Re: any issues putting a 360 magnum in to a 74 e body?
[Re: 05dakota]
#2202004
11/24/16 08:32 PM
11/24/16 08:32 PM
Posts: 17,861 albany ny
05dakota
albany ny
i was told there is no way to use a mechanical fuel pump and that the serp belt setup wont work with manual steering?
5549 post on old board
[Re: 05dakota]
#2202009
11/24/16 08:46 PM
11/24/16 08:46 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just swap the Magnum timing cover for an LA, this takes care of the water pump and alternator problem. The mechanical fuel pump can be used with a kit to install the eccentric on the Magnum cam. Some good info here: http://www.magnumswap.com/using-la-parts-on-a-magnum/
[Re: 05dakota]
#2202022
11/24/16 09:08 PM
11/24/16 09:08 PM
05dakota
albany ny
apparently nobody makes an la based crate engine?
[Re: 05dakota]
#2202043
11/24/16 09:50 PM
11/24/16 09:50 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
You will have to use the early style 5.9 magnum balancer to use LA pullies. The later balancer have pulley/balancer 1 piece. I was unable to source a new old style pulley on my last build. All of the new ones I found were the 1 piece design. Had to get one from the salvage yard. Pre-99 engines should have the bolt on pulley.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 05dakota]
#2202464
11/25/16 05:37 PM
11/25/16 05:37 PM
05dakota
albany ny
what flex plate do i use?
[Re: 05dakota]
#2202470
11/25/16 05:49 PM
11/25/16 05:49 PM
05dakota
albany ny
will my 74 cuda hp exhaust manifolds work?
[Re: 05dakota]
#2203029
11/26/16 10:09 PM
11/26/16 10:09 PM
05dakota
albany ny
Cant find mopar preformance intake model: P5007381ab any where? any ideas?
cant find valve covers?
[Re: 05dakota]
#2203037
11/26/16 10:28 PM
11/26/16 10:28 PM
Posts: 12,493 Western Colorado High Desert
moparmarks
Not finding that number in my book. Which intake is that? MP black valve covers?
I don't know about putting LA E/manifolds on a Mag. head but I've seen Dakota manifolds on 340 heads in a 71 Cuda.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 05dakota]
#2203112
11/27/16 01:31 AM
11/27/16 01:31 AM
Posts: 1,822 Colorado
denfireguy
Colorado
To answer your several questions. I am running a 5.2L Magnum which is physically similar. Fuel pump: You can get an eccentric that goes onto the nose of the cam shaft, I did not and went with electric Timing cover: LA cover bolts right on and does not leak Water pump: Same as above. Heads: I opted for Engine Quest heads with the LA angle drill for intake. Hughes also has a similar head Intake: I used a LD4B originally, now have Edelbrock Performance but only because the LD4's radiator hose and thermostat housing interfered with the A/C compressor (A Sanden conversion, the RV2 fit just fine) Flex plate: Using the original 904 plate. Exhaust manifold: Using the original LA. Since your are using a 360, I would look elsewhere for that solution. Only issue was the alternator had to be spaced out a bit as it was too close to a mounting boss on the heads. It was heating the diodes in the back of the alternator making them fail prematurely. Power steering strictly stock. The only thing I could not use from the LA was the oil pan which I borrowed from a newer 360 to bolt on. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: moparmarks]
#2203689
11/28/16 01:18 AM
11/28/16 01:18 AM
05dakota
albany ny
was mp version of a 340 intake modified to fit magnum heads. was hoping to use a stock appearing valve cover and appars there is no such thing. Not finding that number in my book. Which intake is that? MP black valve covers?
[Re: 05dakota]
#2207928
12/05/16 12:53 AM
12/05/16 12:53 AM
denfireguy
Colorado
I am using the LA valve covers. Not as many bolts but it does bolt on. I have had only one leak, passenger side at the middle bolt. Cinched it down a little tighter, leak gone.
[Re: dogdays]
#2208464
12/06/16 12:04 AM
12/06/16 12:04 AM
RapidRobert
If you are using an automatic, then you use the stock 5.9 Mag flexplate and a neutral balance converter. Mags carry the imbalance on the flexplate, 360s have the imbalance on the converter. [5.2 Mags are internally balanced, as are all 318s.] If you will use the converter from behind a an LA 360, the imbalance weights must be removed, and the 5.9 Mag flexplate used. R. Hey Dog, for the record does that apply for both 904's and 727's. I would assume so but before I copy it I want to confirm.
