Battery question #2210389
12/08/16 11:19 PM
12/08/16 11:19 PM
ohio
slomoshun Offline OP
ohio
I have a pulling truck and the battery is located in the tool box and that is where the master switch is also located. I am wanting to move the battery under the hood but leave the master switch where it is. My question is with the extra cable I'm going to have to run from the front of the truck to the tool box will this affect the performance of the battery or will it not matter
Re: Battery question [Re: slomoshun] #2210395
12/08/16 11:32 PM
12/08/16 11:32 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Not if you use large enough cable. I'd recommend 1/0 gauge (aka 0 gauge) and it should work just fine.
Re: Battery question [Re: DrCharles] #2210396
12/08/16 11:34 PM
12/08/16 11:34 PM
ohio
ohio
Ok thanks
Re: Battery question [Re: slomoshun] #2210532
12/09/16 05:10 AM
12/09/16 05:10 AM
Cab_Burge Online work
Cab_Burge  Online Work
How about using a 100 % heavy duty rated R.V. solenoid between the battery and the main cable feed from the battery to the main electrical system feed and turn it on and off from the switch in the tool box with a 14 gauge wire work scope up
