Re: paint job on a budget!?
[Re: GoDartGo]
#22050
03/05/06 11:16 PM
03/05/06 11:16 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I am not even close to painting a car, but I was in home depot today and could not help myself. I picked up a small can of the rustoleum "aluminum" color, foam rollers, mineral spirits, and sandpaper.
I have a 2000 for Van that was an airborne express truck. it got hit on one side and they fixed it, but not too well, paint sucks. I am going to try this on the bottom of the drivers door and see how it turns out
[Re: Pool Fixer]
#22051
03/06/06 09:26 AM
03/06/06 09:26 AM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
don't use that "aluminum" color, the paint is totally different, try it on something else first, if it is the same as the tremclad aluminum then return it.
[Re: 69chargeryeehaa]
#22052
03/06/06 09:44 AM
03/06/06 09:44 AM
Hello
I have tried 69s method on a test panel Using BPS Tractor paint, With very good results! I tried taking some pictures yesterday but it was raining. I will post some pictures of my test panel, and the paint I used soon. Yes the paint is a little "soft" but that how enamels are, they take a while to get rock hard, but there is no way I could scrape any of it off at this point.
Forrest
[Re: davesdartgt]
#22054
03/06/06 10:58 AM
03/06/06 10:58 AM
69chargeryeehaa
toronto canada
I just called Tremclad in canada, and once i told them that i painted my cars with it they said "are you the guy with the cars on the internet, the orange ones?" funny they knew all about me!!!! i hope i get some royalities if they market this product!!!! anyways, they did mention that the rustoleum and tremclad are both alkyd based oil enamels. and that they are basically the same product and labeled for the us, but they are made in different plants. they said that the paint should dry fully in 14 days, but mineral spirits actually slows the drying process. however they are basing this on very heavy coats, typically saying that full coverage is acheived in 1 to 2 coats. but when i paint i don't get full coverage until on or after the 3rd coat. with aprox 6 coats in total, i think my layers of paint would be less then 1 heavy coat of the tremclad when you also factor in wetsanding. but i really think they don't know when painting on cars, since they never really tested it. they also mentioned not using any hardners, that it is not designed to be used with the paint. what all this means to you rustoleum users i don't know, but they said that the 2 are very simmilar products if not the same. also i know i'm repeating myself but, no matter what you paint using any paint even automotive (like singel stage acrylic enamels) they all take 3 months to fully harden, and that's exactly what i've noticed with the tremclad AND all 6 single stage paintjobs i've sprayed on over the years.
[Re: davesdartgt]
#22058
03/06/06 01:08 PM
03/06/06 01:08 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I want to buy the Tremclad since this is what you used & seems to have held up well. I guess I could try rustoleum on a fender I have laying around & see what happens, but don't want to wait months to see if it cures & doesn't peel.
It shouldn't take months. The "professional" rustoleum I used, at this point in time (I think approx 2 weeks after painting) I can't scratch off to the surface. I can put scratches in it, but I can't peel it off the surface. It can only get harder and will probably do so according to what I've read/heard. I can still scratch off the standard rustoleum, but I think there were surface prep issues there. I think I will use the professional stuff when I get around to painting my Dart. hopefully I can get started within a month from now as I want to get all the bodywork done before I paint anything. The painting will be the easy part..
To be safe you could use the professional rustoleum which you can get in cans (quarts and some colors in gallons, as well as sprays) at Lowes. If you apply it right it should not peel by 2 weeks and (I hope!) be rock hard after a month or so.
#22059
03/06/06 01:13 PM
03/06/06 01:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Guess that my theory on the mineral spirits slowing the drying/curing process wasn't too far out of line at that.
