Craigslist Score #2207756
12/04/16 08:32 PM
12/04/16 08:32 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Scored a 2005 545RFE 5 speed automatic out of 2 wheel drive 5.7 Hemi Ram yesterday for $300, took 2 cans of degreaser and an hour with the pressure sprayer to get it clean. It came with dipstick and cooler. I will have it checked out and rebuilt if nessesary. It will go behind the 6.4 Hemi that's going into my 37 pickup
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Craigslist Score [Re: AZ_A12_BEE] #2207758
12/04/16 08:33 PM
12/04/16 08:33 PM
Dreaming of the 808
Dreaming of the 808
Converter too
Re: Craigslist Score [Re: AZ_A12_BEE] #2207983
12/05/16 02:57 AM
12/05/16 02:57 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Good score.
Couple of questions.
What are you going to control it with?
Does a 4.7 have the same bolt pattern?
Kevin
Re: Craigslist Score [Re: AZ_A12_BEE] #2208018
12/05/16 08:56 AM
12/05/16 08:56 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Way cool, nice score. Depending on how high you set the engine/trans you may have some floor modifications in your future.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: Craigslist Score [Re: Mike P] #2208039
12/05/16 11:38 AM
12/05/16 11:38 AM
moparx Offline
moparx  Offline
good buy ! i'm guessing it is a good, running unit as is ? how many miles ? as it came with a dipstick, what year did the dipstick go away to where it takes the dealer to check the transmission fluid ? or is that a different transmission such as the six and eight speed units ? and as was already mentioned, what controller are you planning to use ? sorry for the many questions, but i really don't know much about these transmissions.
beer
Re: Craigslist Score [Re: AZ_A12_BEE] #2208100
12/05/16 02:14 PM
12/05/16 02:14 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
bow You did well ! Before the seller gets too much gone (if he had the whole truck) see if he has the starter. It bolts to the drivers side, which should make header selection easier if that's what you choose. Also, try to get the ECU if he has it. Hotwire or Bouchillon might be able to jack the tune up in that ECU to make your new crate motor run like it should, and it will also control the 545RFE without the need for a separate controller. You can add an Edge In Tune to it to boost engine performance and control shift points and firmness.
Re: Craigslist Score [Re: Twostick] #2208103
12/05/16 02:23 PM
12/05/16 02:23 PM
Dreaming of the 808
Dreaming of the 808
Originally Posted By Twostick
Good score.
Kevin
I'm calling Hotwire today to find out what I need ti control it, I'm not sure about the 4.7
Re: Craigslist Score [Re: Mike P] #2208106
12/05/16 02:27 PM
12/05/16 02:27 PM
Dreaming of the 808
Dreaming of the 808
Mike, I always assented that there would be some floor modifications, after all is said and done I plan on welding the floor and lower firewall together as one unit rather than bolt on as it is now
Re: Craigslist Score [Re: moparx] #2208109
12/05/16 02:30 PM
12/05/16 02:30 PM
Dreaming of the 808
Dreaming of the 808
beer
I saw the truck it came out of, a 2005 Ram 1500 with 150K miles, I assume it to be a core but he swears it ran and drove perfectly, I will send ot out to a shop to be checked and rebuilt if needed before permanent install
I'm calling Hotwire today to plan my wiring to control it and the motor
Re: Craigslist Score [Re: AZ_A12_BEE] #2212491
12/12/16 02:14 PM
12/12/16 02:14 PM
Az
Crizila Offline
Crizila  Offline
Az
Here's a little something to help you plumb that thing.
Fastest 300
Re: Craigslist Score [Re: AZ_A12_BEE] #2212831
12/12/16 10:41 PM
12/12/16 10:41 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The torque converter stall speed is the only difference in the 545RFE.
Re: Craigslist Score [Re: AZ_A12_BEE] #2214773
12/15/16 11:18 PM
12/15/16 11:18 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I have one that came out of a 2005 Daytona pick up that was wrecked with a little over 34000 miles, I listed it for 6 months for $300 never got a call on it..
