Super Stock spring question #221104
02/11/09 01:42 PM
02/11/09 01:42 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
First off I hate left and right!!!!!!
Anyway I have my 002 and 003 springs for my duster. Obviously the 002 is right and the 003 is left. Is that sitting in the car or looking at it from the front? Or in Layman's terms which is the pass and which is driver?
Thanks for taking the time to answer my dumb question.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Super Stock spring question [Re: DemonDust] #221105
02/11/09 01:54 PM
02/11/09 01:54 PM
an8sec70cuda Offline
The right side of a car is always the passenger's side. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Super Stock spring question [Re: DemonDust] #221106
02/11/09 02:02 PM
02/11/09 02:02 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The spring with more leafs goes on the right side of the car, the pass side, to counteract torque steer.
Re: Super Stock spring question [Re: DemonDust] #221107
02/11/09 02:29 PM
02/11/09 02:29 PM
organ
maximum entropy Offline
organ
left and right are always after having been run over (looking at the rear of the vehicle).
Re: Super Stock spring question [Re: maximum entropy] #221108
02/11/09 02:32 PM
02/11/09 02:32 PM
Menomonee Falls
Menomonee Falls
Thanks guys
SDG Motorsports
Re: Super Stock spring question [Re: DemonDust] #221109
02/12/09 11:03 AM
02/12/09 11:03 AM
New Haven County CT
Mr 5 Speed Offline
Mr 5 Speed  Offline
New Haven County CT
002 on Starboard
003 on Port
Re: Super Stock spring question [Re: Mr 5 Speed] #221110
02/12/09 12:50 PM
02/12/09 12:50 PM
Menomonee Falls
Menomonee Falls
002 on Starboard
003 on Port
LOL thanks
The springs look great. I had to have my brother stand on the bumper so I could connect the shocks. Is this normal with the super stock springs?
SDG Motorsports
Re: Super Stock spring question [Re: DemonDust] #221111
02/12/09 01:39 PM
02/12/09 01:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You need longer shocks or shock extensions!
Re: Super Stock spring question [Re: Mr 5 Speed] #221112
02/12/09 01:43 PM
02/12/09 01:43 PM
Connecticut
5126brl No more Offline
Connecticut
002 on Starboard
003 on Port
Re: Super Stock spring question [Re: DemonDust] #221113
02/12/09 02:06 PM
02/12/09 02:06 PM
Menomonee Falls
Menomonee Falls
What shocks are you guys running with your Super stock springs?
SDG Motorsports
Re: Super Stock spring question [Re: DemonDust] #221114
02/12/09 03:41 PM
02/12/09 03:41 PM
Indiana
P
Pentastar440 Offline
P
Indiana
My shocks are '71 Imperial from NAPA . I think they are 2 inches longer.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Super Stock spring question [Re: Pentastar440] #221115
02/12/09 03:44 PM
02/12/09 03:44 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i run the MP shocks, everyone always comments on how smooth the car rides and with 1.49 60' id say there doin something. i will say though i went through 3-4 to find 2 good ones that didn't have problems
Re: Super Stock spring question [Re: DemonDust] #221116
02/12/09 05:23 PM
02/12/09 05:23 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
CE 3 way longer for SS.if you have to squat the car to use the shocks it is too short!the can pull apart.
Re: Super Stock spring question [Re: blownzoom440] #221117
02/12/09 06:06 PM
02/12/09 06:06 PM
Menomonee Falls
Menomonee Falls
Had to squat it like a half inch.
CE 3 way? Part number?
SDG Motorsports
Re: Super Stock spring question [Re: prochargedhemi] #221118
02/12/09 06:07 PM
02/12/09 06:07 PM
Menomonee Falls
Menomonee Falls
You went through 3-4 MP shocks? Or different brand shocks?
SDG Motorsports
Re: Super Stock spring question [Re: DemonDust] #221119
02/12/09 09:49 PM
02/12/09 09:49 PM
Temperance, MI
P
P
Temperance, MI
3-4 MP shocks, as always there quality control sucks so one leaked and the other had the outer cover bent rubbing the lower housing
Re: Super Stock spring question [Re: DemonDust] #221120
02/12/09 10:03 PM
02/12/09 10:03 PM
ELYRIA,OH
ELYRIA,OH
the # is on there web site.i will see if i can find it.thay are 2" longer i think.you can use ranch 9000 also.what length do you have in now extended?if you have longer shackles... you will need to measure forsure.
edit:C2730 # 23.16"length i think it said
Re: Super Stock spring question [Re: blownzoom440] #221121
02/12/09 10:29 PM
02/12/09 10:29 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
This how I remember which number is for what side. This works on everything I have checked when refering to factory part numbers if one side differs from the other.
Mopars odd numbered cylinders are on the drivers side (left). The factory and Mopar performance in this case, numbers which end with a odd number is for the left side. And even for the right. Just check this when you are disassembling something. I haven't found it to be wrong YET. I did say YET. BTW, I run the 002/003 with the long CE shock. They have worked good for me since I loosened the shock setting up. HTH, Beep
Re: Super Stock spring question [Re: Bigbeep] #221122
02/13/09 09:45 AM
02/13/09 09:45 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
there is a YET to the story, Mopar has a 2800lb A-body SS spring where the even no. is the left side, why they did that I have no idea.
Russ
Re: Super Stock spring question [Re: DemonDust] #221123
02/14/09 10:37 AM
02/14/09 10:37 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Mr Gasket used to sell shock extender brackets that would bolt to the bottom of the shocks. Maybe they still do...
And I never worry about the part numbers, as long as you know they are a matched set the spring with more leafs is intended for the right side, the pass side of the car, so it counteracts torque steer. A stiffer spring on the right will counteract a cars tendency to pick up the left side of the vehicle upon a hard launch, so the car launches level. Just like cars with factory rear coils put an air bag in the right side of the car for the same reason.
