Torque wrench calibration #2220661
12/25/16 02:45 PM
12/25/16 02:45 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Have a craftsman "clicker" style wrench. Do any of you guys recalibrate them and where/how? Thanks....and Merry Christmas! Santa4
Re: Torque wrench calibration [Re: Hot 340] #2220674
12/25/16 03:15 PM
12/25/16 03:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Talk with any of the tool trucks(Snap-on,Max)
any of them.. they have stuff calibrated all
the time.. they send them in to a company.. I
dont know what they charge now days.. I had
all mine cal'd at work before I retired
EDIT
Google "tool calibration services" they have
a few sites.. see if there is one near you
wave
Re: Torque wrench calibration [Re: Hot 340] #2220694
12/25/16 03:53 PM
12/25/16 03:53 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Angle Repair in Beckley WV. Check with them to see if they work on Craftsman wrenches. Also if you know anyone in the aircraft trade, they have to keep up with their tools and may know someone local to you.
Re: Torque wrench calibration [Re: CMcAllister] #2220695
12/25/16 03:58 PM
12/25/16 03:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a Fastenal near you they do it
wave
https://www.fastenal.com/en/1487/calibration-and-repair
Re: Torque wrench calibration [Re: Hot 340] #2220743
12/25/16 05:10 PM
12/25/16 05:10 PM
central new york
pettyblue440 Offline
central new york
I have a craftsman clicker and before I put my 383 together this summer I had my machine shop compare against his wrench.
Re: Torque wrench calibration [Re: Hot 340] #2220748
12/25/16 05:28 PM
12/25/16 05:28 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Any metrology lab can do it. look in the local phone book
Re: Torque wrench calibration [Re: pettyblue440] #2220751
12/25/16 05:31 PM
12/25/16 05:31 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
We used to inspect Craftsman torque wrenches when I worked in service at Sears.
Pretty simple. 1 foot from drive weights were set. Its been almost 30 years but basically we hung 25 lbs on the scale type and checked. Did this again at 50, 75, 100. On those cheap wrenches you adjust the needle. On clickerz you checked using a 20 lb weight. Then added 1 lb at a time till it clicked. We followed the scale and noted each entry on the inspection card. Was told they check micometers before my time there.
Re: Torque wrench calibration [Re: Hot 340] #2220752
12/25/16 05:32 PM
12/25/16 05:32 PM
birdtracker Offline
birdtracker  Offline
I calibrated torque wrenches and gauges at a research center.
1. Do not ship your torque wrench. It will be worse than when you sent it.
2. Fastenal would be good if you could walk it in and walk out with it.
3. Clicker types are just as accurate as digital and can be repaired easier.
4. Comparing to other torque wrenches is ok as long as you use a smooth pulling motion and same person does both or 3 torque wrenches is better. Birdtracker
Re: Torque wrench calibration [Re: Hot 340] #2221259
12/26/16 07:24 PM
12/26/16 07:24 PM
crabman173
crabman173
Tool Trucks all have a simple checker --they will check for free and they are close enough--the way you use the wrench has more impact on correct tq than the wrench--never jerk it like you see the NHRA guys doing on a million dollar funny car--one smooth pull---last batch I had I checked four from my shop--cheapos--Snap Ons, Etc all were near enough--it is surprising how close they all were when you look at price and the Snap On 3/8ths is the one that is always breaking a tooth in the head--once a year easy--others never any problem--FWIW the one from Lowes for $50 was dead on enough for the space shuttle
Re: Torque wrench calibration [Re: Hot 340] #2221609
12/27/16 02:29 PM
12/27/16 02:29 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
most torque wrenches are checked at 20% from the bottom, then at 5 intervals until the top 20% of the range. ñormally +-2 to 5% tolerance is allowed, just have a metrology lab do it, cal is normally good for a year. but you can specify 2 years. tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Torque wrench calibration [Re: Hot 340] #2221838
12/27/16 09:17 PM
12/27/16 09:17 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I calibrate mine a couple times a year using a torque adapter mounted in a fixture I built and mount in a vice. Nice to have for spot checking, especially if the torque wrench is ever dropped. The adapter was about $50. I got the lighter weight model which is good for 4 - 146 ft lbs. Check YouTube for adjustment procedures.
Take care.
Re: Torque wrench calibration [Re: humpty] #2222010
12/28/16 01:52 AM
12/28/16 01:52 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I did mine the same way. I found my old Craftsmen to be right on, but my new Eastwood to be off. I recalibated it using the checker.
