Steel Shim Head Gasket - small block 360
#2219656
12/23/16 03:14 PM
12/23/16 03:14 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Does anyone know the part number for the factory style steel shim head gasket?
I'm needing one between .022-.026 thick. It would be a Mahle/Victor Reinz item.
Local auto parts guys couldn't help so if anyone knows please let me know.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Steel Shim Head Gasket - small block 360
[Re: WadeMetzinger]
#2219717
12/23/16 05:17 PM
12/23/16 05:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Good luck, my info is NA, for a long time.
[Re: WadeMetzinger]
#2219734
12/23/16 05:50 PM
12/23/16 05:50 PM
RapidRobert
61018 then underneath that is 3512 space 719. .0215" thick, 4.117" bore. steel shim with MP pentastar
