Re: Racepak questions?
[Re: 68shifter]
#2210452
12/09/16 01:31 AM
12/09/16 01:31 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I went the way of a logger dash.Comes with water temp,oil pressure and shift light output wire.The shiftlite I bought.Then I chose what sensors I wanted. Have to download after every recording. I have recorded idle,cruse and WOT.
[Re: 68shifter]
#2210506
12/09/16 03:25 AM
12/09/16 03:25 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
It used to be that a Sportsman could not log shock sensors. It did not have the analog channels to do so. I believe they have resolved that issue. The other big difference is the number of channels available to you. The Sportsman with the fewest followed by the V300 and V500. But as I say I think that has been addressed. But ask Racepak to be sure. They actually have a discussion board on their website that is good.
As for the clutch they make everything, I would guess it depends on what you want to monitor. Once again ask Racepak.
I don't feel an EGT does much good at all in an NA deal. It basically just tells you if that cylinder is working or not. No tuning info IMO. Now on a power adder or alcohol car then I think there is good info there to tune with. O2 sensors will be a much bigger help tuning the car.
You might look at Racepak's site. Lots of information there and the discussion board is manned by tech there.
[Re: 68shifter]
#2210716
12/09/16 03:32 PM
12/09/16 03:32 PM
Posts: 4,457 Washington
madscientist
Washington
What about the RPM stuff?
I have been looking at that, not sure how good it is.
[Re: 68shifter]
#2210741
12/09/16 04:20 PM
12/09/16 04:20 PM
Al_Alguire
Las Vegas
Sample rates are 10x series stuff but IMO for the average guy that is not a huge issue. You may inquire about the shock stuff. I know that was an issue for a SProtsman and the reason we have used V300's. I have run the stuff since 2010 and been very happy with it. The Sportsman is upgradeable and can ad more channels. We have one in the heads up car and not any issue, but no shock data....
