Custom headrest mount for roll cage help #2200547
11/22/16 02:16 PM
11/22/16 02:16 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
I am seeking advice/images in regards to building headrest mounts on my roll cage seat cross member bar.
The car is a 1968 Dodge Dart (2 door/hard top) that has the super stock seats and a 10 point roll cage.
I purchased a set of used headrest's that are from a 1980's Jeep Cherokee that I want to use. The styling of these headrest's match the design of the seats (square shape and the edge piping). Attached is an image of the headrests.
Are there any rules or regulations in regards to mounting headrest's to the seat cross member bar?
How would you approach this design? Weld piping to the seat cross member bar and slide the headrests support bars inside of them? Cut off the headrest support bars and weld a plate underneath the headrest and attach to a roll cage size pipe?
Thanks!
Re: Custom headrest mount for roll cage help [Re: WS68SSC] #2200566
11/22/16 02:43 PM
11/22/16 02:43 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Head rest's and seats
Re: Custom headrest mount for roll cage help [Re: WS68SSC] #2200681
11/22/16 05:38 PM
11/22/16 05:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine has a 3/4" tube welded to the main hoop. There is a 2nd 3/4" tube welded at 90 degrees at the bottom. The head rest is a flt 1/8" plate welded to a tube that slides into the 2nd tube. There are holes in both so a quick pin can adjust it. The plate is padded and covered with the same material as the seat.
Doug
Re: Custom headrest mount for roll cage help [Re: WS68SSC] #2201548
11/23/16 11:21 PM
11/23/16 11:21 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I just drilled the cross bar for a insert that I drilled out to the size of the head rest posts and welded them in. I used the same tubing to set the height and a couple set collars on the bottom to lock it down.so far never had any issue with tech ( Nhra).if you need I can take a pic.
Re: Custom headrest mount for roll cage help [Re: moparlulu] #2203050
11/26/16 09:56 PM
11/26/16 09:56 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Please post pics
Re: Custom headrest mount for roll cage help [Re: WS68SSC] #2203356
11/27/16 02:32 PM
11/27/16 02:32 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You may be able to use adapters from fence pipe couplers or get some ideas from them.
Re: Custom headrest mount for roll cage help [Re: WS68SSC] #2263193
03/04/17 12:06 PM
03/04/17 12:06 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Thread bump...i too am looking for some headrest ideas for a '68 Dart with A100 seats and a CM cage
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
