Re: 4-speed overdrive and 5-speed owners
[Re: Airgrabber]
#2215340
12/16/16 10:20 PM
12/16/16 10:20 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Running a Tremec TKO 600 behind my 360, best bang for the buck IMO. Passon if you have the time and money.
[Re: Airgrabber]
#2215589
12/17/16 01:08 PM
12/17/16 01:08 PM
Posts: 18,157 Mass
DAYCLONA
Mass
How do you like either the 4-speed Overdrives or 5-speeds that are available for our cars today? Comments on either transmission appreciated. I've done the most popular OD installs, Gear Vendors, 518's, T5's TKO's and T56, along with R700, and other AOD4's If your considering an automatic OD, the Silver Sport Transmission AOD4 kit is truly a bolt in kit, no floor mods, but expensive for most, but worth every penny invested 5 spds in the TKO 500/600 range are available from several sources like Silver Sport and American Power Train, either will require floor mods of some sort to achieve proper drive line angles, you have to weigh each kit mfg's package/price to see which you favor... IMHO, 5 spds are a nice upgrade, but rather "old school" nowadays, T56 6 spds are truly the way to go, Silver Sport is leading the market with kit applications should you decide to go this route As for the low dollar 518, Gear Vendors, etc swaps, they are just that, low dollar swaps, functional yes, but not truly desirable if a deep OD ratio is your goal, as most only offer a .80-.70 OD at best, a TKO 5 spd can go as low as .64 OD, and a T56 can drop even further into the .50 range I have owned and still have an 833 4spd vehicle, and quite frankly would never want to drive any 4 manual after having 5/6 spd equipped vehicles over the last decade+...even a 3 spd automatic feels antiquated and dogged in this day and age Mike
[Re: DAYCLONA]
#2215646
12/17/16 02:25 PM
12/17/16 02:25 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
How do you like either the 4-speed Overdrives or 5-speeds that are available for our cars today? Comments on either transmission appreciated. I've done the most popular OD installs, Gear Vendors, 518's, T5's TKO's and T56, along with R700, and other AOD4's If your considering an automatic OD, the Silver Sport Transmission AOD4 kit is truly a bolt in kit, no floor mods, but expensive for most, but worth every penny invested 5 spds in the TKO 500/600 range are available from several sources like Silver Sport and American Power Train, either will require floor mods of some sort to achieve proper drive line angles, you have to weigh each kit mfg's package/price to see which you favor... IMHO, 5 spds are a nice upgrade, but rather "old school" nowadays, T56 6 spds are truly the way to go, Silver Sport is leading the market with kit applications should you decide to go this route As for the low dollar 518, Gear Vendors, etc swaps, they are just that, low dollar swaps, functional yes, but not truly desirable if a deep OD ratio is your goal, as most only offer a .80-.70 OD at best, a TKO 5 spd can go as low as .64 OD, and a T56 can drop even further into the .50 range I have owned and still have an 833 4spd vehicle, and quite frankly would never want to drive any 4 manual after having 5/6 spd equipped vehicles over the last decade+...even a 3 spd automatic feels antiquated and dogged in this day and age Mike A518 has a .69 OD
[Re: savoy64]
#2215666
12/17/16 02:45 PM
12/17/16 02:45 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
i have a friend that runs road courses with the keisler----his funny is that if you are at a race and you see 2 or more drivers standing around talking that one of them is asking if someone has a T56 core to sell......not funny if you have a viper or gm---but funny enough for him.... Would somebody in the know here please explain the differences in the TKO transmissions??? TY
[Re: CSK]
#2215796
12/17/16 05:53 PM
12/17/16 05:53 PM
Posts: 18,157 Mass
DAYCLONA
Mass
How do you like either the 4-speed Overdrives or 5-speeds that are available for our cars today? Comments on either transmission appreciated. I've done the most popular OD installs, Gear Vendors, 518's, T5's TKO's and T56, along with R700, and other AOD4's If your considering an automatic OD, the Silver Sport Transmission AOD4 kit is truly a bolt in kit, no floor mods, but expensive for most, but worth every penny invested 5 spds in the TKO 500/600 range are available from several sources like Silver Sport and American Power Train, either will require floor mods of some sort to achieve proper drive line angles, you have to weigh each kit mfg's package/price to see which you favor... IMHO, 5 spds are a nice upgrade, but rather "old school" nowadays, T56 6 spds are truly the way to go, Silver Sport is leading the market with kit applications should you decide to go this route As for the low dollar 518, Gear Vendors, etc swaps, they are just that, low dollar swaps, functional yes, but not truly desirable if a deep OD ratio is your goal, as most only offer a .80-.70 OD