How fast have you gone with a standard port bb head? #2214742
12/15/16 10:50 PM
12/15/16 10:50 PM
junction city oregon
V
viperblue72 Offline OP
V
And or how much horsepower? And your combo please?
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214747
12/15/16 10:57 PM
12/15/16 10:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Customers car:
14:1 493, mild roller, tg4500 intake, 1050 carb, 335cfm std port SR's in a 2300lb S/G "street roadster".
As I recall it went like 8.80's in decent air......it was just under 700hp.
It was a very low maintenance bracket build.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214764
12/15/16 11:08 PM
12/15/16 11:08 PM
AndyF Offline
AndyF  Offline
Yep, that would do it. I wonder how the Trick Flows would compare to the std port SR heads.
I think the answer to the question is how fast will 700 hp go in your car. Obviously a 700 hp engine in a rail will go a ton faster than in an Imperial with street tires.
It is fairly easy to build a 700 hp std port engine these days. Buy some Trick Flow heads, add a solid roller cam and some decent compression and you are there.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214776
12/15/16 11:19 PM
12/15/16 11:19 PM
My old pump gas 518 C.I. low deck pump gas stroker (10.29 to 1 comp. ratio)ran a best of 10.30 at 127.8 MPH through the 3.0 inch exhaust system with the Magnaflow 14x3 inch ovals muffs mounted at rear bumper with me in my 1971 Duster weighing 3450 lbs. with the six pack and air cleaner on the CNC ported Eddy RPM heads.
That motor on a DTS engine dyno in Ontario, CA with a .050 shorter stroke crank and 1.0 point less compression and a set of big valve mildly ported 906 heads made 612 HP @ 5500 RPM and 644 Ft. Lbs. at 4500 RPM shruggy
I was really happy with that motor and the results it would produce with the changes I made on it, the last combination was a set of Indy SR M.W. heads and a Indy 400-3 intake and a holley 9375 non HP carb made 727 HP at 4300 ft in Klamath Falls OR. at 4300 ft. altitude. That was the last changes I made on that car and it made the car run 9.993 at 134.7 MPH through the full exhaust and on 91 octane OR non ethanol pump swill at Woodburn in late summer boogie
You can made decent power with the standard port heads on a BB Mopar thumbs
Better heads will make more power also with no other changes thumbs work scope
Now, how fast do you want to go devil
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214777
12/15/16 11:21 PM
12/15/16 11:21 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
440 six pack rods, Ross domed pistons, 915 heads, 2.14/1.88 Herbert roller, Team G, 1050. 575hp @ 6100 rpm. 9.97 @ 135 mph in 3,000 lb Cuda.
[image][/image]
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214778
12/15/16 11:22 PM
12/15/16 11:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
I dont think 750hp would be all that hard to reach with some 350cfm heads on a high compression roller stroker build.
Then, as you say....... Just depends on what you bolt it into.
And there's also boost or spray.
'Nother one:
14:1 528, b1bs heads flowing around 325. M1 TR with 2 x 750's, .690 roller, made right about 720hp @ 6000rpm.
Went 9.71 @ 140 in a 3700lb 68 charger R/T.
One more:
12:1 low deck 451, stage 6's with mild porting(300cfm), RB TG4500, .685 roller, made 650hp, went 9.31 @ 143 in a 2650lb S/G 70 Cuda.
Re: How fast have you gone with a standard port bb head? [Re: fast68plymouth] #2214789
12/15/16 11:34 PM
12/15/16 11:34 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
My brothers 512 15.1 std port trick flows ported soild roller, under .700 with 1.6 rockers nothing super fancy in a 67 cuda stock suspension went 9.56 best at 3298 with him in it .. I'm sure there is more in it as we got it together at the end of the season. Plus it was set up to be sprayed .. Nos converter etc ..
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214817
12/16/16 12:12 AM
12/16/16 12:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Race car?
Street car?
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214818
12/16/16 12:14 AM
12/16/16 12:14 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
135 MPH
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214824
12/16/16 12:23 AM
12/16/16 12:23 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
440 block and crank, alum rods, 11.2 to 1 Ross pistons, unported Edelbrock rpm heads, 304/640 ultradyne flat tappet cam, Isky ductile rockers, 4150 flange M-1 intake, 4150 to dominator 2" adapter with two cheater spray bars installed in it, and an 1150 Dominator on top.
simple straight-forward combo that went a best of 9.96-133 on motor alone, and 8.92-149 on spray.
