1967 Barracuda Formula S 383 daily driver build #2212910
12/12/16 11:58 PM
12/12/16 11:58 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Found a '67 Formula S 383 auto fastback car locally in my search for a '67-68 notch back driver. I wasn't really looking for a big block car but lucked into finding one. I have had a few late model '09 & '15 R/T Challengers & wanted to get back into a vintage daily driver again. The old stuff is just way more fun & every drive is an adventure.
The barracuda has been off the road & in a shed since '85 & needs engine/tranny/gas tank, wiring, radiator, seats, wheels & brakes. It's very rust fee & has most it's original paint. The bumpers,header panel & front valance are all I need for the body but I am also missing the trunk trim.
Brought it home Christmas eve almost a year ago & hope to have it in the road in the next month or so.
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212943
12/13/16 01:01 AM
12/13/16 01:01 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
The car has some neat old speed parts, old '80s Autometer gauges, a Hurst roll control & some miscellaneous bits like Super Stock Springs, billet U-joint caps, adjustable pinion snubber & a 742 sure grip.
I got a '65 383 long block with the car with the drivers front mounting boss. The crank looked good & turned @ 0.010/0.010 & cylinders cleaned up at 0.030. The 727 I got with the car went to Smothers Supercars to go thru it & he add a Transgo kit with the rebuild.
The car did come with some new parts too, an Edelbrock Performer RPM, TTI shorty headers w/aluma-coating, Schumacher motor mount brackets w/isolators.
Cleaned up the floor pans & got any loose scale & some adhesive from some aftermarket carpeting off. They are super clean & only the passenger front has a rust issue, it as 4 pinholes which will need nothing as soon as I get some POR on them.
Luckily there are no extra bucket seat holes & the factory bracing is in place so it wasn't a bench seat car that was converted to buckets.
Drivers front has some busted up spot w/metal below which I'm not really sure what happened there.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212954
12/13/16 01:18 AM
12/13/16 01:18 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
The 383 block got held up in the machine shop, took about 4 months. Got the block back mid April.
Got all the parts to put it together & here are the specs:
383 with a steel crank
Forged flat tops
Edelbrock E-Street w/75cc chambers
Calculates to 9.8:1 compression
Comp Cams XE274H
Holley 650 Street Avenger
Mallory dual point
1 7/8" Hooker full length
I decided to go with Headman B-body full length under chassis instead of the shorty headers but that proved to be a
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212968
12/13/16 01:30 AM
12/13/16 01:30 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Got the engine bay cleaned up & ready to put the engine in.
Got the b-body headers massaged in all the spots that hit but there was no way to get the starter in. I tried a magnum starter & the solenoid majorly hit one of the tubes, I tried the full size starter & just couldn't get it wedged up in there. Thinking the only way would be pull the transmission & slide it in from the back. This set-up is too troublesome for a daily driver plus the passenger side has a couple plugs almost impossible to access.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212971
12/13/16 01:43 AM
12/13/16 01:43 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
After much searching & trying to decide going with $1000 factory manifolds or the shorty headers, I decided I wanted to get the most out of the motor & decided to cut it for fenderwells. I like the old '70s style & for me I think it will work out fine. I just will keep the replacement panels if I ever change my mind. Kind of felt bad cutting such a nice car....
Have a set of old Hooker 1 7/8" fenderwells to go on it.
I cut them on top as small as I could & still make it work, never liked the gaping holes on the top side of the fenderwell.
Check out how much undercoating is in the corner.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212976
12/13/16 01:50 AM
12/13/16 01:50 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
I wanted to run the unique '67 383 A-body unsilenced air cleaner but didn't want to pay the $400-500 price tag guys are wanting. I ended up buying one of the non-performance silenced versions that is the same stamping with the crank case tap on the snorkel. I cut off the snorkel, put a plate over it & smoothed it off. I got a 14" drop base for the Holley carb & it worked out great. I need to get the '67 Comando 383 pie tin, I had the orange one already from a past '70 'cuda.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212979
12/13/16 01:56 AM
12/13/16 01:56 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
One of the hardest things on this thing to find has been a pair of factory buckets, they were missing when I got it & it had some Camaro highbacks. Finnally after 8 months of searching I found some seats with no tracks on the a-body forum. When I got them it was awesome because they were way nicer than I thought. The paint on the seat frames was still shiny, no rust at all. Metal seat backs were not collapsed at all from kids pushing on them, all trim was intact with original hardware. Then after I unboxed & got over how nice they were I was nervous about the seat tracks I had because they were mounted to the Camaro seats. They ended up being the right ones for the car & bolted right up to the new buckets.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212983
12/13/16 02:04 AM
12/13/16 02:04 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
I had 14x8 cragars that came with the car but decided against the 14" rear wheels because I just couldn't find a tire tall enough to make my 4.10 gears work. I ended up with 15x8 Ansen (new style from American Racing) w/ 275/60R15 & 14x6 ET V w/155R14 up front for header clearance.
