Ordered this a month ago from Summit Racing, and finally received it today.
What a let down
![frown frown](/ubbthreads/images/graemlins/custom/frown.gif)
Opened the box and the first thing I see is that the throttle body unit is all scratched up and dirty black grease smeared on it in places. Looks like somebody dragged the bottom of it across some mounting studs, but probably not bad enough to ruin the seal. So I am thinking that maybe they test run them first, but why the dirty grease? Wouldn't they do this in a 'clean' environment?
Then I look underneath the foam padding for the rest of the parts and there are no wiring harnesses. I stopped looking right there to see what other parts are missing because you can't do a damn thing with it without the wiring harness.
So I call Summit and they claim it must have come from Holley that way because they haven't had any returns recently that could have accidentally been resent to me. And I believe that is true because the box did not look like it had been re-taped.
And Summit says it will be another month before they can send another one, so I just canceled my order for a refund.
What the heck, Holley? If you are going to send out returns as if they are new, could you at least wipe the grease off of them and make sure that the major parts are still in the box?
Sorry but I had to vent.
