Re: Pro Parts A Body 440 headers info...
[Re: 300by500]
#220843
02/11/09 09:28 AM
02/11/09 09:28 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use them and so do a lot of others here.A search will get you all the info on them.
I don't know of anything "bad" about them,except maybe a few holes in the fenderwells,but that's it.
[Re: Sixpak]
#220845
02/11/09 02:13 PM
02/11/09 02:13 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Did you buy them used, i'm after a set to replace my 2" TTI's. Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Ari440]
#220847
02/11/09 09:15 PM
02/11/09 09:15 PM
deaks
robin hood country
Nice car Ari. Any downsides to proparts, plug access, trans removal, tyre and starter clearance etc. Mike
[Re: Sixpak]
#220848
02/11/09 09:33 PM
02/11/09 09:33 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
You're going to need to find a used set, cause the 'new improved version' won't be 1/2 the price of TTI's ....
I got an unused set on ebag for $451, I heard the new ones are gonna be alot higher...
[Re: deaks]
#220849
02/11/09 09:34 PM
02/11/09 09:34 PM
Posts: 5,618 long island NY
Ari440
long island NY
thank you
tips :
bolt all the pipes on the two heads , but do not tigthen them
push in the collecters ,ist a little hard to do but if the pipes where tigthened on the heads its very hard to do
when the collecters are on thigthen the header bolts on
#6 pipe
to get to this spark plug make a hole on the fender well ,use a long extention to get to it
all last 4 : 6-8 , 5-7 plugs use an extention to get to
all 4 : 1-3 , 2-4 front plugs you can get from the side or under the car
#7 pipe take off the head and the U pipe going to the collecter and the starter comes off
the moter trannie in the car you can assemble the headers on
215 75 15 front tires 27 inch tall very lite rub marks but no problems touching and bent pipies
I think #1 pipe need to ding the pipe in the pitman arm touches it
a moter plate helps you adjust engine heigth too
you can take the trannie out ,taking off the collecters help more
I have some pics some one asked for and will post them
1.39 9.85 - 137 mph
[Re: Ari440]
#220853
02/11/09 09:47 PM
02/11/09 09:47 PM
Ari440
long island NY
1.39 9.85 - 137 mph
[Re: 300by500]
#220854
02/11/09 10:18 PM
02/11/09 10:18 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
The NEW replacement headers are finally available at Bob Mazzolini Racing. I saw them and they are CLEARLY nicer construction than the origionals. Nicer flanges, welds, fitment. I would buy a set if I had a Big Block A-body.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#220855
02/12/09 07:17 AM
02/12/09 07:17 AM
deaks
robin hood country
It says 459 on the site but people are saying 779, either way, i will wait for the pound to rise against the dollar before buying unless a decent used set come along. Ari Thanks for all the pics and info. I hope i haven't stole the original poster's thunder too much. Mike
[Re: deaks]
#220856
02/12/09 09:37 PM
02/12/09 09:37 PM
PUNK
Bobs website is definitely not current. The 459 price was the OLD ProParts headers that are not available any longer. To be honest, the latest versions of the proparts brand headers were nowhere near as nice as the older sets they used to make. Bobs versions are WAY nicer than any sets ever were.
