Re: B1vsB1MC hp diff?
[Re: KOS]
#2211873
12/11/16 03:51 PM
12/11/16 03:51 PM
Posts: 4,679 On the parachute mount
n20mstr
If you have to buy castings, makes no sense to go originals. Get mc's and be done. Porting should cost the same.
....BAD A$$ STREET CAR.....
[Re: KOS]
#2211930
12/11/16 05:16 PM
12/11/16 05:16 PM
KOS
yes i know the origs can make 1000 and the porting cost the same my situation is i can buy a set of origs locally or buy new MCs at $3000+ diff in price.so 3k worth the gain in hp?
[Re: KOS]
#2212017
12/11/16 07:45 PM
12/11/16 07:45 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
yes i know the origs can make 1000 and the porting cost the same my situation is i can buy a set of origs locally or buy new MCs at $3000+ diff in price.so 3k worth the gain in hp? M/C's are easily 1000HP with a 4.500 bore and can get to the 1100 range too. As said, get the M/C's and have room to grow with a cam change. If the price of Koffel's and Hemphill are the same, I would have Hemphill do the porting. He's been doing it almost as long as Koffel and I've heard some impressive numbers out of his stuff. Nothing against Koffel, just what I know about Hemphill. I wouldn't have someone experiment on them, that's for sure. JMO
[Re: KOS]
#2212300
12/12/16 01:50 AM
12/12/16 01:50 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Buck did the originals on the 572 that Wade built. That was a fairly low compression pump gas motor with not near a max effort cam that made over 900 on pump swill with ease. So the question is how much power you want. If what you quoted above is all you want, the extra 3k tag for the MCs makes no sense
Have a friend with a 570" Pontiac with Edelbrock heads that makes over 1100 with a head that flows maybe 400 on a good day. So it's not JUST the parts........it's the effort
[Re: KOS]
#2212348
12/12/16 04:47 AM
12/12/16 04:47 AM
KOS
my goal is low maintence piece easy on parts.....compression i dont mind i run Q16 now... id like to make as much power as possible and be able to drive on the street alittle and not have to change valvesprings etc every season.what kinda max power is achievable with that in mind?
[Re: KOS]
#2212446
12/12/16 01:03 PM
12/12/16 01:03 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I hesitate to post anything on this site anymore. I'm not trying to rotate the earth with my combo so it is what it is. Here is the flow sheet for my B1-MC's recently sent to Modern Cylinder Head for their CNC program and valve job.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: KOS]
#2212489
12/12/16 02:09 PM
12/12/16 02:09 PM
Plumb Wired
Blue Ridge, VA
Bob can be hard to get on the phone, keep trying to call or you might try sending an email moderncyl@aol.com
RIP Monte Smith
[Re: KOS]
#2212513
12/12/16 02:49 PM
12/12/16 02:49 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
I agree like we discussed before. I would go with an MC head if B1 was the direction I want. But I have both and a set of Predators. IMO its all in who does the port work, how much you want to spend and how fast you want to go. I have a set of CFE Originals that are nice and made a tick over 1000 in a build that was meant to be in a bracket car.
