Were Rallye Gauges standard with AARs? #2213420
12/13/16 06:02 PM
12/13/16 06:02 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
I'm sure I've seen some without, and wouldn't they all be coded A62 on fender tag if they were? And have 3 speed wipers?
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213453
12/13/16 06:58 PM
12/13/16 06:58 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
No rallye gauges in mine...
Tony
70 AARCuda Vitamin C
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213457
12/13/16 07:04 PM
12/13/16 07:04 PM
Kirkland, Washington
Pacnorthcuda Offline
I've seen a lot of them with standard dashes. All I can figure is a typically younger buyer (and less affluent) than other 'Cuda buyers???
Re: Were Rallye Gauges standard with AARs? [Re: Pacnorthcuda] #2213463
12/13/16 07:10 PM
12/13/16 07:10 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Rally dash was optional on cudas yet standard on Challenger R/Ts.
I've always wondered why that was.
Challenger T/As were not R/Ts so rally dashes were optional on them also.
AARs and T/As usually didn't get built with many options, so it is common to see them without rally dashes.
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213464
12/13/16 07:13 PM
12/13/16 07:13 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Standard cluster came with 2-speed wiper motor & manual foot pump washer.
3 speed wiper motor with variable wipers & electric washer optional with the standard cluster.
A62 included the variable wiper motor with electric washer.
Re: Were Rallye Gauges standard with AARs? [Re: Mastershake340] #2213465
12/13/16 07:15 PM
12/13/16 07:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The Dodge line was higher priced than the Plymouth line, so more goodies as standard equipment.
Re: Were Rallye Gauges standard with AARs? [Re: Alaskan_TA] #2213470
12/13/16 07:30 PM
12/13/16 07:30 PM
All true--yet time has treated the 'Cuda favorably vis-a-vis the Challenger!
(that oughtta get someone's BVD's in a bunch)
Re: Were Rallye Gauges standard with AARs? [Re: Mastershake340] #2213479
12/13/16 07:41 PM
12/13/16 07:41 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Ma did a lot of things that made little sense.
Hemi Challenger: rallye guages standard, shaker optional
Hemi Cuda: shaker standard, rallye guages optional
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213482
12/13/16 07:46 PM
12/13/16 07:46 PM
MONC Offline OP
MONC  Offline OP
Thanks guys, good info up
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213674
12/14/16 12:47 AM
12/14/16 12:47 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
My AAR has rallye gauges but column shift, go figure
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213696
12/14/16 01:33 AM
12/14/16 01:33 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
You can also ask why Challengers are two inches longer than a Cuda. Dodge and Plymouth were really two different companies back in the 60s and 70s.
1971 HEMI E BODY REGISTRY
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2213755
12/14/16 04:01 AM
12/14/16 04:01 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Dodge was higher priced line. More luxurious cars. Cougar vs a Mustang.
Higher line, more luxurious, longer wheelbase with better ride. Most Dodges where longer and often wider than Plymouth versions (A, B, and C bodies)
Shaker is a sportier younger go fast type item. That's a Plymouth target buyer.
Re: Were Rallye Gauges standard with AARs? [Re: autoxcuda] #2213881
12/14/16 02:32 PM
12/14/16 02:32 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I also have Rallye gauges, manual steering, column shift
Re: Were Rallye Gauges standard with AARs? [Re: MONC] #2214174
12/15/16 12:06 AM
12/15/16 12:06 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
The standard -vs- optional inconsistencies continued with the 1972 E-body model
72 Cuda standard engine was 340
72 Challenger Rallye standard engine 318 2-bbl the 340 was Optional
Though even with the 318 engine the rallye came standard with dual scooped hood, rallye gauges, sway bars & more
strange because the Rallye replaced the R/T in the 1972 Challenger line-up as the performance model and there was a base model Challenger
Re: Were Rallye Gauges standard with AARs? [Re: Pacnorthcuda] #2214403
12/15/16 01:39 PM
12/15/16 01:39 PM
uk
TiMopar Offline
TiMopar  Offline
uk
I was under the impression that AARs & T/As were not ordered/ optioned by customers, and that one just had to pick what the dealers were sent. Is this correct?
Re: Were Rallye Gauges standard with AARs? [Re: autoxcuda] #2214421
12/15/16 01:57 PM
12/15/16 01:57 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The Shaker was an option except the Hemi Cuda for four barrel E Bodies. Why did DODGE offer another performance hood that was not offered on a Plymouth, a TA Hood on a Challenger for almost a year Starting in the spring of 1970 and ending in the fall of 1971.
Re: Were Rallye Gauges standard with AARs? [Re: mopargem] #2214434
12/15/16 02:13 PM
12/15/16 02:13 PM
New York
rarefish Offline
rarefish  Offline
New York
I have the same "predicament" in my AAR...
Re: Were Rallye Gauges standard with AARs? [Re: TiMopar] #2214527
12/15/16 05:09 PM
12/15/16 05:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Dealership ordered AARs & T/As do exist.
Re: Were Rallye Gauges standard with AARs? [Re: rarefish] #2214529
12/15/16 05:11 PM
12/15/16 05:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I think it is awesome myself, the consoles look really cheap to me.
Extra bonus if the car also has the extra cost bench seat.
Re: Were Rallye Gauges standard with AARs? [Re: Mastershake340] #2214533
12/15/16 05:21 PM
12/15/16 05:21 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
70 'Cudas (AARS too) got road lamps as standard equipment.
1970 Dodge Challenger T/A
