2468330-M Wedge- Which Block do I have? #2204228
11/29/16 02:13 AM
11/29/16 02:13 AM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
I don't have my old MP Catalogs available. I think they made a couple different ones. 4.50 bore
What I know:
4 bolt main
4.38 Bore
Water Cooled
Cast in 2003
What I don't know:
Siamese?
Capable overbore?
Right now its an aluminum rod 540 built as a Truck Pull or Mud truck that ran alcohol.
I have to get it apart to determine cam and a few other things.
Thanks in advance.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: 2468330-M Wedge- Which Block do I have? [Re: 440PURSUIT] #2204298
11/29/16 10:16 AM
11/29/16 10:16 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Going by your specs and what's on the list, your block has to be P5007624. I bought an all new 540 shortblock from someone who had it built for truck pull. Thankfully, he saved the paperwork that came with the block.
IMG_20161129_055456547_HDR.jpgIMG_20161129_055739029_HDR.jpgIMG_20161129_055908332.jpg
Re: 2468330-M Wedge- Which Block do I have? [Re: jughed] #2204389
11/29/16 01:12 PM
11/29/16 01:12 PM
DC, MD Suburbs
DC, MD Suburbs
Thanks. Im trying to find out more about the engine since it was built some time ago and the original owner is deceased.
I have contacted Indy and JE-
1972 Charger w 383
Re: 2468330-M Wedge- Which Block do I have? [Re: 440PURSUIT] #2205171
11/30/16 12:33 PM
11/30/16 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you going to pull a head? If so it will be easy to tell if it's a siamese bore block by poking a piece of wire in a casting core hole on the deck that is between 2 cylinders and see if is goes between them.
Re: 2468330-M Wedge- Which Block do I have? [Re: 440PURSUIT] #2205304
11/30/16 04:27 PM
11/30/16 04:27 PM
I think all the early blocks where the Mega blocks that didn't like to be bored much over 4.410 shruggy
Maybe someone on here will know when the first World cast iron replacement blocks started entering the Mopar inventory luck
One of the local racers had several of those early Mopar Mega blocks that had cracked at 4.500 but lived at 4.410 to 4.440 bore sizes confused
I would have it sonic tested before boring it any bigger twocents
Re: 2468330-M Wedge- Which Block do I have? [Re: Cab_Burge] #2205488
11/30/16 09:44 PM
11/30/16 09:44 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I must have lucked out on this early ('01) block. The builder stated in the notes that it's good up to a 4.56 bore
Re: 2468330-M Wedge- Which Block do I have? [Re: jughed] #2205497
11/30/16 10:02 PM
11/30/16 10:02 PM
Washington
madscientist Offline
Washington
Probably need to verify that because cab is correct. Those early ones were kinda thin.
Re: 2468330-M Wedge- Which Block do I have? [Re: madscientist] #2205529
11/30/16 10:42 PM
11/30/16 10:42 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Probably need to verify that because cab is correct. Those early ones we kinda thin.
According to the sheet above, there are several blocks with a max overbore of 4.31". Must be referring to those.
Verifying the max bore would be mandatory anyway if i were to have it bored for a 572
Re: 2468330-M Wedge- Which Block do I have? [Re: jughed] #2205539
11/30/16 10:55 PM
11/30/16 10:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My mega block was one of the last ones that
Mopar built.. even at 4.500 bore it still had
.200 wall thickness... that was with 64 readings
per bore
EDIT
this was a 4.19 siamese block that I was told to
get vs the 4.5 bore because of the bore quality
and would need to be redone
wave
Re: 2468330-M Wedge- Which Block do I have? [Re: 440PURSUIT] #2205687
12/01/16 02:10 AM
12/01/16 02:10 AM
DC, MD Suburbs
DC, MD Suburbs
I have the Heads off. So ill check the water jackets.
Heads are 572-13 2.35 Valve O-ringed heads and block.
Jesel Rocker System. BIG offfset on Roller Lifters
JE said not much info on the job. They did give the bore at 4.38 and a 1.301 Compression Distance. .990 pin.
Pistons have as much Dome as Valve relief.
I will have to CC a cylinder with a piston in the hole to figure out compression. May have to change pistons to Run Gas or E85.
There are aluminum rods but with a mirror I cannot find a manufacturer on Rods or Crank.
JP Performance Chain
Cam Motion R2826 2862-11
Got the Card Today and its like 790/745 w 1.7, 281/290 @.050 111 lobe separation.
Fortunately all is super clean and nothing broken. Prob need to start another post to discuss options with these parts once I figure out compression. I 'd like to use it in 72 Demon that always ran Race Gas.
Re: 2468330-M Wedge- Which Block do I have? [Re: jughed] #2205872
12/01/16 02:38 PM
12/01/16 02:38 PM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=jughed]Going by your specs and what's on the list, your block has to be P5007624. I bought an all new 540 shortblock from someone who had it built for truck pull. Thankfully, he saved the paperwork that came with the block.
If you look at the description under the part numbers Jughead posted it says the siamese blocks have Mopar in large letters cast in the block. Both the P5007624 and P5007625 are the same block but one is bored to 4.19 and the other out to the max bore of 4.50.
I have a 2468330 M hemi block that is a 4.31 max bore water jacket block and it doesn't have the Mopar cast above the numbers.
Hope this helps, Mike
Re: 2468330-M Wedge- Which Block do I have? [Re: second 70] #2205980
12/01/16 05:57 PM
12/01/16 05:57 PM
DC, MD Suburbs
DC, MD Suburbs
The Block
Re: 2468330-M Wedge- Which Block do I have? [Re: 440PURSUIT] #2206622
12/02/16 08:15 PM
12/02/16 08:15 PM
central il.
second 70 Offline
second 70  Offline
central il.
siamese 4.50
