1971 billboards or no? #220290
02/10/09 04:24 PM
02/10/09 04:24 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
i just finished restoring a 71 cuda, its all numbers matching and factory spec's. it did not come with billboards, but i am thinking of installing them. i may need to sell it as well. just wondering what all you mopar guys think of adding them, or not??? thanx for your input..
Re: 1971 billboards or no? [Re: kingkt] #220291
02/10/09 04:24 PM
02/10/09 04:24 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
to sell add them... to keep ... stock dan
Re: 1971 billboards or no? [Re: ph23vo] #220292
02/10/09 04:29 PM
02/10/09 04:29 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I'll reverse - to sell don't install, keep as built, if keeping, and you like them - install and be happy
Re: 1971 billboards or no? [Re: shakerjoe] #220293
02/10/09 05:21 PM
02/10/09 05:21 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Reverse is the right way to look at it if you
think you might sell.
logan426
Re: 1971 billboards or no? [Re: MLR426] #220294
02/10/09 05:31 PM
02/10/09 05:31 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
logan426
The reverse of reverse or just reverse?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 1971 billboards or no? [Re: kingkt] #220295
02/10/09 07:36 PM
02/10/09 07:36 PM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline
What color is the car? Is it the original color?
You could always drive it without, then add them later.
Re: 1971 billboards or no? [Re: Diego (not Ted)] #220296
02/10/09 07:40 PM
02/10/09 07:40 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
Just put them on one side!!!
Problem solved!!!
Re: 1971 billboards or no? [Re: DCM71cuda] #220297
02/10/09 07:42 PM
02/10/09 07:42 PM
Va (for now)
FY1TA & 65 Wedge Offline
mopar addict
mopar addict
Va (for now)
Problem solved!!!
I was going to say that!
Re: 1971 billboards or no? [Re: DCM71cuda] #220298
02/10/09 07:43 PM
02/10/09 07:43 PM
put them on !!!!
Re: 1971 billboards or no? [Re: Diego (not Ted)] #220299
02/10/09 07:43 PM
02/10/09 07:43 PM
WV.
Challenger_Nut Offline
WV.
For me that is easy. I didn't like the Billboards when the cars were new and I still haven't bought into let's put them on everything trend.
Re: 1971 billboards or no? [Re: Diego (not Ted)] #220300
02/10/09 07:51 PM
02/10/09 07:51 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
its gf7 green original and i restored the same. thanx everyone for your input, im stuck on what to do, and ill probably end up selling her.
Re: 1971 billboards or no? [Re: Challenger_Nut] #220301
02/10/09 07:52 PM
02/10/09 07:52 PM
Friendsville, TN
Reverend_Ron Offline
super street
super street
Friendsville, TN
Put them ON!
Re: 1971 billboards or no? [Re: Challenger_Nut] #220302
02/10/09 07:52 PM
02/10/09 07:52 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
Seriously....it comes down to personal preference.
I think with certain paint/interior combos they look great, but with some combinations, they look
Re: 1971 billboards or no? [Re: Challenger_Nut] #220303
02/10/09 07:57 PM
02/10/09 07:57 PM
I couldn't agree more. They are pretty ugly to begin with, but putting them on everything takes the uniqueness away from those cars that actually did come from the factory with them. Many years ago I could appreciate them as being pretty interesting at least...now they are just zzzzzzzzzzz...
Re: 1971 billboards or no? #220304
02/10/09 08:12 PM
02/10/09 08:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I like the billboards, if I had a cuda I'd add them.
Could always add a line in the ad saying for X dollars more I'll add a set of billboards...
Re: 1971 billboards or no? [Re: kingkt] #220305
02/10/09 09:41 PM
02/10/09 09:41 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The 70 Cuda is an extemely clean design, then Chrysler hung on the "busy" 71 grille and cheesey fender louvers. For me adding the billboards just totally "kiddies" it up. I would leave them off. If the next owner wants to add them he can go ahead.
Sheldon
Re: 1971 billboards or no? [Re: RUNCHARGER] #220306
02/10/09 10:53 PM
02/10/09 10:53 PM
WV.
WV.
Thanks! I was begining to think that I was the only one who likes the 70 'cuda's clean look. Back in the day the 70 was the "ONE"..........
Re: 1971 billboards or no? [Re: Challenger_Nut] #220307
02/10/09 10:57 PM
02/10/09 10:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't care for them much on none High Impact colors (and even those I only like them on the bright ones). One thing that sucks is cleaning them, wax build up on the edges, etc.
Re: 1971 billboards or no? [Re: DPelletier] #220308
02/11/09 09:40 AM
02/11/09 09:40 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
logan426
Just the first reverse Dave.
logan426
Re: 1971 billboards or no? [Re: MLR426] #220309
02/11/09 12:09 PM
02/11/09 12:09 PM
DPelletier Offline
DPelletier  Offline
logan426
logan426