[img]https://farm1.staticflickr.com/424/31483338651_b15e6097ef_z_d.jpg[img]
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2212996
12/13/16 02:36 AM
12/13/16 02:36 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
All the wiring under the hood & to the headlights had been unwrapped & that hard plastic convoluted covering installed. I pulled all that off & re-wrapped with non-stick tape. It was actually good because I routed the wiring away from the header opening & added additional temp/tach/ground/main power wiring into the loom.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2213708
12/14/16 01:56 AM
12/14/16 01:56 AM
Illinois
SGTFURY62 Offline
SGTFURY62  Offline
Illinois
I like those fenderwell headers on there a lot! Great looking car
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2213773
12/14/16 08:41 AM
12/14/16 08:41 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Nice work. up Been thinking about finding something similar myself for a DD. work
Mallory dual point? Must be an older guy to even know what points are. biggrin Before I retired, lots of the younger techs didn't know what points and condenser were. laugh2
If you haven't already done it, are you going to replace the heater core while all the interior is out? wink
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 1967 Barracuda Formula S 383 daily driver build [Re: I_bleed_MOPAR] #2214202
12/15/16 01:33 AM
12/15/16 01:33 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Thanks, I always liked them but never really wanted them on this real 383 car. I was planning on them going on a '69 /6 Dart with a 440 we have with rusty inner fenders.
Originally Posted By I_bleed_MOPAR
Nice work. Been thinking about finding something similar myself for a DD. Mallory dual point? Must be an older guy to even know what points are. Before I retired, lots of the younger techs didn't know what points and condenser were. If you haven't already done it, are you going to replace the heater core while all the interior is out?
The old, rough original paint cars make nice, stress free drivers.
I'm 41, have had several points cars & several articles show there is no hp loss with points. I would rather have it simple than extra wiring & the latest electronics.
I wasn't planning on worrying about the heater core till after it is driving. I don't think it will be too hard to pull it out down the road.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: SGTFURY62] #2214567
12/15/16 06:30 PM
12/15/16 06:30 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
It couldn't hurt to build a heat shield for the master cylinder.
[img] [/img]
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278661
03/30/17 12:47 AM
03/30/17 12:47 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Got the old Autometer gauges that were in the car when I got all cleaned up & wired up. Ended up getting a replacement for the Coolant Temp since the mechanical one had the sender broke. The replacement one looks pretty decent with these old ones & isn't too far off.
These were stacked on the console & I ended up kind putting them at an angle towards me. Looks better than just all flat.
Not one of these actually matches, check out the 4 different bulb sockets...
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278666
03/30/17 12:54 AM
03/30/17 12:54 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Got the brakes done & bleed without too many initial leaks, with 23 connections throughout the car it was inevitable. Also got the headers put on for "good" with studs, cut between the tubes & filed the mating surface smooth. Found out the "good" Mr Gasket header gaskets had the end opening about 1/4" off. Got a cheap set of header gaskets & they match up perfectly. Still have to adapt my DEI starter heat shield to fit the bottom of the master cylinder to protect from heat.
Got the correct '67 pie tin for the air cleaner.
Now if I could find what I did with the battery tray i could get the battery in & get measured up for cables & such.
The border collie thinks the car is comfortable & is sleeping even though I was running the grinder & banging things around plus it was about 45* in the garage.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278670
03/30/17 12:57 AM
03/30/17 12:57 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Got the pans coated in POR-15 & my spots on my hands as well. Planning on not running carpet for some time so it will look better plus I don't have to worry about any leaks initially when it rains.
Dug out a '67/68 a-body console I bought here on the DC classifieds a few years back. Someone had cut the front of console off that was in the car for some reason. My parts hoarding of parts that don't fit cars I have is finally paying off. I new I would have a console A-body at some point.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278673
03/30/17 12:59 AM
03/30/17 12:59 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Always fun hooking up a battery to something that hasn't had power for the probably the past 25+ years....
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278679
03/30/17 01:04 AM
03/30/17 01:04 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Got everything laid out pretty nice as far as plug wires, wiring & fuel line around the engine. Seems like the past few weeks I've spent nights out in the garage but I've had plenty of dvr'd B/J & Mecum auctions & plenty to line out on the car.
Seems like I've made multiple trips a week to this place.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: clonestocker] #2278684
03/30/17 01:11 AM
03/30/17 01:11 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Been hitting it hard, got a Lokar transmission kickdown & it went on pretty good, much better than the stock 3 piece linkage. The transmission end of the cable is kind of close to the shifter linkage adjustment bolt. I am thinking about putting a set-screw in there to make sure it doesn't interfere.
Need to get a taller throttle cable bracket but for now I added a piece of another bracket to make it reach a little closer & get it hooked up to the carb. Also got the starter heat shield adapted to protect the master cylinder.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278687
03/30/17 01:14 AM
03/30/17 01:14 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Finally found locally a nice old bumper which will go better with the car than a new one. This one is very good shape but once you get up on it you can see some imperfections. It really makes the back look better, been looking at this car for over a year with no bumper.
2021 Toyota Supra
