Re: shaker hood trim ring nuts
[Re: Morty426]
#2206060
12/01/16 08:47 PM
12/01/16 08:47 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
I don't think there is anything special about them. Just a captured star washer nut with coarse thread (in most cases). I found some at AC hardware.
They get painted. X2
Admiration For Multiple Carburetor Vehicles...
[Re: Morty426]
#2206104
12/01/16 10:01 PM
12/01/16 10:01 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
They get painted. Hard shoulder nut.
68 Charger 70 Cuda
[Re: ScottSmith_Harms]
#2206398
12/02/16 11:52 AM
12/02/16 11:52 AM
Posts: 567 Indianapolis, IN
B5Cuda440-6
Indianapolis, IN
sbcjd,
Here's a couple pictures of original trim ring nuts that I received from another Moparts member. The nuts are a very soft metal, and are a little thicker (taller) than nuts I’ve found at a general fastener supply store (Ace Hardware, Car Quest, AutoZone, etc.). Most over the counter nuts I’ve found today are thinner looking and zinc plated, as Scott mentioned. If you want the OE look, the only way to achieve that will be to find original nuts.
I’ve seen two types, one with an “S” stamped into it, and others that were plain. And, I’ve also seen them with good paint coverage, and minimal.
[Re: sbcjd]
#2206446
12/02/16 01:38 PM
12/02/16 01:38 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
Rob is correct. Originals came with and without the S Also originals are slightly taller than anything else aftermarket that I have seen. Plus,the 6 edges are squared on top edges on originals unlike aftermarket. Original on right
[Re: Droop69]
#2206598
12/02/16 07:21 PM
12/02/16 07:21 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
If you have a reproduction trim ring the thread pitch is different than the originals.
I believe the original is 10/24 and the reproductions are 10/32. Not sure if I have that in the right order though.
You are correct.
