69 roadrunner 383 eng #2209078
12/07/16 12:25 AM
12/07/16 12:25 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
should i use a vented or unvented gas cap. thanks
Re: 69 roadrunner 383 eng [Re: moparpro] #2209117
12/07/16 01:28 AM
12/07/16 01:28 AM
Since you ain't gettin any love on this Q I will start out with this: I would think with the tough fed gov't emission regs of that era (starting in '68 in most states, maybe 67 in California, not sure exactly) that it came with a non vented cap. gas fumes would be a major polluter. I think the C.A.P. (C.A.S)? system started in '68. I know my 68 440 GTX had the valve cover breather connected to the air cleaner as opposed to being open. Not sure how the tank is vented for the fluid to flow out/forward
Re: 69 roadrunner 383 eng [Re: moparpro] #2209148
12/07/16 02:37 AM
12/07/16 02:37 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Tank should have a vent that runs up into the inside of a frame rail.
I want my fair share
Re: 69 roadrunner 383 eng [Re: moparpro] #2209303
12/07/16 01:30 PM
12/07/16 01:30 PM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
The tank has 2 vents one that can be seen in the trunk area and routes to passenger frame rail. The other is on the left side and is J shaped and clips in by the upper shock mount drivers side.
Re: 69 roadrunner 383 eng [Re: moparpro] #2209440
12/07/16 05:36 PM
12/07/16 05:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The gas tank and cap in 1969 didn't care what engine was in front of it , no vented was the only cap whether a slant 6 or a hemi .
I don't even think there is a vented cap , if it was vented it would splash out fuel every time you hammered the throttle ....