[Re: MoparforLife]
#22061
03/06/06 04:34 PM
03/06/06 04:34 PM
69chargeryeehaa
toronto canada
in a way it is yes and no. when you thin with the mineral spirits it allows you to apply a really thin coat, which dries faster then a thicker coat, the paint is based from mineral spirits, meaning it is a ingreadient in the paint, and adding only about 10% to thin does'nt really effect the drying time much. I spoke again to tremclad and they offered to send me a case of paint and some clear coat in brush from(liquid). after a long discussion basically the rustoleum stop rust is a alkyd based paint but is manufactured in the us and tremclad is made in canada, he said the paints are simmilar, but they use different resins obviously because of where they are made. but one interesting topic came out of the 30 mins conversation, and that was with the clear coat. tremclad offers a clear coat that is a lacquer/enamel type paint that is reccommended to use over the tremclad rust paint, and that it should be thinned with lacquer thinner, and not mineral spirits. when i expiremented with the clear coat i used mineral spirits, and he said that it would actually remove some shine using it, probabally why i did'nt notice a difference when i tested it. but he said when thinned with lacquer thinner that the reflective properties of the finish at 60degrees was 90%!!!! that's like really high, and should be really really shiny. they also use the clear coat to paint on chrome, brass, copper, ect...as a protective coating, it also has uv inhibitors as does the tremclad rust paint. it's used to enhance the shine on rust paint, as well as for example a new mail box that is brass, the clear protects it from tarnishing. so i think it is time for me to expirement with the clear coat. with the clear i really think it would be comparable to BC/CC in lusture/finish. ummmmm time to clear the cars?
[Re: Exit1965]
#22063
03/06/06 05:10 PM
03/06/06 05:10 PM
69chargeryeehaa
toronto canada
re the clearcoat - that would be AWESOME. The question I have though is how the clearcoat would be applied. When I was doing the roller process with the enamel, the coat wasn't nice and smooth (or free of dog hair) until after wetsanding - and then the shine was gone. Before wetsanding, the shine was nice but the surface still needed flattening.
So if you roll the clearcoat on, would you have to wetsand it also, and would that affect the gloss (I'm guessing "yes")?
on the clear coat, no, wetsanding would not effect the end shine. unless you use a really coarse grit, typically a really good traditional paint job involves wetsanding and polishing to perfect it, so it is nothing new. the purpose of thinning any paint by the way has a few purposes, thinner paint promotes "self-leveling", increases pot life slightly, and increases the "workability" of the paint so that there is virtually no high/low spots or roller marks. I have virtually no dust/dirt/hair in my paint, that is strictly a function on how clean your enviroment is. if you are getting dirt using a roller, you'd go crazy if you were spraying the paint on, because you aggitate the air and get huge dust/dirt/hair issues unless you have a booth, or make a ventelation system that keeps a positive pressure in the room so that air is allways going out and not in, bringing dust/dirt/hair on your work. before i paint i clean my garage, hose it out, and clean the car really well. then once the door is closed, i don't open it until it's done. before i paint i also use a "tack cloth" which is a sticky cloth used in the auto body industry to remove all dust/dirt/hair from the surface (usually costs a $1), i clean each pannel just before i paint. the key is keeping your area as clean as possible. i think i have 1 cat hair (thick one, must be a a$$ hair!!!) in the paint that came out when wetsanding. no dust/dirt in the paint at all. and the surface is perty much very smooth, wetsanding just makes it much better. if you're getting orange peel or marks form the roller, either work faster, or thin the paint more, or do both. also the wetsanding process does not introduce any new dust/dirt if you clean the car while it's wet with a shammy to remove all sanding dust. so the whole process is probally the best way to paint in your garage and have really good results. oh and don't let your dog in the garage while/during painting.
[Re: Exit1965]
#22065
03/06/06 07:46 PM
03/06/06 07:46 PM
Pool Fixer
Coram, NY
call me crazy but couln't you spray a clear coat on? I would think you could use a small hvlp gun or something and do a panel at a time since there is no color to get even....again it opens up the can of worms of masking the whole car, super controlled clean environment and fumes...
[Re: Pool Fixer]
#22066
03/06/06 08:34 PM
03/06/06 08:34 PM
69chargeryeehaa
toronto canada
i guess you could, but there's no real advantage except for more work. if you have the equipment and a understanding wife, then i'd say go for it.