2950lb 70 Challenger, glide and 9" hughes converter, 4.30 geared 8 3/4.
Dependable and lots of fun!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214826
12/16/16 12:26 AM
12/16/16 12:26 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Dead stock 906 heads, not even a 3 angle valve job, on a 3200 pound Dart, 10.80s-122 .30 over flat tops.
37 years ago technology.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214840
12/16/16 12:49 AM
12/16/16 12:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Funny you ask cos my goal is to have one of or the fastest standard port window street cars at my cubes(470)and wt. now around 3050 n/a and hopefully some will share that............Last time out I went a 1.33 60 ft. and 6.15 @ 109 just lifting before the finish but went 111.78 2 years prior w/a poor 1.4? and 6.20 et so how much power is that? work Been 9.79 @ 135.59 4+ years ago first pass at 3200+ lbs........
Combo; 470 stroker w/a offset ground 413 forged crank, eagle 6.385 chevy rods, JE 12.1.1 true comp. pistons, home ported 84cc(now 72)rpm's w/a 2.19 intake,Victor jr. w/adapter fully ported by Ed Mosler w/some minor adjusting since by me, an Isky solid roller w/.680-.660 and 276-281 @ .050,a home built 1050 dominator,2" Hooker Fender Wells w/3 1/2" side pipes into bullets,a Darrell Parks built 727 stock basically and rollerized,8" 5200+ Continental vert, freshly built Dr.Diff 8 3/4 nodular housing w/4/10's, 35 spline axles, and 28.10.5 w's on 10" Billet Specialties wheels............I`m curious too about wt and et's.............. boogie drive
Re: How fast have you gone with a standard port bb head? [Re: cudaman1969] #2214841
12/16/16 12:51 AM
12/16/16 12:51 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Cam? Converter? Gears?? Intake/carb?
Re: How fast have you gone with a standard port bb head? [Re: cudadoug] #2214865
12/16/16 01:41 AM
12/16/16 01:41 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mild solid cam, Crane? I'll have to ask my partner, 9 inch TCI , 5.13, TM7 800 holly with a 850 baseplate and 2 inch wooden spacer I made. Tried the Weiand, didn't help. Six-pac scoop on a glass hood. Car weighted 3021 but KK weighted 260. Headers by Ed, fender well but made better than Hooker, didn't interfere with tire. Looked like a big spider on the engine stand. Tore up every 8 inch converter we put in it, probably made better now. Won a lot of money with that car.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2214874
12/16/16 01:51 AM
12/16/16 01:51 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
There are iron headed wedge Super Stock cars that run low 9s at pretty hefty weights.....so take that for what it's worth. But that makes some alum headed strokers seem not so impressive. Too many just throw "cool guy" parts at motors instead of carefully planning the combo.
NOT saying you should use iron heads, or not build a stroker............just saying that a good combo is what makes power, not just throwing parts in a pile
Re: How fast have you gone with a standard port bb head? [Re: Monte_Smith] #2214935
12/16/16 03:53 AM
12/16/16 03:53 AM
fullmetaljacket Offline
133 mph. Standard window SR's. 12.5 cr.
Re: How fast have you gone with a standard port bb head? [Re: fullmetaljacket] #2215117
12/16/16 03:22 PM
12/16/16 03:22 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Best mph 139 once, usually 136-137...standard port B1BS,14.2-1
Re: How fast have you gone with a standard port bb head? [Re: Thumperdart] #2215306
12/16/16 09:18 PM
12/16/16 09:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By Thumperdart
Last time out I went a 1.33 60 ft. and 6.15 et so how much power is that?
drive
Enough to run a 9.70, I could of said 9.69, but I didn't. devil
Re: How fast have you gone with a standard port bb head? [Re: Sport440] #2215315
12/16/16 09:33 PM
12/16/16 09:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You suck................lol I say 9.65 or better........... biggrin
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215320
12/16/16 09:42 PM
12/16/16 09:42 PM
V
V
Thanks for the responses. I ask because I have a lowly 383 and I am putting portted sidewinder heads and a tr on it. But my future plan is to build a bigger short block eventually.
My current combo is 12.5 to 1 trw domes, mp590 cam. 2800lb valiant. I'm hoping at least 10.7s. But eventually wanna build a short block for 10.00 or better. Looks like these heads can do the trick.
