Exhaust Interference and Drone Problems
#2218798
12/22/16 03:24 AM
12/22/16 03:24 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Today I actually had the opportunity to drive my car on the freeway. With the 6-speed manual, I'm able to get the RPM's down to about 2000 while driving at 70 mph. I have one big problem with that... The drone is absolutely unbearable at high speeds. I ended up dropping my speed to 60 mph where I was cruising at 1500 RPM and the car was as quiet as a church mouse. My only other option was to speed up to 85 mph where the car was cruising at 2500+ RPM. While inspecting my engine bay during my lunch break, I also noticed a bigger problem, that my headers are resting directly on my steering box.
So, I need two fixes: 1) Is it possible to move/shim the steering box or engine so they won't contact anymore? (I have a cherry picker) 2) What's the best way to get rid of the drone?
My 408 makes about 523 hp. I have TTi shorty headers, TTI 2.5" X-pipe, Dynomax Super Turbo mufflers, and turn downs. I realize that the 2.5" diameter is undersized for the amount of peak horsepower I'm making, but I needed the 2.5" exhaust to ensure everything cleared the undercarriage.
Changing the muffler will probably be the easiest way to get rid of the drone, I just don't know what style of muffler to try to remedy it.
Re: Exhaust Interference and Drone Problems
[Re: MuuMuu101]
#2218802
12/22/16 03:32 AM
12/22/16 03:32 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
tail pipes will help A lot.
[Re: NANKET]
#2218816
12/22/16 04:41 AM
12/22/16 04:41 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
for sale 1968 Dart GT. then go buy a new challenger. All fixed Thanks for the productive and informative response.
[Re: Kern Dog]
#2218848
12/22/16 10:18 AM
12/22/16 10:18 AM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I know its a PITA to get in and do it. But sometimes you can loosen all of the motor mounts and lift the engines weight with the crane and then re-tighten everything. More than likely the mounts were bolted on and then dropped in. There is a small amount it can be moved by loosening them all and re-positioning it before tightening it down... I'd venture to say by doing this you are going to make your oil filter clearance on the other side tighter.... The drone is typical without having tailpipes...
...FAFO...
[Re: MuuMuu101]
#2218852
12/22/16 10:34 AM
12/22/16 10:34 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The length of your tailpipe from muffler back matters a lot to the rpm where Drone is most severe. Just as a Church Organ makes different musical notes when different length pipes get air blown through them, so will your exhaust make annoying music.
Very roughly, if drone was severe at 2000 rpm, and much less at 1500 rpm, then your tailpipe length needs to increase 2000 divided by 1500 4/3 rds
Other things come into play here, such as the temperature of the exhaust gas, which will be higher the more the trottle is opened.
You could experiment to find the added length that snuffs out drone. Buy two ninety degree fittings, and two lengths of either solid or flexible corrigated pipe, and add maximum length for side outlet style exhaust, then cut off about two inches at a time untill the exhaust note suits you.
Drive up steep hills to demonstrate how a more open throttle changes exhaust temperature and therefore drone.
The quietest set up for low drone in the 1200 to 2200 rpm range is usually large "Helmhertz Trap" mufflers mounted cross ways near the rear bumper fed by as long as possible tailpipes. T-Traps of closed stub pipes the right length can also kill drone at a particular rpm.
[Re: MuuMuu101]
#2218893
12/22/16 12:20 PM
12/22/16 12:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Tailpipes will probably fix most of it, getting the header to steering box issue fixed will get more of it and if you do not have a crossover, either an H or X pipe that will help. Adding resonators will help. I'd do the first two then see if it's gone and add the rest in order of listing if needed.
Make sure the exhaust is rubber hung, the stock hangers were designed to isolate exhaust noise from the chassis, use them if you can. Gert under the car and very closely inspect the exhaust system for any other rubbing or metal to metal contact, do not be afraid to move the system about by hand to see if things can touch, even if it appears not to at rest.
Move the engine or dimple the tube before you fool with steering box location. Of course you ought to do a bumpsteer check to make sure the gear box is in optimal location before you move or dimple, but it's not 100% necessary, just attention to details there.
