Roller Rockers question
#2208980
12/06/16 10:11 PM
12/06/16 10:11 PM
Posts: 318 Beans Cove Pa
Bumbalawski
Beans Cove Pa
I have an RB engine that I am building that uses a solid roller cam. The valve springs will around 550 lbs. open. The are not offset. I would prefer to use a true roller rocker and not a bushed one with a roller tip. Also, this will be a street engine. What would be a good durable rocker at a reasonable price? And would a bushed rocker hold up if I were to go that route?
Thanks, Don
Re: Roller Rockers question
[Re: Bumbalawski]
#2209003
12/06/16 10:45 PM
12/06/16 10:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bump for ya.. but bushed ones will work fine on the street with those spring pressures... but I will let the BB guys suggest which ones ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Bumbalawski]
#2209009
12/06/16 10:59 PM
12/06/16 10:59 PM
Posts: 4,457 Washington
madscientist
Washington
I would never use a needle bearing on a reciprocating shaft. A bushing is a better deal.
550 on the seat isn't much.
Keep your idle oil pressure above 30 pounds.
[Re: Bumbalawski]
#2209014
12/06/16 11:02 PM
12/06/16 11:02 PM
Posts: 4,212 New York
polyspheric
New York
Needle shaft bearings are one of those ideas that sound good, but their only benefit is that they only need to be "wet", allowing you to restrict top end oil or use the extra flow for cooling spray, while plain bushing rockers need pressure delivery to the shaft. Needle bearings provide far less support than a plain or bushed surface, are fragile, expensive, dirt-sensitive, and the theoretical advantage of reduced friction is too small to measure. The needles must be thicker than a bushing, which requires a thinner shaft, a weaker rocker arm with a thinner wall at the shaft support area, or a larger rocker arm. This is simply money thrown away and needless complexity, except for professional racing. Don’t bother.
Boffin Emeritus
[Re: Bumbalawski]
#2209066
12/07/16 12:10 AM
12/07/16 12:10 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
I have bought and used several different brands of aluminum true roller rocker arms as well as extruded aluminum roller tip rocker arms on solid roller cam BB Mopar V8 motors. The only true needle bearing aluminum roller rocker arm I will use now on the street are the Harland Sharp brand, I like and use their 1.6 ratio rockers now ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) As far as your deal you can use a bushed ductile iron or stainless bushed rocker arms with probably no problems with those spring pressures IHTHs
[Re: polyspheric]
#2209163
12/07/16 03:23 AM
12/07/16 03:23 AM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I agree with this completely,plus the added chance of a rocker bearing failure contaminating your engine.Being a street engine I'm sure it won't fall under routine race engine teardown/inspection~RT
[Re: Stanton]
#2209263
12/07/16 12:35 PM
12/07/16 12:35 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a set of Harland Sharps - installed but not yet used. I've been contemplating pressing out the bearings and pressing in bushings. Any thoughts ?? WHY?????????? How many Harland Sharp rockers have you ever heard of going bad and when I see how bad some guys set up their valve train it should be common.
[Re: Thumperdart]
#2209307
12/07/16 01:33 PM
12/07/16 01:33 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
Guess I've been doing it wrong all of these years w/solid roller cams, needle bearings in my rockers, 8" overheating verts and BIG carbs..........too funny.......ANYTHING can and will break in the "wrong" hands and sometimes things just fail. In the op's case HS's or a good bushed lifter if it helps ya sleep........... ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I have a set of full roller Harland Sharps on my Indy headed 440. They were new sometime back in the '90s and have a lot of use on them.
[Re: Thumperdart]
#2209982
12/08/16 12:12 PM
12/08/16 12:12 PM
an8sec70cuda
Yep.........Thankxxx again Chip Lee's carb went out yesterday....... Thanks Dom, we are both excited to get it back and test it out! I remember posts from not that long ago about why roller bearing rockers were they way to go and bushed rockers were crap. Funny how things go, lol.
[Re: an8sec70cuda]
#2210096
12/08/16 03:35 PM
12/08/16 03:35 PM
Cab_Burge
The full roller Harland Sharp rockers kits have caged needle bearings in the center of the rocker arms so there is no way for the needles to fall out ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) They also have solid roller tip wheels on harden axles on the valve stem end, no needle bearings out there. They have special harden shafts for the rockers to ride on along with specific spacers and shaft hold downs. I had one set of the original early(1960s made)BB rockers that had two roller tip axles that where worn, the wheels where good. I replaced those two axles and that set is still on the road today ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I bought a set of used 1.6 for the Indy 440-1, the rollers had more side to side slop in them that I liked and I sent them back to Harland Sharp after telling them about my problem on the used rocker arms and they machine the ends for wider wheels and replaced them and the axles and returned them to me for $42.00 including the shipping I've never heard of a racer or hater on here say that they had a on engine failure with those rocker arms
[Re: an8sec70cuda]
#2210216
12/08/16 07:07 PM
12/08/16 07:07 PM
Thumperdart
State of confusion
Yep.........Thankxxx again Chip Lee's carb went out yesterday....... Thanks Dom, we are both excited to get it back and test it out! I remember posts from not that long ago about why roller bearing rockers were they way to go and bushed rockers were crap. Funny how things go, lol. Mee too man...............
