Valve Springs #2208791
12/06/16 04:36 PM
12/06/16 04:36 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I have a set of 906 heads with 2 bad valves. I will be getting a set of stock 346s given to me that has a fresh valve job and only a hundred miles or so on them.
I'm running a Mopar hydraulic 509 in my 383. My question is this... can the high lift springs I have on my 906s be put on the 346s without any issues or will the 346s need a new set of springs?
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Valve Springs [Re: Texas383] #2208824
12/06/16 05:34 PM
12/06/16 05:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
They use the same springs.
Just verify the spring installed height is the same when you put the springs on the new heads.
Re: Valve Springs [Re: Texas383] #2208831
12/06/16 05:44 PM
12/06/16 05:44 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Great.... Thanx!!
1969 Y2 Super Bee
Re: Valve Springs [Re: Texas383] #2209077
12/07/16 12:24 AM
12/07/16 12:24 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Might want to verify retainer to guide clearance too as you never know on a reworked head.
Don't be the exception.
Re: Valve Springs [Re: Texas383] #2209235
12/07/16 11:57 AM
12/07/16 11:57 AM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Ok... will do
Thanx!
1969 Y2 Super Bee
