Anyone use Jegs cage in A-body? #2217207
12/19/16 08:06 PM
12/19/16 08:06 PM
OH
TheBlackCar Offline OP
OH
Anyone install one of these? The bends on the main hoop are way too high, instead of being at top of door jamb, it's half way up window. I called to verify that I got the correct hoop. After comparing measurements to confirm, I can't believe they are selling without issue.
Not on here trying to badmouth, just curious if anyone had used one. We put one of there kits in a truck and it turned out great, was little disappointed when I started on this.
I usually bend my own and planned on minor modifications, but...lol
Re: Anyone use Jegs cage in A-body? [Re: TheBlackCar] #2217353
12/19/16 11:57 PM
12/19/16 11:57 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Can't say that I have. Comp Chassis is only a few hours pull away from me and they make em right.
Re: Anyone use Jegs cage in A-body? [Re: TheBlackCar] #2217368
12/20/16 12:14 AM
12/20/16 12:14 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I used their b-body in and a-body had to cut the main hoop down but wanted the cage to be tight .. I can't complain ..
Re: Anyone use Jegs cage in A-body? [Re: TheBlackCar] #2217435
12/20/16 01:18 AM
12/20/16 01:18 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
Same issue, ordered one from comp was told a week out, no show. Called 4 times and was finally told eight weeks on delivery, plain bullcrap, got stroked thru jegs, they had the jegster a body in stock the whole time but never mentioned it. Had issues with it. Total crap kit period. Never again. If you want quality materials and the same size tubing throughout, build it yourself, as the saying goes,you get what you pay for.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Anyone use Jegs cage in A-body? [Re: TheBlackCar] #2217458
12/20/16 01:39 AM
12/20/16 01:39 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Say it ain't so. I have a Jegs bar kit waiting to be installed in my duster. May just look into getting a custom one built. Ugh.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Anyone use Jegs cage in A-body? [Re: 71yelladustr] #2217516
12/20/16 03:07 AM
12/20/16 03:07 AM
OH
OH
I've had this lying here since May. Lol
Been gathering parts to redo this relic for awhile.
This hoop almost stands up (very little to trim off bottom). Problem as I see is the bend is way too high. Otherwise, the overall width and top bend seem good, which made me think they made it that way and wasn't "picked" wrong at the warehouse. Just a little hurdle I guess....
Curious if anyone had installed one for comparison.
Re: Anyone use Jegs cage in A-body? [Re: 70dusterjohn] #2217528
12/20/16 03:23 AM
12/20/16 03:23 AM
OH
OH
Never thought of that. It's not too wide?
I was gonna slide over to "Summtimes" and just get one for a-body, but they don't have one in stock. Imagine that.lol. Jegs is a 4hr round trip and acquiring measurements over the phone seemed like a major deal. I did get a guy to go back and measure one, and it was the same as I got....so....
Re: Anyone use Jegs cage in A-body? [Re: TheBlackCar] #2217557
12/20/16 04:36 AM
12/20/16 04:36 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Those are not "custom" built for each car. That's just a hoop that happens to fit inside an A-body. It may be the same hoop and kit for several cars with similar inside dimensions. You want a cage that FITS, you are going to have to build it yourself or have someone do it.
Re: Anyone use Jegs cage in A-body? [Re: TheBlackCar] #2217584
12/20/16 08:40 AM
12/20/16 08:40 AM
Deerfield, Ohio
Deerfield, Ohio
A and B are different .. Period .. I have a friend that worked there, and it was about a 1 1/2 difference. It was taller but they all come that way. Oh and that cage was cert. In a dart.
Re: Anyone use Jegs cage in A-body? [Re: 70dusterjohn] #2217765
12/20/16 02:34 PM
12/20/16 02:34 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
When I finally have to cage my Ramcharger, I will just go down to this place and have them bend up some pipe
https://www.artmorrison.com/homepage2.php
Since I have a '72 Cuda in the shop right now, the owner and I will probably place an order for his cage first and they probably already have a kit in stock for his E-body.
Morrison's is about 25 miles from my door.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
