2468330-M Wedge- Which Block do I have?
#2204228
11/29/16 02:13 AM
11/29/16 02:13 AM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
I don't have my old MP Catalogs available. I think they made a couple different ones. 4.50 bore
What I know: 4 bolt main 4.38 Bore Water Cooled Cast in 2003
What I don't know: Siamese? Capable overbore?
Right now its an aluminum rod 540 built as a Truck Pull or Mud truck that ran alcohol. I have to get it apart to determine cam and a few other things.
Thanks in advance.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
Re: 2468330-M Wedge- Which Block do I have?
[Re: jughed]
#2204389
11/29/16 01:12 PM
11/29/16 01:12 PM
440PURSUIT
DC, MD Suburbs
Thanks. Im trying to find out more about the engine since it was built some time ago and the original owner is deceased.
I have contacted Indy and JE-
[Re: 440PURSUIT]
#2205171
11/30/16 12:33 PM
11/30/16 12:33 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I have contacted Indy and JE- Are you going to pull a head? If so it will be easy to tell if it's a siamese bore block by poking a piece of wire in a casting core hole on the deck that is between 2 cylinders and see if is goes between them.
[Re: 440PURSUIT]
#2205304
11/30/16 04:27 PM
11/30/16 04:27 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I think all the early blocks where the Mega blocks that didn't like to be bored much over 4.410 Maybe someone on here will know when the first World cast iron replacement blocks started entering the Mopar inventory One of the local racers had several of those early Mopar Mega blocks that had cracked at 4.500 but lived at 4.410 to 4.440 bore sizes ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I would have it sonic tested before boring it any bigger
[Re: Cab_Burge]
#2205488
11/30/16 09:44 PM
11/30/16 09:44 PM
Posts: 1,229 In The Hills
jughed
In The Hills
I think all the early blocks where the Mega blocks that didn't like to be bored much over 4.410 Maybe someone on here will know when the first World cast iron replacement blocks started entering the Mopar inventory One of the local racers had several of those early Mopar Mega blocks that had cracked at 4.500 but lived at 4.410 to 4.440 bore sizes ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I would have it sonic tested before boring it any bigger I must have lucked out on this early ('01) block. The builder stated in the notes that it's good up to a 4.56 bore
[Re: jughed]
#2205497
11/30/16 10:02 PM
11/30/16 10:02 PM
Posts: 4,457 Washington
madscientist
Washington
I think all the early blocks where the Mega blocks that didn't like to be bored much over 4.410 Maybe someone on here will know when the first World cast iron replacement blocks started entering the Mopar inventory One of the local racers had several of those early Mopar Mega blocks that had cracked at 4.500 but lived at 4.410 to 4.440 bore sizes ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I would have it sonic tested before boring it any bigger I must have lucked out on this early ('01) block. The builder stated in the notes that it's good up to a 4.56 bore Probably need to verify that because cab is correct. Those early ones were kinda thin.
[Re: madscientist]
#2205529
11/30/16 10:42 PM
11/30/16 10:42 PM
jughed
In The Hills
I think all the early blocks where the Mega blocks that didn't like to be bored much over 4.410 Maybe someone on here will know when the first World cast iron replacement blocks started entering the Mopar inventory One of the local racers had several of those early Mopar Mega blocks that had cracked at 4.500 but lived at 4.410 to 4.440 bore sizes ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I would have it sonic tested before boring it any bigger I must have lucked out on this early ('01) block. The builder stated in the notes that it's good up to a 4.56 bore Probably need to verify that because cab is correct. Those early ones we kinda thin. According to the sheet above, there are several blocks with a max overbore of 4.31". Must be referring to those. Verifying the max bore would be mandatory anyway if i were to have it bored for a 572
[Re: jughed]
#2205539
11/30/16 10:55 PM
11/30/16 10:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My mega block was one of the last ones that Mopar built.. even at 4.500 bore it still had .200 wall thickness... that was with 64 readings per bore EDIT this was a 4.19 siamese block that I was told to get vs the 4.5 bore because of the bore quality and would need to be redone
[Re: 440PURSUIT]
#2206622
12/02/16 08:15 PM
12/02/16 08:15 PM
Posts: 1,714 central il.
second 70
central il.
siamese 4.50
