Re: Stage 6 heads intake recommendations.
[Re: rickb67]
#2203335
11/27/16 03:10 PM
11/27/16 03:10 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Can you correct your cam specs for us. Don't know what you have.
Are you stating 282 Advertised for intake and 251 @ 050 for exhaust?
[Re: rickb67]
#2203336
11/27/16 03:11 PM
11/27/16 03:11 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Rick, check those cam duration numbers again.
I don't recall if you have 1.5 or 1.6 rockers.
[Re: rickb67]
#2203349
11/27/16 03:25 PM
11/27/16 03:25 PM
fast68plymouth
So. Burlington, Vt.
Do you have, or have access to the adapter plates?
[Re: rickb67]
#2203358
11/27/16 03:33 PM
11/27/16 03:33 PM
fast68plymouth
So. Burlington, Vt.
I thought you had the stage 6 intake for use with those heads on the RB block. To use a "normal" intake you'll need the spacer plates.
Probably wouldn't help with the bottom end situation, but if the cam is only 252/257 @ .050, there is some power to be gained from going bigger.
Converter is 8", but what does it stall to on the brake with no chip?
[Re: fast68plymouth]
#2203361
11/27/16 03:40 PM
11/27/16 03:40 PM
Posts: 4,457 Washington
madscientist
Washington
Converter is 8", but what does it stall to on the brake with no chip? I think fast is in th right track...sounds like it needs more converter.
[Re: rickb67]
#2203373
11/27/16 04:27 PM
11/27/16 04:27 PM
fast68plymouth
So. Burlington, Vt.
You can check it one of two ways......(motor and trans warmed up of course):
-Engage the transbrake, floor it with no chip in the two step(if you run one). Hold it long enough to get a good reading(like 2-3)seconds.
Or
-with the car rolling along at about 10-15mph in high gear, floor it and observe where the tac levels off.
You really want it to be at least 4500rpm for that application.
IMO, this needs to be a known quantity before any other changes are made.
[Re: rebel]
#2203397
11/27/16 05:24 PM
11/27/16 05:24 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Stage 6 heads don't get a lot of respect but a good Friend of mine has gone lots of 9.70's at Keystone with them in his beautiful street legal duster. He did his own porting work
[Re: pittsburghracer]
#2203566
11/27/16 10:34 PM
11/27/16 10:34 PM
BradH
Nice Duster! My wasn't directed at you; I just threw that on here since I've got a good bit of experience w/ Stage VIs and was (am) curious where the topic goes. FWIW, to the OP... 1. The MP Stage VI 4150 intake (RB w/o spacers) needs a LOT of work to "work", and even then has some drawbacks. It's really a poor match for your combination, especially w/ that small of a cam. 2. There is a vendor on eBarf that reproduces the MP RB intake spacers and has one (1) set left listed as of this post -> CLICK THIS3. The "If it was mine..." answer is: - Pull the heads, if not already off - Get those spacers - Have the spacers mounted to the heads & the heads' roofs raised from the top of the spacer through the intake port in a line-of-sight approach to remove the dip in the roof where the spacers match the heads . - Get a Victor 440 intake and do the plenum mods I've posted on here in the past (assumes you have no issue running a taller intake) - Get a bigger cam; Hmmm... why not let Dwayne spec you a cam, too, since he just prepped your heads? 4. And what everyone else said about figuring out what your converter's stall is... But I suspect -- as long as there are no issues w/ the converter -- the current intake manifold has such a "hole" in the torque curve that it's not doing your 60-ft times any favors. You're .07 slower in the 60 and .2 slower in the 1/4 than I ran at the same MPH. Carry on.
Victor 440 with plenum modsVictor 440 with as-cast plenum
