How to Remove Differential Thrust Block? #2220841
12/25/16 08:11 PM
12/25/16 08:11 PM
KY
DougR Offline OP
DougR  Offline OP
KY
This 8 3/4' axle conversion is fighting me all the way. I test fit my Dr. Diff green bearing axles into my A body housing with a 741 case open differential (no SureGrip). The spiral ring around the bearing sits about 1/8" out when the other side is pushed all the way in. Clearly the thrust block in the center section is the problem, but I don't see how to remove it. It has a large slot through it that the pinion gear shaft goes through. Can the thrust block be removed, or do I need to have the axles cut slightly shorter? Thanks.
Re: How to Remove Differential Thrust Block? [Re: DougR] #2220847
12/25/16 08:35 PM
12/25/16 08:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With the one-piece thrust block, the differential must be disassembled to remove it. I'd just shorten the axles.
Re: How to Remove Differential Thrust Block? [Re: DougR] #2221041
12/26/16 11:33 AM
12/26/16 11:33 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Do certain cases have the one-piece thrust block?
My 489 case had a block that was two pieces. The 3rd member needs to come out and you need to look very closely at the pin holding the two halves together. One you can hammer on all day and not make any progress, the other will come right out.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: How to Remove Differential Thrust Block? [Re: DougR] #2221051
12/26/16 12:12 PM
12/26/16 12:12 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
When in doubt . . . check youtube ??? Or better yet, check back with Cass (Dr. Diff) . . . he da man !
Re: How to Remove Differential Thrust Block? [Re: DougR] #2221074
12/26/16 01:11 PM
12/26/16 01:11 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Yep... Dr.Diff is da man.
Had a similar problem with my tapered axle diff (742 case with clutch type sure grip) after replacing the wheel bearings. The new ones were slightly narrower than the originals. Called Dr.Diff to see where to purchase the required shims and found that no one makes them anymore. Long story short, two alternatives... make your own shims or remove material from the thrust block. I did the latter. Had to remove .140 from the thrust block to get proper axle end play. He da man!
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: How to Remove Differential Thrust Block? [Re: GoodysGotaCuda] #2221144
12/26/16 02:34 PM
12/26/16 02:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The OP has no Sure-Grip, the open differential and the cone-type SG have a one-piece block. Only the clutch-type SG has the two-piece thrust buttons.
Re: How to Remove Differential Thrust Block? [Re: DougR] #2221168
12/26/16 03:19 PM
12/26/16 03:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Generally I leave the thrust button(s) in, and either fabricate flange spacers for the axle tube flange as I generally incorporate a rear wheel disc set up (.100-.110 thick each side) or cut the axle ends, there's plenty of spline for this
Re: How to Remove Differential Thrust Block? [Re: John_Kunkel] #2221273
12/26/16 06:48 PM
12/26/16 06:48 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks for the info, didn't know that. wrench
2020 RAM 1500
Re: How to Remove Differential Thrust Block? [Re: DougR] #2221431
12/26/16 11:37 PM
12/26/16 11:37 PM
KY
DougR Offline OP
DougR  Offline OP
KY
Update: John's pic is exactly what I have. I woke up this morning realizing the brake backing plates might act like shims if the center hole diameter was small enough. I quick test assembly showed this was the case: the spiral ring on the green bearing butts up against the outside of the backing plate, not the housing flange like I first thought. The combined thicknesses of the two brake backing plates spaces the axles out just enough to avoid jamming into the thrust block. I have renewed respect for Dr. Diff's expertise! I am posting this to help others who might have this situation.
Re: How to Remove Differential Thrust Block? [Re: GoodysGotaCuda] #2222197
12/28/16 01:34 PM
12/28/16 01:34 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I have yet to see a thrust block that was in 2 pieces ... that wasn't broken somehow ... , what was the center section from ?
Mainstream Media is the new Pravda