at best, a TKO 5 spd can go as low as .64 OD, and a T56 can drop even further into the .50 range I have owned and still have an 833 4spd vehicle, and quite frankly would never want to drive any 4 manual after having 5/6 spd equipped vehicles over the last decade+...even a 3 spd automatic feels antiquated and dogged in this day and age Mike A518 has a .69 OD I was generalizing the OD range mentioned above regarding some of the other OD offerings, Yes you are correct, the 500/518 are both .69 OD, and are good candidates for mild horsepower applications, but the OD feature is not of sound engineering and prone to operating issues and eventual failure, more so in high performance applications, I generally like to install a transmission once, with the exception of clutch/TOB changes being acceptable repair practice
[Re: floridian]
#2215821
12/17/16 06:40 PM
12/17/16 06:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
i have a friend that runs road courses with the keisler----his funny is that if you are at a race and you see 2 or more drivers standing around talking that one of them is asking if someone has a T56 core to sell......not funny if you have a viper or gm---but funny enough for him.... Would somebody in the know here please explain the differences in the TKO transmissions??? TY The TKO 500 or 600 is a redesign of Tremecs TR-3550, the 3550 was a long running/widely used production piece used by Ford/GM and assorted other production mfg, the TKO is Tremecs "aftermarket" offering, having only been used once in factory production in a limited number of Cobra Mustangs The TKO has a 10 spline input shaft, smaller input bearing retainer, the TKO 600 has a larger 26 input spline, larger input bearing retainer, both have a 31 spline output shaft the 500 TKO has a 3.27:1 1st gear, the 600 has a 2.87:1 1st gear, the TKO's utilize high grade alloy gears and steel forged shift forks, where as the T5 and TR3550 used cast gears and aluminum shift forks, the biggest change to the TKO design is the upgrade from a 3pc to 1pc countershaft along with internal upgrades mentioned above Downside is the bronze syncros, that limits the shift point to 6000 RPM, carbon fiber upgrades are available to increase that into the 7000 rpm range If your considering a TKO opt for the 600, stronger unit, and more upgrade/service offerings from assorted aftermarket suppliers/rebuilders
[Re: savoy64]
#2215828
12/17/16 06:51 PM
12/17/16 06:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
i have a friend that runs road courses with the keisler----his funny is that if you are at a race and you see 2 or more drivers standing around talking that one of them is asking if someone has a T56 core to sell......not funny if you have a viper or gm---but funny enough for him.... True, but funny...that's generally the case with early T56 Tremec 6 spds where the vehicles horsepower has been increased substantially, the T56 Magnum is a different animal however, it was designed by Tremec to address it T56 shortcomings, the Magnum is designed to survive behind high HP, supercharged and boosted motors, and take a beating on drag strips and road courses in prolonged use, IMHO pretty much the way to go if considering an OD for a multi purpose vehicle
[Re: DAYCLONA]
#2215845
12/17/16 07:36 PM
12/17/16 07:36 PM
John_Kunkel
Rio Linda, CA
And a better OD ratio of .64
[Re: DAYCLONA]
#2215914
12/17/16 10:33 PM
12/17/16 10:33 PM
floridian
Lakeland FL
i have a friend that runs road courses with the keisler----his funny is that if you are at a race and you see 2 or more drivers standing around talking that one of them is asking if someone has a T56 core to sell......not funny if you have a viper or gm---but funny enough for him.... Would somebody in the know here please explain the differences in the TKO transmissions??? TY The TKO 500 or 600 is a redesign of Tremecs TR-3550, the 3550 was a long running/widely used production piece used by Ford/GM and assorted other production mfg, the TKO is Tremecs "aftermarket" offering, having only been used once in factory production in a limited number of Cobra Mustangs The TKO has a 10 spline input shaft, smaller input bearing retainer, the TKO 600 has a larger 26 input spline, larger input bearing retainer, both have a 31 spline output shaft the 500 TKO has a 3.27:1 1st gear, the 600 has a 2.87:1 1st gear, the TKO's utilize high grade alloy gears and steel forged shift forks, where as the T5 and TR3550 used cast gears and aluminum shift forks, the biggest change to the TKO design is the upgrade from a 3pc to 1pc countershaft along with internal upgrades mentioned above Downside is the bronze syncros, that limits the shift point to 6000 RPM, carbon fiber upgrades are available to increase that into the 7000 rpm range If your considering a TKO opt for the 600, stronger unit, and more upgrade/service offerings from assorted aftermarket suppliers/rebuilders Thank you.... but where does the T56 Magnum fit in here??
