E body cluster lenses polishing #2214048
12/14/16 09:26 PM
12/14/16 09:26 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Does anyone have some tips on polishing the lenses on a e body dash cluster?Thanks guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: E body cluster lenses polishing [Re: stickman] #2214057
12/14/16 09:39 PM
12/14/16 09:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If it's just fogged/hazed plastic, Meguiars PLASTIC POLISH, plenty of clean white soft cloth changed out often as you polish, if scratches are present you'll need to determine at which paper grit you'll need to start sanding with, if you can't remove the scratches with 600-800 wet/dry paper start looking for new lenses, I generally finish up sanding in the 3000 grit range before polishing by hand with polish
Re: E body cluster lenses polishing [Re: stickman] #2214084
12/14/16 10:05 PM
12/14/16 10:05 PM
BDW Offline
BDW  Offline
Is that the same stuff used for yellow headlight lense polishing?
Re: E body cluster lenses polishing [Re: stickman] #2214086
12/14/16 10:06 PM
12/14/16 10:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sand wet only with a drop of dish soap in the water. Personally I wouldn't touch it with anything coarser than 1500. Sand the whole surface, not just the scratches. work up to 2000 grit or finer. Hand polishing just doesn't cut it, you need to machine polish it to get a crystal clear finish BUT any heat will melt the plastic so nothing faster than a drill and not too much pressure - let the buffer and compound do the work. I put a small buffing wheel in an air die grinder and turn the pressure down so it turns slow - more manageable than a drill !! You can use the stick polishes that Harbor freight sell - white or red.
Re: E body cluster lenses polishing [Re: BDW] #2214104
12/14/16 10:33 PM
12/14/16 10:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Nope...
this...
Re: E body cluster lenses polishing [Re: stickman] #2214152
12/14/16 11:43 PM
12/14/16 11:43 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I've hand polished with the Meguiars many times with great success.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
