Strong B-block bottom end for max hp effort
#2215584
12/17/16 01:03 PM
12/17/16 01:03 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Gents, I have a good block to start with. I would like your feedback on the best option for strengthening a stock block for 900+ hp. I know a race block built to the task would be better, but I'm building a stock blcok. I know there are quite a few mfgrs, I'm looking for products you have used and kept the bottom end together until something else gave way. Main caps obviously, steel or aluminum? Girdle worth it? Mfgrs for both? This is another of those issues where I don't want to save a penny and waste a dollar, but don't want to spend bigger $$ when less will do with a margin of safety. Thanks in advance, Merry Christmas.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Strong B-block bottom end for max hp effort
[Re: Lifsgrt]
#2215600
12/17/16 01:25 PM
12/17/16 01:25 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
You're not going to like the answers as stock block and 900hp dont work together. Anything you do is a band aid and will fail. Just a matter of when, not if.....If you want to spend wisely, spend on an aftermarket block.
[Re: Lifsgrt]
#2215647
12/17/16 02:25 PM
12/17/16 02:25 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Aluminum caps and longest, lightest, strongest rods available. Piston and pin weight at dead minimum. Maybe an SBC wrist pin?
[image][/image]
[Re: sgcuda]
#2215662
12/17/16 02:42 PM
12/17/16 02:42 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
900 horsepower with a stock block is doable but its doable for a limited amount of runs. Besides doing all the band-aids I would recommend finding a good church and Praying as often as possible. Throw salt over your right shoulder, and attend more car shows than races. Good-luck. Oh and PLEASE stay away from detonation and 7500 plus RPM. An engine diaper is also good insurance too.
[Re: Lifsgrt]
#2215685
12/17/16 03:14 PM
12/17/16 03:14 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
As stated above get ready to spend some money. I started off with the original BCR girdle with the aluminum main caps, It looked so good I really had a hard time putting the oil pan on just covering up such a quality piece. This is NOT a bolt on system . As with any after market main cap install the block must be align bored. Then with the girdle, the bottom of the block [ pan rail ] and main caps must decked to make sure they are flat. The girdle is stud bolted to the pan rail and the girdle is stud bolted to the main caps tying it all together. Acid clean the block before any hard block is installed. This should be done and cured before any machining is done. I don't run anywhere near 900 Hp but it has held up for over 8 years for me
[Re: Lifsgrt]
#2215841
12/17/16 07:25 PM
12/17/16 07:25 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Define good block please ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I like and use Ductile Iron main caps with ARP main studs on all my builds that will exceed 600 HP on pump gas. I also choose to use and build 400 blocks for any wedge build, regardless of fuel type used, for motors built to make over 700 HP also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) As already stated a good race block is the best choice to start with on any serious race build PM on this for more information and help, if you want it
[Re: WO23Coronet]
#2215871
12/17/16 08:40 PM
12/17/16 08:40 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Answering for the OP here so forgive me if I get it wrong, but he's building a Daytona clone for salt flat racing, and the class requires a stock block from an engine that was available in that chassis. Daytona's only came with 440's and 426 Hemi's so it has to be a 440 block, he can't use a thick web 400 230 block unfortunately. Will they be allowed to use power adders such as a turbo.
[Re: Lifsgrt]
#2215874
12/17/16 08:46 PM
12/17/16 08:46 PM
crabman173
crabman173
900 wedge HP without power adders is almost impossible/ at least very hard without 4.5 inch bores and it is silly to think that a stock block will hold 900 HP for long no matter what the heck you do to it ( unless perfectly tuned turbo or the like) Please call Marsh Perf 336 283 0800 and get a new 440 block from him--he has two in stock ready to go --not cheap but hey he has the only two on the market I am guessing DRY SUMP DRY SUMP A Hemi is the right direction for that job but bet the bar is already set pretty darn high in that class Just no good answer on making that goal with a $50 block and spending a grand+++ to slightly improve it is still a crapshoot Wet sump in that application is rolling the dice
[Re: cudaman1969]
#2216179
12/18/16 01:15 PM
12/18/16 01:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Real funny, been reading David Vizards book on porting. He shows on one page a 410 cu in small block Chevy single four making in excess of 1000 hp and we can't even get close. What a shame or are we talked out of it before we even try? I assume this was a N/A engine... thats 2.44 HP per ci.. thats a ton.. sounds like one of those happy dynos ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2216302
12/18/16 04:07 PM
12/18/16 04:07 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
Real funny, been reading David Vizards book on porting. He shows on one page a 410 cu in small block Chevy single four making in excess of 1000 hp and we can't even get close. What a shame or are we talked out of it before we even try? I assume this was a N/A engine... thats 2.44 HP per ci.. thats a ton.. sounds like one of those happy dynos When I read his carb book I really got that same feeling.
