have a oil band!go to comp cams web site,and you can view all the lifters that comp makes,by number and description!every body has there "favorite" brand and Im sure that
there are better lifters than Comp lifters,But I have given the Comp lifters a real test with what I have and they havent let me down!
Re: Need dependable roller lifters [Re: sc301v] #222129
02/12/09 06:52 PM
02/12/09 06:52 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
Thanks again
ISKY RED ZONE PART# 3472RH
Re: Need dependable roller lifters [Re: Cab_Burge] #222130
02/12/09 07:42 PM
02/12/09 07:42 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I agree. Anything else is a crap shoot for serious applications.
Re: Need dependable roller lifters [Re: BobR] #222131
02/12/09 08:40 PM
02/12/09 08:40 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
what about Crower lifters??
Re: Need dependable roller lifters [Re: Defbob] #222132
02/12/09 10:14 PM
02/12/09 10:14 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I've just bought a set of Crane .210 offset, pushrod oiling. im lifting close to an inch in my 600++ci engine
Re: Need dependable roller lifters [Re: Diablo] #222133
02/13/09 03:23 AM
02/13/09 03:23 AM
SoCal
Brian Hafliger Offline
SoCal
I sell these: Pushrod oil, edm oil to the bearings, moved oil hole, shrouded wheel, available with no offset or .180 offsets.
Brian
Re: Need dependable roller lifters [Re: Diablo] #222134
02/13/09 09:41 AM
02/13/09 09:41 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Dont guess you have a part# would you.
And also do you run them in an unbushed block.
Re: Need dependable roller lifters [Re: sc301v] #222135
02/13/09 10:10 AM
02/13/09 10:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i use morel solid roller lifters. i'v read that the powerboat guys have been running these with 0 failures. you can get them thru erson cams. do not know if they have an oil thru lifter, you'll have to call.
Re: Need dependable roller lifters [Re: Brian Hafliger] #222136
02/13/09 10:51 AM
02/13/09 10:51 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Brian
Probably need to have the bores bushed to get any kind of decent oil pressure.
Re: Need dependable roller lifters [Re: BobR] #222137
02/13/09 11:26 AM
02/13/09 11:26 AM
SoCal
SoCal
Brian
Where do you guys come up with this stuff???????????????????????????????????????????????????????????????????????????????
These lifters go right in, no problem, no bushing. Infact these lifters are made so you can run quite a bit of lift WITHOUT bushing the block!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ask some board members who have bought from me, like Cudabin and AndyF!!!!
Brian
