340 block. Casting reads TA, now what? #2211033
12/10/16 01:48 AM
12/10/16 01:48 AM
usa
Mopar1970440 Offline OP
usa
I just got ahold of a 70 340 block, I was going to slowly build up for my truck. I noticed the casting reads TA 340 on side of block. I'm understanding this should be an aar cuda or TA challenger block?? Where should I start to see if the car is still out there and see if owner would like to reunite block with car? I do see numbers stamped into block by oil pan rail area.
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211036
12/10/16 01:52 AM
12/10/16 01:52 AM
The T/A Challengers and AAR Cuda where made for only a few months in 1969/1970 to meet the rules of the Can Am racing association. I would look for special interest groups and clubs for those cars up twocents
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211038
12/10/16 01:58 AM
12/10/16 01:58 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Post the number on the VIN pad here or email me at sixpak340(insert at symbol here)att.net please?
Hundreds of AARs & T/As on file & I do have owners on record for a lot of them, several of whom are hoping their original block surfaces.
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211043
12/10/16 02:06 AM
12/10/16 02:06 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can also post it here on Moparts in the lost / wanted engine & transmission thread at https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2844/1/engine-and-trans-lost-found.html
Re: 340 block. Casting reads TA, now what? [Re: Alaskan_TA] #2211052
12/10/16 02:22 AM
12/10/16 02:22 AM
usa
usa
Sent you an email Alaskan_TA
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211122
12/10/16 10:52 AM
12/10/16 10:52 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I'm sure if my block ever shows up, it will be .060 without main caps or the day before Christmas for 10k. I doubt I will ever see mine. It was replaced in warranty.
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211128
12/10/16 11:08 AM
12/10/16 11:08 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Email sent with contact info, I have not heard of this AAR since 1992, so hopefully the contact info is still good!
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211364
12/10/16 06:01 PM
12/10/16 06:01 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Great job Barry.
1971 HEMI E BODY REGISTRY
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211376
12/10/16 06:22 PM
12/10/16 06:22 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Well, I guess it wasn't mine, but like Fastmark it is doubtful mine will show since it was replaced in 72 under warranty and the extent of the damage is not known.
Careful, your character's showing!
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211517
12/10/16 10:03 PM
12/10/16 10:03 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Fastmark.. Just out of curiosity I assume your replacement short block was a regular 340 block.
I know leftover TA shortblocks have been found in some 71 A-bodies, but I doubt Chrysler went to the extent to make sure a TA owner got a replacement TA block.
Re: 340 block. Casting reads TA, now what? [Re: mccannix] #2211529
12/10/16 10:29 PM
12/10/16 10:29 PM
Illinois, USA
jeff1974 Offline
jeff1974  Offline
Illinois, USA
Just to clarify. Those blocks were homologated for ACCA trans am racing, not Can-Am road racing. Just sayin
Re: 340 block. Casting reads TA, now what? [Re: mccannix] #2211548
12/10/16 11:02 PM
12/10/16 11:02 PM
mopar346 Offline
mopar346  Offline
Mine was replaced with a regular 340 short block with a 72 casting date.
Re: 340 block. Casting reads TA, now what? [Re: jeff1974] #2211560
12/10/16 11:19 PM
12/10/16 11:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Originally Posted By jeff1974
Just to clarify. Those blocks were homologated for SCCA trans am racing, not Can-Am road racing. Just sayin
Sports Car Club of America wrench
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211569
12/10/16 11:30 PM
12/10/16 11:30 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I have a friend with a T/A he purchased that the seller kept the #s match block but will swap him if he can come up with another T/A block. My friend has access
to lots of mopar parts and motors if you would be willing to work with him. Let me know he is located in CA. and the block he needs is back east.
1969 Hemi Roadrunner 2nd owner
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211575
12/10/16 11:51 PM
12/10/16 11:51 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Did this block come with heads and rocker arms?
Re: 340 block. Casting reads TA, now what? [Re: NANKET] #2211639
12/11/16 01:54 AM
12/11/16 01:54 AM
usa
usa
This is just the block with main caps
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211658
12/11/16 02:18 AM
12/11/16 02:18 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
But it is from an AAR, so it would have had them originally.
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211721
12/11/16 10:30 AM
12/11/16 10:30 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My AAR came from San Angelo, TX in 1976. It had a 71 steel crank warranty short block, with the original TA heads, intake, carbs and air cleaner. It had a tag riveted to the block stating it was a warranty replacement block. The car only had 53,000 miles at the time. Ironically it had a spun rod when I bought it. When I pulled the pan off, the rivet that holds the steel splash shield on the bottom of the intake, was laying in the pan with all the aluminum shards with it. That's what caused the problem. When I looked at the intake, which was off when I bought it, one rivet was gone and the other was replaced with a bolt. I can only speculate that the first missing rivet caused the original motor to fail.
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211744
12/11/16 11:01 AM
12/11/16 11:01 AM
P
Porter67 Offline
Porter67  Offline
P
A bit off topic, but I wonder why they didnt use t/a parts, I was able to get two over the counter t/a no vin blocks, on after 76 and one I think it was in 80, both from my local dealer parts guys stash, but still from the dealer.
Ya think maybe some did, some didnt and possibly the service/warranty guy was slackin and just used a 340?
Re: 340 block. Casting reads TA, now what? [Re: Mopar1970440] #2211783
12/11/16 01:03 PM
12/11/16 01:03 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It was not the big deal like it is now. They were 2000 cars with a 200 block. I paid 500 for my TA long block in 1980. I bought it from a guy that got it free from his sponsoring wrecking yard for a hobby stock circle track car. Fortunately he sold it to me instead of racing it.
