any issues putting a 360 magnum in to a 74 e body? #2202001
11/24/16 08:22 PM
11/24/16 08:22 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
do i have to use serp belt etc or can i use la block style alernator and water pump?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202004
11/24/16 08:32 PM
11/24/16 08:32 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
i was told there is no way to use a mechanical fuel pump and that the serp belt setup wont work with manual steering?
5549 post on old board
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202009
11/24/16 08:46 PM
11/24/16 08:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Just swap the Magnum timing cover for an LA, this takes care of the water pump and alternator problem. The mechanical fuel pump can be used with a kit to install the eccentric on the Magnum cam.
Some good info here:
http://www.magnumswap.com/using-la-parts-on-a-magnum/
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202021
11/24/16 09:07 PM
11/24/16 09:07 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
what balancer is used with la style pullies?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202022
11/24/16 09:08 PM
11/24/16 09:08 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
apparently nobody makes an la based crate engine?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202043
11/24/16 09:50 PM
11/24/16 09:50 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You will have to use the early style 5.9 magnum balancer to use LA pullies. The later balancer have pulley/balancer 1 piece. I was unable to source a new old style pulley on my last build. All of the new ones I found were the 1 piece design. Had to get one from the salvage yard. Pre-99 engines should have the bolt on pulley.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202153
11/25/16 12:41 AM
11/25/16 12:41 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
. http://www.mrlperformance.com/about.html
Dennis
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202213
11/25/16 03:39 AM
11/25/16 03:39 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Classic has 340LA crates so they are out there.
Also try here.
http://www.hughesengines.com/Index/produ...GUgRW5naW5lcw==
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202230
11/25/16 06:36 AM
11/25/16 06:36 AM
victoria australia
O
OZRT4406 Offline
OZRT4406  Offline
O
victoria australia
I used the professional products powerforce balancer pt no 80012
works perfect , bolted up all the la style front and oil pan and pick up with a small mod, been running 8 years no probs.
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202464
11/25/16 05:37 PM
11/25/16 05:37 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
what flex plate do i use?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202470
11/25/16 05:49 PM
11/25/16 05:49 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
will my 74 cuda hp exhaust manifolds work?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2202478
11/25/16 06:07 PM
11/25/16 06:07 PM
Andrewh Offline
Andrewh  Offline
as I recall, there is some unsupported area using la exhaust on mag heads.
the durango manifolds fit pretty well in a 65 B. I would expect them to clear in an 74 E.
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2203029
11/26/16 10:09 PM
11/26/16 10:09 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
Cant find mopar preformance intake model: P5007381ab any where? any ideas?
cant find valve covers?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2203037
11/26/16 10:28 PM
11/26/16 10:28 PM
moparmarks Offline
moparmarks  Offline
Not finding that number in my book. Which intake is that?
MP black valve covers?
I don't know about putting LA E/manifolds on a Mag. head but I've seen Dakota manifolds on 340 heads in a 71 Cuda.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2203112
11/27/16 01:31 AM
11/27/16 01:31 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
To answer your several questions. I am running a 5.2L Magnum which is physically similar.
Fuel pump: You can get an eccentric that goes onto the nose of the cam shaft, I did not and went with electric
Timing cover: LA cover bolts right on and does not leak
Water pump: Same as above.
Heads: I opted for Engine Quest heads with the LA angle drill for intake. Hughes also has a similar head
Intake: I used a LD4B originally, now have Edelbrock Performance but only because the LD4's radiator hose and thermostat housing interfered with the A/C compressor (A Sanden conversion, the RV2 fit just fine)
Flex plate: Using the original 904 plate.
Exhaust manifold: Using the original LA. Since your are using a 360, I would look elsewhere for that solution.
Only issue was the alternator had to be spaced out a bit as it was too close to a mounting boss on the heads. It was heating the diodes in the back of the alternator making them fail prematurely.
Power steering strictly stock.
The only thing I could not use from the LA was the oil pan which I borrowed from a newer 360 to bolt on.
Craig
Re: any issues putting a 360 magnum in to a 74 e body? [Re: moparmarks] #2203689
11/28/16 01:18 AM
11/28/16 01:18 AM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
was mp version of a 340 intake modified to fit magnum heads.
was hoping to use a stock appearing valve cover and appars there is no such thing.
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2207928
12/05/16 12:53 AM
12/05/16 12:53 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I am using the LA valve covers. Not as many bolts but it does bolt on. I have had only one leak, passenger side at the middle bolt. Cinched it down a little tighter, leak gone.
Re: any issues putting a 360 magnum in to a 74 e body? [Re: denfireguy] #2208144
12/05/16 03:35 PM
12/05/16 03:35 PM
dogdays Offline
dogdays  Offline
I prefer to call it a 5.9 Mag, it is enough different to have its own name. For one thing, the external balance is different.
If you are using an automatic, then you use the stock 5.9 Mag flexplate and a neutral balance converter. Mags carry the imbalance on the flexplate, 360s have the imbalance on the converter. [5.2 Mags are internally balanced, as are all 318s.]
If you will use the converter from behind a an LA 360, the imbalance weights must be removed, and the 5.9 Mag flexplate used.
R.
Re: any issues putting a 360 magnum in to a 74 e body? [Re: dogdays] #2208464
12/06/16 12:04 AM
12/06/16 12:04 AM
R.
Hey Dog, for the record does that apply for both 904's and 727's. I would assume so but before I copy it I want to confirm.
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2208495
12/06/16 01:08 AM
12/06/16 01:08 AM
Andrewh Offline
Andrewh  Offline
yes it does. I have seen the 904 use the 5.9 flex plate with a hole wallowed out.
