Page 1 of 3 1 2 3
Cam selection; 340 with manifolds #2215583
12/17/16 12:56 PM
12/17/16 12:56 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I have been running a 69 dart 340 for a few years with a racer brown cam 220* .460 lift cam. It works really good but I would like to increase the horsepower. Any recommendations for a small block running stock manifolds? I would consider a solid cam but would prefer hydraulic. I have stock 2.02 valve heads and stock 10.5 compression.
My original idea was to put headers on it but TTI's and full exhaust run close to 2k in Canada so I'm hoping for a better option.
Opinions?
Re: Cam selection; 340 with manifolds [Re: dd340] #2215621
12/17/16 01:44 PM
12/17/16 01:44 PM
OT have you dialed in the dist spot on? It makes a world of difference. Is the A/F ratio correct? mandrel bends in exhaust & general free flowing? Here's a BTT for ya since you ain't gettin any love on your Q (& I ain't a cam guy).
Re: Cam selection; 340 with manifolds [Re: dd340] #2215629
12/17/16 01:54 PM
12/17/16 01:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don't think you're going to find the magic you're looking for in a cam swap.
Keep saving for the headers and exhaust system.
Re: Cam selection; 340 with manifolds [Re: dd340] #2215655
12/17/16 02:35 PM
12/17/16 02:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Upgrading parts is interdependant.
Right now you have a very mild cam and the full boat TTI setup will probably not net a substantial difference, certainly not $2000 worth.
Putting in more cam will probably not see as great an improvement with manifolds as it would with headers.
But then again, if the intake system is the bottle neck you need to improve that as well.
Vicious circle.
And as you up the HP potential the cycle only becomes more pronounced. But any one of those changes will show some improvement and as you can afforded upgrading the other areas will enhance that improvement.
Don't be the exception.
Re: Cam selection; 340 with manifolds [Re: dd340] #2215712
12/17/16 03:44 PM
12/17/16 03:44 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Back when my 340 had HP manifolds, RPM intake, 650VS carb, 3500 converter, and 3:91's, Scott Brown spec'd me out a cam that was 226/238, 270/288, .489"/.480" on a 112 cl. This has been a great little cam and I still run it today with other upgrades since the cam swap.
But the best single upgrade that I ever made for my stockish 340 was removing the stock convertor for the 3500 unit. (I did not see what tranny you were running, but thought to throw this out there.)
Re: Cam selection; 340 with manifolds [Re: dd340] #2215730
12/17/16 04:17 PM
12/17/16 04:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You don't need headers to make power. Will you (usually) make more power with headers and exhaust? Yes. Do you need the difference? In street driving, usually not. I have one of each, both are stroker 340's, 422 and 426 cubes respectively. Both are built very similarly, similar cams ported iron heads that flow at around 280, both in 71 A-body cars with manual transmissions and 3,91 gears. Both have both been dyno'd so I have real data on them. The 426 cam specs are attached, the 422 was a very similar grind. The 426 made 450hp and 500tq. These numbers were made with exhaust manifolds, stock iron intake, stock Thermoquad carb, and everything else externally stock down to the belts and hoses. Now, the 422. It has TTI headers, mandrel bent 3" exhaust, a single plane intake, a Holly 950HP carb, 7AL ignition, and all the other 10 cent tricks. It made 530hp and 520tq on the dyno.
So, bottom line, A LOT of $ and optional equipment (as a package that works well together) resulted in roughly 75hp and 20lbs of tq most things being equal if not at least similar.
On the street you simply don't need the extra hp. the 450 engine will blaze the tires at any speed and torque is so close it feels the same.
.02
Re: Cam selection; 340 with manifolds [Re: ScottSmith_Harms] #2215766
12/17/16 05:17 PM
12/17/16 05:17 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
Originally Posted By ScottSmith_Harms
You don't need headers to make power. Will you (usually) make more power with headers and exhaust? Yes. Do you need the difference? In street driving, usually not. I have one of each, both are stroker 340's, 422 and 426 cubes respectively. Both are built very similarly, similar cams ported iron heads that flow at around 200, both in 71 A-body cars with manual transmissions and 3,91 gears. Both have both been dyno'd so I have real data on them. The 426 cam specs are attached, the 422 was a very similar grind. The 426 made 450hp and 500tq. These numbers were made with exhaust manifolds, stock iron intake, stock Thermoquad carb, and everything else externally stock down to the belts and hoses. Now, the 422. It has TTI headers, mandrel bent 3" exhaust, a single plane intake, a Holly 950HP carb, 7AL ignition, and all the other 10 cent tricks. It made 530hp and 520tq on the dyno.
