Fuel pump vs AN fittings
#221389
02/11/09 07:40 PM
02/11/09 07:40 PM
Posts: 396 California, USA
Phil Saran
California, USA
I've got a Mallory 140 electric fuel pump I want to reuse.
I bought AN fittings to use, but they only thread in about two threads....what am I doing wrong? Do I need to go back to brass fittings for the pump?
Phil Saran
Parker, Colorado
Re: Fuel pump vs AN fittings
[Re: Phil Saran]
#221391
02/11/09 07:47 PM
02/11/09 07:47 PM
Posts: 5,620 long island NY
Ari440
long island NY
they migth not be 3/8 pipe thread but 3/8 thread with a O ring
had the same problem on a barry grant 4 port regulater
I went to a local speed shop and got the rigth ones
1.39 9.85 - 137 mph
[Re: Phil Saran]
#221392
02/11/09 07:59 PM
02/11/09 07:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just looked at their web site and they state it uses a 3/8 pipe into/ out of the pump so you need AN to 3/8 pipe (what ever size AN you want)
[Re: MR_P_BODY]
#221393
02/11/09 08:35 PM
02/11/09 08:35 PM
Phil Saran
California, USA
Mike,
These are Russell blue AN/pipe thread adapters to fit braided fuel line to each item.
Just wondering is there a fine/corse thread situation here??
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#221395
02/11/09 08:47 PM
02/11/09 08:47 PM
MR_P_BODY
Pipe is pipe BUT I have seen pipe thread being under size or over size, pipe thread is a tapered thread and I have seen some of the alum fittings being over sized (no clue why unless they want them beefier) When I say pipe thread, I am referring to NPT which is what Mallory stated 3/8 NPT
[Re: RobX4406]
#221397
02/11/09 10:28 PM
02/11/09 10:28 PM
Phil Saran
California, USA
I'll take a trip over to Home Depot tomorrow and compare fittings.
I have to assume since I have aluminum AN/pipe fittings, that the pipe part is oversize for the 3/8" hole size.
Phil Saran
Parker, Colorado
[Re: jamesc]
#221399
02/11/09 11:25 PM
02/11/09 11:25 PM
Phil Saran
California, USA
I've got a fuel cell with a -10AN fitting coming out that will have braided line to a fuel filter with -10AN on both ends to the fuel pump and then on to a braided line to connect to 1/2" aluminum fuel line with -8AN on each end to the fuel regulator, then -8 to the DP carb fittings.
Phil Saran
Parker, Colorado
[Re: 68Fastback]
#221402
02/12/09 02:35 AM
02/12/09 02:35 AM
Phil Saran
California, USA
Jim,
You are correct and those are the fittings I aleady bought, but the 3/8" pipe thread side does not screw into the pump, so I will go to Home Depot tomorrow and play around with the brass bittings and see if I can come up with some stuff that will work.
Phil Saran
Parker, Colorado
[Re: BSB67]
#221405
02/12/09 09:01 PM
02/12/09 09:01 PM
Phil Saran
California, USA
The problem is that the threads on the output side of the pump is buggered up and yes I will need to get a pipe tape to clean it up and then use a new aluminum AN/pipe fitting.
Thanks for all the help.
Phil Saran
Parker, Colorado
