Oops...goodbye pistons #220232
02/10/09 03:45 PM
02/10/09 03:45 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Tuning errors can be costly
2007 5.7L Hemi, bone stock with a supercharger on it.
Do you think it might have had too much timing?
Rich H.
Esse Quam Videri
Re: Oops [Re: ZIPPY] #220233
02/10/09 03:50 PM
02/10/09 03:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
man thats ugly. what happened?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oops [Re: pittsburghracer] #220234
02/10/09 04:01 PM
02/10/09 04:01 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
First it lifted the top ring land, then the piece bounced around in there and tore things up. It did that in two cylinders on the odd side...this is the worst one.
Luckily everything else looks OK for the most part. One quench pad on one head did get chewed up slightly, but it looks like it might be OK with a little finessing and smoothing out.....although brand new (factory aluminum) heads are dirt cheap....only about $200 with springs and valves...I might not bother even looking at them.
A set of pistons and probably rods (the bearings don't fit tightly in the rods, so you know this thing detonated) and it'll likely be good to go again. I don't think these powdered metal rods can be resized so they're probably junk.
Re: Oops [Re: ZIPPY] #220235
02/10/09 04:17 PM
02/10/09 04:17 PM
PA.
"Little"John
"Little"John
PA.
I hate to see things like that happen. To bad you can't go back and run a computer program to see what went wrong and why.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Oops [Re: pittsburghracer] #220236
02/10/09 05:25 PM
02/10/09 05:25 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I'm no expert, but I'm pretty sure the knock sensor didn't/couldn't pull enough timing out of it?
Edit: changed the subject line...didn't realize it was only one word.
What is the usual cause of the ring lands breaking off? I'm assuming detonation but haven't broken enough parts to know. I think I will rebuild the thing most likely with forged pistons, but I don't plan on a blower like the previous owner had.
Re: Oops [Re: ZIPPY] #220237
02/10/09 06:13 PM
02/10/09 06:13 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
That's nothing unusual for the new hemi's with any power adder. The top ring is so close to the dome they break easily.
My buddy did the same thing with 3psi of boost.
Re: Oops [Re: pittsburghracer] #220238
02/10/09 06:17 PM
02/10/09 06:17 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
GS Motorsports?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Oops...goodbye pistons [Re: ZIPPY] #220239
02/10/09 06:19 PM
02/10/09 06:19 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
what was the ring gap?
Engine by DeTar http://www.kansasbadman.com
Re: Oops [Re: ZIPPY] #220240
02/10/09 06:32 PM
02/10/09 06:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Both Butting of the rings and or detonation can break the ring lands. With Detonation there is usually tell tale signs as in Specking of the pistons and quench pads. I cant tell from the pics if there is any specking because of all the scrappnel damage. But there could be. mike
Re: Oops...goodbye pistons [Re: ZIPPY] #220241
02/10/09 06:57 PM
02/10/09 06:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
think that's bad? you should see the #3 I have from my old 440 I was only pushing 6psi on cast pistons...well I did forget to turn on the aux electric fuel pump. It cooked quick.
Re: Oops [Re: Sport440] #220242
02/10/09 08:40 PM
02/10/09 08:40 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
this was my thaught.and what did the plug look like?
bummer about the parts!
Re: Oops [Re: blownzoom440] #220243
02/10/09 08:55 PM
02/10/09 08:55 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Been there, done that. KB Hyper pistons + too lean =
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Oops...goodbye pistons [Re: CH3NO2] #220244
02/10/09 09:10 PM
02/10/09 09:10 PM
MN
hemidup Offline
hemidup  Offline
MN
I've seen the top ring gaps vary from .009" to .011" on these new Hemi's which is not very boost friendly and usually the #3 piston will be the first one to go.
Jerry Williams.
Re: Oops...goodbye pistons [Re: hemidup] #220245
02/10/09 11:22 PM
02/10/09 11:22 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I know they make rod bearings with a larger OD for the "other" makes of engines with powdered metal rods. Not sure on Mopar.
I have piles of used 5.7 parts if needed.
TR Waters
Re: Oops [Re: The Shadow] #220246
02/11/09 01:28 AM
02/11/09 01:28 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Been there, done that. He did nothing wrong. The ring land is 3mm from the top of the piston to prevent hydrocarbons from being trapped in there. GS Motorsports warns that anything over 6 psi must have replacement (forged) pistons installed.
Re: Oops [Re: 10sec440] #220247
02/11/09 01:39 AM
02/11/09 01:39 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I wouldent doubt that this is most likly the case, just from digesting all the above info. mike
Re: Oops [Re: Sport440] #220248
02/11/09 08:58 AM
02/11/09 08:58 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
looks like detonation killed it. i had a 340 that would ping if it didnt drink the 93 and my girlfriend at the time didnt believe me- she used 87 octane gas CAUSE IT WAS CHEAPER. 3 months later, my piston looked like that as well. turns out that 87 octane cost me a bunch more
Re: Oops [Re: aarcuda] #220249
02/11/09 09:10 AM
02/11/09 09:10 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Women....
Re: Oops [Re: Sport440] #220250
02/11/09 10:41 AM
02/11/09 10:41 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Too tight of ring gap is a good point. The "good" pistons that are left in it (that didn't have any shrapnel hit them) don't show any signs of specks taken out of them. So the rings probably butted together, then?
Re: Oops [Re: ZIPPY] #220251
02/11/09 10:53 AM
02/11/09 10:53 AM
if the bearings are hammered and fallout of the caps, it was detonating. it's very possible that detonation AND the rings butting together took place.
