Hotchkis TVS and drag racing
#2195760
11/13/16 04:02 PM
11/13/16 04:02 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
I have been mulling over taking my 69 Dart into the Pro-touring direction and have been considering the Hotchkis TVS. Anyone using this suspension how did it affect you at the strip? My car currently rides on Springs N Things HD rear leafs and hooks pretty good on MT ET Streets. With the stiffer/lower suspension I know it will compromise just interested in hearing how much.
1972 Road Runner
1988 Shelby CSX-T
Re: Hotchkis TVS and drag racing
[Re: racerx20]
#2195981
11/13/16 11:58 PM
11/13/16 11:58 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I made some devices that are kinda hybrid Caltrac/Assassin bars. My biggest problem is without them my driveshaft hits tunnel and want to leave the car.
Mopar to the bone!!!
[Re: 72Swinger]
#2198394
11/18/16 04:38 AM
11/18/16 04:38 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
i have 315 drag radials on mine and hooks well on street...680 horse hemi ..a stock style pinion snubber on my s60 is about 3/4 off floor in my 70 charger with full tvs....i have my shocks as stiff as they can go and rear sway in middle hole.
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: sublimehemi]
#2198847
11/19/16 10:44 AM
11/19/16 10:44 AM
racerx20
Standard but OK
Standard but OK
Houston, Texas
That's good to hear, thanks for your input. I like the idea of using caltracs along with the tvs as well.
1972 Road Runner
1988 Shelby CSX-T
[Re: racerx20]
#2199086
11/19/16 07:56 PM
11/19/16 07:56 PM
72Swinger
Nebraska
I would de-arch what you have and go from there. Im not a fan of Hotchkis A-body leaves. Im probably going to add another full leaf to mine, a Dart needs more spring than all the other A-bodies.
[Re: 72Swinger]
#2199125
11/19/16 09:26 PM
11/19/16 09:26 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I would de-arch what you have and go from there. Im not a fan of Hotchkis A-body leaves. Im probably going to add another full leaf to mine, a Dart needs more spring than all the other A-bodies. The Hotchkis Challenger appears to have the rear end low every time I see a picture of it. Perhaps they're trying to favor weight bias vs aesthetics.
[Re: racerx20]
#2199164
11/19/16 11:11 PM
11/19/16 11:11 PM
72Swinger
Nebraska
The E and B springs are alot more beefy than the A body versions. From what I could tell when they were R&D'ing these springs they were using a 68 Dart post and a Duster as test mules. Both 108" WB cars with quite a bit less rear weight. Peter tried these in his Dart and the rear ride height was stupid low and he was NOT able to use them, I can agree. Im all for having 0 arch at ride height, but I cant have that with a sacrifice in wrap or rate. Dart Swingers, non-post cars, have a 111" wheelbase and just plain need more spring.
[Re: 72Swinger]
#2204346
11/29/16 11:44 AM
11/29/16 11:44 AM
racerx20
Standard but OK
Standard but OK
Houston, Texas
Good info, those leafs are pricey to have to deal with these issues.
1972 Road Runner
1988 Shelby CSX-T
[Re: 72Swinger]
#2208792
12/06/16 04:36 PM
12/06/16 04:36 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
I made some devices that are kinda hybrid Caltrac/Assassin bars. My biggest problem is without them my driveshaft hits tunnel and want to leave the car. b Do you have some pictures at all please?
[Re: racerx20]
#2209393
12/07/16 04:15 PM
12/07/16 04:15 PM
72Swinger
Nebraska
Big bumps yes, and you can here them "engage".
[Re: racerx20]
#2211353
12/10/16 05:45 PM
12/10/16 05:45 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have the ESPO HD stock height leafs at stock height and basically the rest of a TVS (minus the steering links). I'd just keep the springs you have. Unless you are autocrossing you'd probably find you wouldn't put the rear bar on full stiff anyway.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#2211851
12/11/16 03:16 PM
12/11/16 03:16 PM
racerx20
Standard but OK
Standard but OK
Houston, Texas
I have the ESPO HD stock height leafs at stock height and basically the rest of a TVS (minus the steering links). I'd just keep the springs you have. Unless you are autocrossing you'd probably find you wouldn't put the rear bar on full stiff anyway. This is a good idea as well, car sits plenty low as is in the rear.
1972 Road Runner
1988 Shelby CSX-T