.02
Thanks for those dyno numbes Scott. Where did you make peak hp on that stroker motor with manifold? I assume it was pretty low in the rpm band.
Maybe I would be further ahead putting a stroker assembly in it.
Re: Cam selection; 340 with manifolds [Re: RapidRobert] #2215770
12/17/16 05:20 PM
12/17/16 05:20 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I'm not at all upset with the way the current set up runs. I have run a best of 13.7 at about 102 mph, that's with 3.23 non suregrip gears. So feel like it's pretty much doing what it should. I just have the motor out of the car right now so I want to upgrade a bit.
Re: Cam selection; 340 with manifolds [Re: dd340] #2215773
12/17/16 05:23 PM
12/17/16 05:23 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
.02
By the way, I have a stroker 340 motor in my 87 ram d100 and it's awesome, but with my dart I was just looking for another 30-40 hp.
Re: Cam selection; 340 with manifolds [Re: dd340] #2215776
12/17/16 05:24 PM
12/17/16 05:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
Because that's a cheaper option than the headers and exhaust?
Re: Cam selection; 340 with manifolds [Re: fast68plymouth] #2215777
12/17/16 05:26 PM
12/17/16 05:26 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
No but maybe better bang for the buck. I haven't looked up the cost of stroker assembly's lately.
Re: Cam selection; 340 with manifolds [Re: dd340] #2215835
12/17/16 06:59 PM
12/17/16 06:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The strokers make peak torque around 4,200 rpm, but the torque is noticeably stronger from idle to peak and nice and flat afterwards. Its like driving a (strong) big block. On the street torque is king as you don't need to rev the engine to the moon to make big power.
If you are considering a complete build definitely put your money into a stroker it and if you want more later it's easy to add or change external stuff. Stroker kits are getting really reasonable now, 4.00" cast cranks are only $299.00, but I'd step up to a good forged crank if affordable. As for brands, I like Scat or Callies, but even an Eagle is ok.
Re: Cam selection; 340 with manifolds [Re: ScottSmith_Harms] #2216075
12/18/16 04:42 AM
12/18/16 04:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
.02
Could you elaborate on the heads used on each motor respectively?
Re: Cam selection; 340 with manifolds [Re: dd340] #2216153
12/18/16 12:43 PM
12/18/16 12:43 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Very interested combo Scott, are the manifolds flowed in anyway? Exhaust or intake? I have to figure your carbs work like no other as well.
Careful, your character's showing!
Re: Cam selection; 340 with manifolds [Re: dd340] #2216168
12/18/16 12:59 PM
12/18/16 12:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
(I corrected my first post typo on flow numbers).The heads on the 422 are econo W2's ported by Moparts member OU812, they flowed in the 285-290 range. I can't elaborate on the 426 heads but they flowed in the 275 range. Both have 1.5 rockers (although 1.6's might offer up a bit more power). The 426's exhaust manifolds have been extrude honed but on the dyno we tested them vs unmodified examples and there was only a couple HP difference. The intake is bone stock as is the Thermo-quad (4972) didn't even change the jets so nothing magical there. I'm sure some jet changing and intake porting would find more power.
Re: Cam selection; 340 with manifolds [Re: ScottSmith_Harms] #2216274
12/18/16 03:30 PM
12/18/16 03:30 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
DD340 those numbers with a non sure grip are pretty darn good. It would be interesting with 3.91s and tuning.
Re: Cam selection; 340 with manifolds [Re: joes68340s] #2216288
12/18/16 03:52 PM
12/18/16 03:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Running 13.7's with 3.23 open with that cam, and stock manifolds sound pretty well tuned already
Re: Cam selection; 340 with manifolds [Re: autoxcuda] #2216305
12/18/16 04:12 PM
12/18/16 04:12 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I think it it would really benefit from a decent converter, sure grip and some sticky tires. I think it could be a low 13 sec car. My best 60' time is around 2.15 sec.
Re: Cam selection; 340 with manifolds [Re: dd340] #2216522
12/18/16 09:08 PM
12/18/16 09:08 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
When I say tuning I'm talking the entire package chassis is huge now. Hes got great mph.
Re: Cam selection; 340 with manifolds [Re: dd340] #2216528
12/18/16 09:14 PM
12/18/16 09:14 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Opinions?
Based on your opening question and some of your responses I think we need to know your budget, and your expectation. Certainly you can put headers on the car for far less than $2000. I also think that that a different cam will put more power in it too.
Your car/motor seems to run about right for what it is, and making any one change will not likely yield a huge gain.
Are you running your current combo on pump gas? If so, this surprises me. What is you cranking cylinder pressure?
If you go to a cam swap, I would go with a small solid
Page 1 of 3 1 2 3