[Re: MuuMuu101]
#2218898
12/22/16 12:27 PM
12/22/16 12:27 PM
Posts: 12,245 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Another vote for tailpipes.
If you do go with tailpipes and they don't eliminate enough of the drone by themselves, then any cheap bullets (we used to call them glasspacks) in the tailpipes work good as resonators and usually deal with the remaining drone quite well. Do you have room for all that?
You should try to re-position your engine as suggested above. But it looks like you are probably going to need to hammer on your headers. That won't hurt your performance, but will take a toll on the coating.
A piece of insulation there will help to cover up the dent and the accompanying coating damage as well as keep a bit of heat off the box.
Master, again and still
[Re: GoodysGotaCuda]
#2218912
12/22/16 12:40 PM
12/22/16 12:40 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Tailpipes out the back will help a bunch. What do you have for motor mounts, is it a solid driver's side mount?
You can consider a pair of resonators as well.
Which 6th gear do you have, the 0.50? I have the standard 67-72 motor mounts. The biscuit style I believe so there seems to be some wiggle room. I have to see how much room I have for resonators. And my final drive ratio for the trans is 0.63:1. I'm running 3.55 gears on a 26" tall tire. But doing the math, I may have the other transmission, which I hope not.
[Re: MuuMuu101]
#2218932
12/22/16 01:04 PM
12/22/16 01:04 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Which 6th gear do you have, the 0.50? I have the standard 67-72 motor mounts. The biscuit style I believe so there seems to be some wiggle room. I have to see how much room I have for resonators. And my final drive ratio for the trans is 0.63:1. I'm running 3.55 gears on a 26" tall tire. Do you have tail pipes at all or just dumps at the axle ? Schumacher sells shims that go between the biscuit and the K frame , but don't get carried away and change your drive shaft angle , I would try shifting the engine toward the passenger side instead of raising it because it could eventually settle back down. Also you could grind a little off the steering box ... that is obviously more work ...
[Re: JohnRR]
#2219039
12/22/16 03:18 PM
12/22/16 03:18 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Which 6th gear do you have, the 0.50? I have the standard 67-72 motor mounts. The biscuit style I believe so there seems to be some wiggle room. I have to see how much room I have for resonators. And my final drive ratio for the trans is 0.63:1. I'm running 3.55 gears on a 26" tall tire. Do you have tail pipes at all or just dumps at the axle ? Schumacher sells shims that go between the biscuit and the K frame , but don't get carried away and change your drive shaft angle , I would try shifting the engine toward the passenger side instead of raising it because it could eventually settle back down. Also you could grind a little off the steering box ... that is obviously more work ... I have full tailpipes with their exhaust tips. The exhaust dumps before the bumper. That's what I was worried about with changing engine position. I'll probably try skicker's method tomorrow and moving the engine a little to the passenger side. I may even dent the header. I have a feeling that contact may be causing part of my drone. I have the day off tomorrow, so I have some time.
[Re: MuuMuu101]
#2219042
12/22/16 03:21 PM
12/22/16 03:21 PM
Posts: 2,260 IL
furious70
IL
tailpipes for sure. I tried various mufflers and turn downs on my Fury before finally putting the tail pipes on. World of difference.
And dent the header and be done with it.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Dave Hall]
#2219054
12/22/16 03:38 PM
12/22/16 03:38 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
My TTI 3" system does the same thing. I think resonators between the axle and bumper are where we are headed... I was thinking of a decent place of putting them, but there's hardly a straight piece of tubing on the entire system. If resonators are going on, they're probably going to have to go there.
[Re: MuuMuu101]
#2219057
12/22/16 03:44 PM
12/22/16 03:44 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Eric at Classic Chambered Exhaust made me a set of these 2.5" resonators to fit beside the gas tank on my 70 Challenger. He made them so that they would bolt onto my new 2.5" R/T exhaust tips. All I had to do is cut off the rear TTi exhaust pipe and clamp them on.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
