New racecar for 2009 #220636
02/10/09 07:50 PM
02/10/09 07:50 PM
Affton MO
Q
qwkmopardan Offline OP
Q
Affton MO
I finally got off my rump and got busy on the tube chassis Lebaron I bought in early 2002. Payed alot of storage on it. Anyway I've got it all cleaned up and new tires, checked the brakes, greased the wheel bearings and polished the weld wheels. Engine is on the stand finished except for a coat of paint. Trans is finished except for t-brake and csr sheild which are on the way. Engine is a 383 block w/3.900 crank and nicely ported 915 closed chamber heads. Comp ratio is 11.5 to 1. Camshaft is solid flat tappet 272 at .050 w/ .605 lift at the valve. ported Victor 383 intake. 727 trans w/ 5400 conv. Rear is 9" w/ 4.10 gears. Car weighs 2300lbs w me in it. What do you guys in Moparland think it should run?
Re: New racecar for 2009 [Re: qwkmopardan] #220637
02/10/09 07:52 PM
02/10/09 07:52 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
What class are you going to race? That car is sweet!
Oh and can I borrow your demon for some no box racing this year? lol
Post deleted by Defbob [Re: qwkmopardan] #220638
02/10/09 08:31 PM
02/10/09 08:31 PM
Re: New racecar for 2009 #220639
02/10/09 09:06 PM
02/10/09 09:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Very nice!
Re: New racecar for 2009 [Re: qwkmopardan] #220640
02/10/09 09:07 PM
02/10/09 09:07 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Dan looks like you need a exterminator .Are you going to the dark side ???
with that big block.
Looks sweet i'll give you a call when i get a minute .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: New racecar for 2009 #220641
02/11/09 01:18 AM
02/11/09 01:18 AM
Affton MO
Q
Q
Affton MO
I went that fast with a junkyard headed sm. block mopar at 3100lbs. I hope for 9.00s or even 8.90s with a big block and 800lbs less weight. I could be dead wrong. The time slips in mid march will provide an answer. I can't wait.
Re: New racecar for 2009 [Re: qwkmopardan] #220642
02/11/09 07:46 AM
02/11/09 07:46 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
What about the Demon. Are you keeping it, or time to move on?
Yeah, it's got a smallblock.
Post deleted by Defbob [Re: qwkmopardan] #220643
02/11/09 10:21 AM
02/11/09 10:21 AM
Re: New racecar for 2009 #220644
02/11/09 02:20 PM
02/11/09 02:20 PM
St. Louis Mo. USA
P
Pleaz Offline
Pleaz  Offline
P
St. Louis Mo. USA
It looks good Dan. It will be cool to finally see it go down the track. I predict it will run like all your engines, very fast! See ya at the track.
