WHERE TO MOUNT THE FUEL ISOLATOR #221709
02/11/09 09:58 PM
02/11/09 09:58 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
where are you guys mounting your fuel isolator on the motor or firewall or? please post pics if you have them thanks
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: moparbud] #221710
02/11/09 10:56 PM
02/11/09 10:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Has to be at least 6" forward of the firewall, they
dont want something to explode and take it out, mine
is about 4" forward but no one has said a thing plus
mine is way out board mounted to the chassis tube.
Sorry no pic
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: MR_P_BODY] #221711
02/12/09 12:02 AM
02/12/09 12:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you are talking the isolator that allows you to run the fuel pressure gauge in the cockpit my suggestion is to mount in the GARBAGE CAN! Those things are VERY slow to react and if you REALLY need to know your fuel pressure are worthless. Just my
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: Al_Alguire] #221712
02/12/09 12:08 AM
02/12/09 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I happen to like mine and I checked it against a gauge,
its within a 1/4 psi
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: MR_P_BODY] #221713
02/12/09 12:20 AM
02/12/09 12:20 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mr P. I am by no means saying they are not accurate. My issue is they are VERY slow to react to changes, ie loosing pressure and will not always show a 1-2 loose quickly. I have personally see two cars loose motors, both nitrous due to using them. After doing some data logging, and in car video I was convinced to loose mine. I have seen this with both the Longacre and Auto meter isolaters. Just my experiences.
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: Al_Alguire] #221714
02/12/09 12:42 AM
02/12/09 12:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I dont play with the spray so I'm not worried
about that
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: Al_Alguire] #221715
02/12/09 01:09 AM
02/12/09 01:09 AM
Renton Washington
Triple Threat Offline
Renton Washington
What would you recommend as an alternative route then for someone who doesn't want to mount a gauge on their cowl? Electric?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: Triple Threat] #221716
02/12/09 09:06 AM
02/12/09 09:06 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
I have used a fuel isolator and agree with others that they are useless for accurate readings.
As the temp rises in engine compartment so will the guage reading. I would use an electric sender type guage if I needed to see it from the drivers seat.
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: ToddP] #221717
02/12/09 09:19 AM
02/12/09 09:19 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The fuel isolators might not show a 1 or 2 psi fluctuation quickly enough for low pressure use, but for EFI stuff it is worth it's weight in gold. I regularly put 150 psi of pressure thru my fuel system. The electric sending units cannot handle that kind of pressure, and are VERY scary when they fail.
Ever seen fuel boil while being sprayed directly onto the headers and not catch fire? No sparks allowed.
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: MR_P_BODY] #221718
02/12/09 09:45 AM
02/12/09 09:45 AM
mo
moparbud Offline OP
moparbud  Offline OP
mo
ok thanks for the info
Re: WHERE TO MOUNT THE FUEL ISOLATOR [Re: Duner] #221719
02/12/09 10:04 AM
02/12/09 10:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine doesnt use a electrical sender its a mech gauge
one psi in on the one side of the diaphram and one
psi on the other side of the diaghram to the gauge.
One thing thats real important with this style of
unit is the side going to the gauge is filled with
glycerin and its VERY important that its FULL otherwise
you will compress the air thats in there
