Re: Engine removal 1996 2500 Van
[Re: sthemi]
#2205942
12/01/16 04:56 PM
12/01/16 04:56 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't know about the 96, but with the older ones, it is just as described above, or you can get them out the passenger door. Either way, you need to basically get it down to the long block to pull it.
I have mechanical Aptitude. I can screw up anything.
[Re: 68GTS383]
#2210965
12/09/16 11:46 PM
12/09/16 11:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yea we would pull the pass door on the older ones and pull the eng out that way. It may work ok on the 96 but I dont remember for sure. Ron