#22067
03/06/06 09:53 PM
03/06/06 09:53 PM
Project "Beer Fridge" notes: 1. Project gets underway today. Cleaned the fridge well, wiped down with mineral spirits and let dry. 2. Wetsanded with 400 grit paper to give the paint something to grip. 3. Wiped down again with mineral spirits and let dry well. 4. Mix Paint: It's a warm Florida day (~80 degrees, but dry by S. FL standards) so I mix the paint with ~10% mineral sprits. Seems pretty darn thin to me. 5. Of note, although the fridge is clean, there are a significant number of surface rust spots, most noticably on the top from condensation when opening the freezer. Beer Fridge has been living a very comfortable life in the garage for several years now, but as it is S. Florida, it does get VERY humid in here. I chose not to sand down the rust spots to clean metal because A. I'm lazy and excited to get going, and B. because I wanted to see just how the Rustoleum would handle these spots. 6. Main Door - Okay, here we go... BUBBLES! More bubbles, and more bubbles. They are not going away, not after a light pressure re-roll either. A good stiff blast of breath pops them and the paint starts to lay down. Whew! Half way thru the door and I'm beginning to think the paint is too thick - or is it my technique? I press on. 7. Top door - trying to work a little faster and the results are better. Loading up more paint on the roller and trying NOT to reroll so much (causing in effect a second coat). This is where I realize I'm starting to make a mess of things, not with the rolling but with my brush technique. Cut-in is not my strong suit and it shows grossly here. Drips and sags from too much paint, then I remember 69Chargers advice; roller in one hand, brush in the other. Getting better... you are wise, oh Master 69Charger. 8. Left Side - Load roller more, roll faster. Hmmm, this is starting to work better. Still have lots of bubbles but by now I'm huffing and puffing away to get them all popped, and the results are starting to look much better! Note to self: quit smoking cigarettes... SOON! 9. Top surface - MUCH easier to do a horizontal surface! Even with te considerable rust up here, I can see much better results. 10. Left side - Ironically, this side comes out best. Ironic because "Beer Fridge" sits up next to the water heater and there's no manuevering room on this side. Because of this, I take the tact of REALLY loading up the roller and working very fast. Get as much on as I can and get it spread out as quickly as I can. Huff, puff, and the paint really statrs to lay down nicely. Lesson learned? By going quicker I'm not "pulling" the paint up with the roller as much. First coat done, time to assess: Time for my "WTF AM I DOING!" moment! Standing back, the fridge looks... Horrible. Verging on frightening. BUT... It admitedly did a rather nasty job on the first door, and looking at the final side, things look much better. Wait an hour and re-assess. Okay, it STILL looks bad but I'm ready to press on. I SHOULD really stop here and sand down what I've done, but I decide to press on. 11. Mix Paint for coat #2 - I basically doubled the mineral spirits to ~20-25% this time. MUCH thinner, really starts to feel like water this time around. Yes Master, Grasshopper is learning. 12. Second Coat - what a world of difference! Still getting the bubbling but only for a few quick seconds. Even the slightest breath disperses them and the paint really lays down quick and smooth. If not, a very light pressure re-roll and slight puff is all it takes. 13. Entire surface takes half as much time as coat #1 and the results are much better. Clean up and done for the night. Evaluation: learned quite a bit. First and foremost; THIN THAT FRIGGIN PAINT! Even while mixing batch number two I thought to myself "this will never work, it's too damned thin..." WRONG! I can definitely see that coat number one was too thick, and that it will take at least 3-4 coats using the thinner batch to completely cover the underlaying color (white), but the benefit is that the thinner coat goes on MUCH smoother with less trouble. Less trouble, and less sanding, which is what I will be doing ALOT of after that first coat mess I made. But I had the wife give me an honest opinion, and looking at the final LEFT side with two coats - unsanded - even she saw the potential. Gonna take some photos but hold off posting them until I get a chance to wetsand first (don't want to scare off anyone just yet).
