72-79 truck racers, air flow ? #2207430
12/04/16 08:44 AM
12/04/16 08:44 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Air flow over bed, is better to cover bed, run open bed or open bed with tailgate off? Truck will be running low 11's down to high 10's. Truck is also lowered.
Re: 72-79 truck racers, air flow ? [Re: 68dodge] #2207463
12/04/16 11:11 AM
12/04/16 11:11 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would assume a hard flat cover would be best. But make it light so the gain you get from aerodynamics is not lost to weight. Next best would be tailgate off because you are removing weight from truck.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 72-79 truck racers, air flow ? [Re: 68dodge] #2207470
12/04/16 11:27 AM
12/04/16 11:27 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I've made numerous back to back passes with tailgate on, tailgate off...no diff. Trucks can use the extra weight anyway, at least my Dakota can, I have a 58 lb lead brick bolted in the back as it is.
I'm curious about a flush bed covering helping with ET.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 72-79 truck racers, air flow ? [Re: 68dodge] #2207562
12/04/16 02:18 PM
12/04/16 02:18 PM
Alberta
rustbuckett68 Offline
Alberta
Make up some flat iron straps to position the tailgate at about a 45 degree angle. Looks faster, and is adjustable. As said, the weight at the rear of the truck probably won't hurt.
Re: 72-79 truck racers, air flow ? [Re: 68dodge] #2207590
12/04/16 03:13 PM
12/04/16 03:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My Dakota was faster with tail gate off. Less weight is what I assumed. But I also had a soft tonneau cover on it and left it on with gate off.
