5.9 Magnum conversion in an 88 D100
#2202861
11/26/16 03:21 PM
11/26/16 03:21 PM
Posts: 8,500 Candler,NC / Myrtle Beach, SC
JDMopar
I have bought a low mile 98 model 5.9 Magnum with all of the engine wiring and ECU, and will be putting it in my beater truck. 88 D100 has a TBI 318 in it now. I want to use the MPFI that is with the 5.9. My question is, does anyone have a step by step process for converting the existing engine wiring with the 5.9 to work in older vehicles? I know I could send the harness to several reputable place and let them do it, but I don't want to have more money in the harness than what I paid for the truck! Yes, I'll admit that I'm being a cheapskate....lol. Any help or ideas appreciated!
Re: 5.9 Magnum conversion in an 88 D100
[Re: JDMopar]
#2202905
11/26/16 05:10 PM
11/26/16 05:10 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
A 95 and earlier harness and PCM would be easier to make work than the later JTEC controller.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2203040
11/26/16 10:39 PM
11/26/16 10:39 PM
JDMopar
That's kind of what I've gathered from what info that I have been able to find. I don't suppose it matters what a 95 or earlier harness comes out of, as long as it's a Magnum vehicle? Truck, van or Jeep should work. If it matters, the truck that my motor is coming out of is a 3500 5 spd truck, and I will be using an automatic.
[Re: JDMopar]
#2203354
11/27/16 03:30 PM
11/27/16 03:30 PM
71yelladustr
Missouri U.S.A.
Any pre OBD-II 95-down V-8 magnum harness should fit the bill. The manual trans PCM will help considerably in the conversion since there will no transmission controls needed.
[Re: JDMopar]
#2203481
11/27/16 08:17 PM
11/27/16 08:17 PM
Posts: 684 Maine
jerseybud
Maine
I just did this to my 88. Great conversion. http://ramchargercentral.com/mopar-trucks/1988-w-100/50/Using anything 96 and later except the engine will greatly complicate things. 92 and 93 trucks are the preferred donor but tough to find. Only thing that got me was engine mounts. I swear they moved the holes in the crossmemnber from 88 to 92 b/c it was a PIA to get the engine seated. It still sits 1 inch farther back than my stock 92
