filling a co2 bottle for a shifter? #220441
02/10/09 05:16 PM
02/10/09 05:16 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
who normally does this?everybody i call in my area cant fill a bottle this small(10 oz)thanks
Re: filling a co2 bottle for a shifter? [Re: 7sec.cuda] #220442
02/10/09 05:24 PM
02/10/09 05:24 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have a big bottle and fill my own
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: filling a co2 bottle for a shifter? [Re: 7sec.cuda] #220443
02/10/09 05:27 PM
02/10/09 05:27 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
I have my own 40 lb big c02 bottle that I use to fill my bottles. You may want to contact a Scuba shop or paint ball shop to help you out. Perhaps another racer in your area has a large bottle.
The way you fill the small 10oz or 2.5 lb bottles is you put them in a freezer or cooler with ice let them get cold and connect 10 oz to the 40lb via hose and open both valves until you stop hearing the air transfer.
Here is a pic of my bottle.
Sean
Re: filling a co2 bottle for a shifter? [Re: PlumCrazyCharger] #220444
02/10/09 06:04 PM
02/10/09 06:04 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my local welding supply fills mine,6 bucks.
Re: filling a co2 bottle for a shifter? [Re: bonefish] #220445
02/10/09 06:16 PM
02/10/09 06:16 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I have mine filled at the local paintball store.
Call around and see if they have the needed adapter.
Re: filling a co2 bottle for a shifter? [Re: AAR-B4] #220446
02/10/09 07:17 PM
02/10/09 07:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I get mine done at the fire extinguisher service shop.
Re: filling a co2 bottle for a shifter? [Re: markz528] #220447
02/10/09 10:16 PM
02/10/09 10:16 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I get mine filled at a local liquor store that sells kegs. $2.00 per bottle.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: filling a co2 bottle for a shifter? [Re: brktracr] #220448
02/10/09 10:51 PM
02/10/09 10:51 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i have been buying my nitrous from a place in Hartford Ct, Aero All Gas, VERY nice people to deal with, the have a website, search it out and give them a call, if i can ill get the number on here for you
....BAD A$$ STREET CAR.....
Re: filling a co2 bottle for a shifter? [Re: 7sec.cuda] #220449
02/11/09 06:34 PM
02/11/09 06:34 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
For those 10 oz clys a trans fill is used. All you do is shoot some co2 into the mt bottle, then close the first ball valve and open the second one. The bottle will exhaust, now it's MT and chilled ready for a fill. Close the second ball valve and open the first, you will see the frost line disappear as it fills with room temp gas. The mother tank must be a sipion tank or turn the tank upside down like I do to transfer liquid. Be careful to store full cyl in a cool place till you use it. It's easy to over fill and have it pop off and you will need a new relief valve.
Co2 gas is about 800 PSI. I have used brass valves in the past but these steel valves holdup better. Get yourself a hose setup like this and you can fill your own 10 ozs from a small 5LB beer tap tank even. Hope this helps some guys.
One time a friend of mine came out of a store to his car and found his newly cleaned cloths all over his car. He thought someone had broken into his car. Turned out that he had just left my place from getting his cly filled and had it in his laundry basket in the back seat and it popped off from the heat in his car.lol
Anyway I have plenty of spare relief valves because those 10 ozs are easy to over fill, I crack the valve after filling to leave some room for exspantion. I change out the cly after every run and fill em all at once. We also have a scale and weigh em after filling because if there over filled they will pop off in the trailer on the way to the track during the hot weather.
I have made several transfer hoses from #3 or #4 braided brake hose, they work just fine.
Re: filling a co2 bottle for a shifter? [Re: Challenger 1] #220450
02/11/09 07:25 PM
02/11/09 07:25 PM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
I also own my own 40 pound bottle and fill my own.I bought the bottle and lines from Praxair. I can get about 700 psi in a bottle without chilling the bottle and that will last quite a while. I always have it in the trailer so if anyone needs a bottle filled at a CCevent come look me up.
Jack
Re: filling a co2 bottle for a shifter? [Re: Moore & Moore] #220451
02/12/09 01:40 AM
02/12/09 01:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just find a Paintball place. I have a buddy with a paintball shop and he fills mine all the time.
