ARP Connecting Rod Bolt Install 318 #2219673
12/23/16 03:50 PM
12/23/16 03:50 PM
Kemblesville, PA
dart14 Offline OP
dart14  Offline OP
Kemblesville, PA
stock 1969 318 rebuild. Purchased new ARP connecting rod bolts. I tried putting the bolts in the frezer and heating the rods to 250 in the oven. Could not get the bolts to seat by hammering them in. They went in about 2/3 of the way. I tried just running the nuts to pull the bolt through on one rod. One went through ok and the other doesn't seem to want to go. I did not want to lean on it too much. I abandoned this idea as I think it may stress the bolt out. Do the bolts have to be pressed in by a machine shop ?
Re: ARP Connecting Rod Bolt Install 318 [Re: dart14] #2219683
12/23/16 04:12 PM
12/23/16 04:12 PM
Guitar Jones Offline
Not only do they need to be pressed in, you will also need to resize the big end after that.
Re: ARP Connecting Rod Bolt Install 318 [Re: Guitar Jones] #2219686
12/23/16 04:18 PM
12/23/16 04:18 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
X2
Re: ARP Connecting Rod Bolt Install 318 [Re: Guitar Jones] #2219699
12/23/16 04:37 PM
12/23/16 04:37 PM
iagree Any time you disturb the big end of a rod by changing or removing those type press in bolts you should always have it check for roundness and I.D. size twocents
Re: ARP Connecting Rod Bolt Install 318 [Re: dart14] #2221875
12/27/16 10:31 PM
12/27/16 10:31 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
take rods and bolts to machine shop. they will cut the rod and cap. install bolts, torque them then rehone bores to proper size.
