Page 3 of 4 1 2 3 4
Re: K frame dolly [Re: MoparJunkie] #2203461
11/27/16 07:41 PM
11/27/16 07:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Brian, if you flip that over and put the lift ring on the opposite side it will be a little stronger/safer should your welding be hiding any flaws.
Re: K frame dolly [Re: ScottSmith_Harms] #2203486
11/27/16 08:35 PM
11/27/16 08:35 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Originally Posted By ScottSmith_Harms
Brain, if you flip that over and put the lift ring on the opposite side it will be a little stronger/safer should your welding be hiding any flaws.
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: K frame dolly [Re: MoparJunkie] #2203489
11/27/16 08:41 PM
11/27/16 08:41 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
If you mean the cross bar that has the D ring welded to it I put it that way because the two arms sticking out are angle iron,I did think about notching the angle so that I could put it on the underside but was in a hurry to get it done so that I could get the motor out,had a guy on the way to get it.
who is that guy?
Re: K frame dolly [Re: Brian_wo] #2203747
11/28/16 03:16 AM
11/28/16 03:16 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I think Scott is saying rotate it 180*, then the weld's aren't near as critical.
Re: K frame dolly [Re: MoparJunkie] #2203756
11/28/16 03:37 AM
11/28/16 03:37 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
yep!
Re: K frame dolly [Re: MoparJunkie] #2203789
11/28/16 10:43 AM
11/28/16 10:43 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Duh!
I didn't even think about turning the angle and drilling the holes in the other side.
I was in this huge hurry,then the guy never showed.
who is that guy?
Re: K frame dolly [Re: Brian_wo] #2203903
11/28/16 03:48 PM
11/28/16 03:48 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
This is the one we made. The only thing I would recommend for anyone making one of these is steal your bottle jack out of your dodge ram and install in under the engine somewhere. I welded a socket on the end of the jackcrank and use my impact gun to bring the jack up and down. It works great at getting just the right angle.
Re: K frame dolly [Re: mymcodebee] #2203904
11/28/16 03:52 PM
11/28/16 03:52 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Another
Re: K frame dolly [Re: Brian_wo] #2203921
11/28/16 05:06 PM
11/28/16 05:06 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Originally Posted By Brian_wo
Duh!
What was being suggested was, ...take what you have now, rotate it 180 degrees, & weld on a new lifting ring,...that's all.
Re: K frame dolly [Re: MoparJunkie] #2204077
11/28/16 10:21 PM
11/28/16 10:21 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Yeah I see what I did,should have put those pieces on the opposite sides,or as you guys are trying to get through to me :-)
Flip it upside down and bolt it back on with a new D ring,I will probably do that.
Thx for pointing out what should have been the obvious.
who is that guy?
Re: K frame dolly [Re: MoparJunkie] #2204193
11/29/16 01:29 AM
11/29/16 01:29 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
If it hasn't broken yet ...
Some people just like to find things wrong with stuff other people have done.
Re: K frame dolly [Re: MoparJunkie] #2204783
11/29/16 10:40 PM
11/29/16 10:40 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
It's ok,had I taken the time to look at it I would have done it that way.
who is that guy?
Re: K frame dolly [Re: MoparJunkie] #2205059
11/30/16 04:50 AM
11/30/16 04:50 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I built it off of a store bought one a friend had and then loaned it to TX9Cuda and he made the plans when I ask for measurements for AAR1064 while he had it. Not that any of that is important. :-)
It has all the measurements and sizes and can be built for about $50 worth of steel.
Attached PDF document
Careful, your character's showing!
Re: K frame dolly [Re: MoparJunkie] #2205061
11/30/16 04:52 AM
11/30/16 04:52 AM
mopar346 Offline
mopar346  Offline
The dolly
Re: K frame dolly [Re: MoparJunkie] #2205087
11/30/16 08:43 AM
11/30/16 08:43 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Mopar346 - thanks for the plans!
Re: K frame dolly [Re: MoparJunkie] #2205133
11/30/16 11:26 AM
11/30/16 11:26 AM
mopar346 Offline
mopar346  Offline
My pleasure, I have also used it as a break in stand using a stationary core support and securing the stand.
Re: K frame dolly [Re: MoparJunkie] #2205139
11/30/16 11:34 AM
11/30/16 11:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Mopar346, those plans are a near identical copy of the US Cartool design. Did you dimension from one of those?
Re: K frame dolly [Re: ScottSmith_Harms] #2205207
11/30/16 01:42 PM
11/30/16 01:42 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Thought the same thing... identical..
Re: K frame dolly [Re: MoparJunkie] #2205361
11/30/16 05:49 PM
11/30/16 05:49 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
1/4" wall tubing is bigtime overkill. 3/16 is plenty and 1/8" would be just fine. There is just no need to make this so heavy you can't move it.
Re: K frame dolly [Re: ScottSmith_Harms] #2205553
11/30/16 11:12 PM
11/30/16 11:12 PM
mopar346 Offline
mopar346  Offline
Actually never put a tape measure to anything but I did have a picture of a friends store bought one, I think I bought a 10 ft stick of the base tube and did the math to make it work to the best advantage and minimal excess. I build a lot of stuff by seeing something in someone's shop and thinking I need one but since I am notoriously cheap I built it myself and a lot of times out of scrap. I have an outside rotisserie for blasting the bottom of cars that is based on 2 4X6s planted in the ground, I'm sure I saw the basic design somewhere and then used a little thought to built it to suit my purpose.
As mentioned I use it as a break in stand as well, I have a Camaro core support bolts to a 2X4 strapped between 2 post in my shop with an aluminum radiator of unknown origin with a 79 4WD Dodge upper hose and a Cuda lower, wired and gauged with what I had lying around. I strap the stand between 4 post with tie down straps from my car trailer. I don't have plans for that but I could probably get that drawn up too. twocents
Page 3 of 4 1 2 3 4
