Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199681
11/21/16 12:25 AM
11/21/16 12:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
As someone who doesn't spray I can only make an assumptions. So here goes. Bang for the buck a 200 shot is as cheap and easy as it gets. Quality kit, proper fuel delivery, proper ignition timing and away you go. Now if you combo has tight ring gaps, thin ring lands, poor oil control you could be on a path to destruction. Certainly higher levels of power adder will require more specialized components. Going on the edge is going to require precise tuning and a motor specifically designed for spray. But from what I can see the lower level hits aren't rocket science. Just like anything else. Better parts will survive more power. A 400 hp N/A motor is easy, as is a 400hp spray motor. A 1000 hp spray motor has to be a pretty decent piece but not state of the art ports, high compression, wild cam, etc. A 1000hp N/A motor is going to need some compression, good flowing heads, and some pretty good valve train, thus more than likely more costly. Either way most of us always want to go quicker. Just different definitions of how fast is fast. Everyone has their own challange as how to do it. If I could make 1K a day tuning I'd quit my day job and spend the money building a faster car.
Doug
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: mopar dave] #2199683
11/21/16 12:26 AM
11/21/16 12:26 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I'm looking forward to trying some spray next year but I will always have my NA builds too
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: WHITEDART] #2199686
11/21/16 12:40 AM
11/21/16 12:40 AM
State of confusion
Thumperdart Offline OP
State of confusion
Originally Posted By WHITEDART
If you feel that you are making more horsepower... then what this calculator shows.. you probably need to get to work on the chassis..
Making it out to the track once a year isn't going to get it... bring it out to Irwindale..and let's get to work... I think it's time to experiment with /gear/ launch RPM/ converter technology has got better last couple years.. and maybe upgrade to the grid so we can really mess with the timing
If I cage this heap then I won't get the boot every damn time so maybe we can hang and beat this thing but till then, one pass, one kill...........lol
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: n20mstr] #2199770
11/21/16 02:32 AM
11/21/16 02:32 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Originally Posted By n20mstr
Originally Posted By SpareParts
Originally Posted By Monte_Smith
Why spray a car that already runs good?.........Simple answer is because it runs better. Just got back from the track helping a customer. 2900lb Mustang on 29.5s with a 370" small block. Ran some nice easy 5 teens
How much to come help me do that?... on 26's
Thought you were past teens ?
shruggy
No frown I wish tho...
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: SpareParts] #2199836
11/21/16 09:03 AM
11/21/16 09:03 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I get a $1000 a day to go to the track and do what so many think is easy. Have to turn people down because I don't have the time to go.........wonder how many N/A tuners are having that problem?
^^^Here you go spareparts^^^
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199859
11/21/16 11:34 AM
11/21/16 11:34 AM
an8sec70cuda Offline
No one but you cares how fast you're going on motor. The only thing that matters is turning on the win light.
I was like you are a few years ago...just got bored so I decided to step it up. I ran mine on motor for 8 years even though I intended on spraying it from the start. Now that I've run it for a while, I might as well sell my N/A torque converter b/c it'll never go back in the car.
I flew the N/A flag for a long time in the local street car classes, but eventually got tired of getting outrun by cars w/ way less motor and a little nitrous. You know how easy it is to run in the 5s w/ a little mild small block mustang and a 250 shot? I have a friend w/ a REALLY mild 383 sbc in a full interior fox body mustang street car. On an untuned 200 shot it goes low 6.20s. When I say mild 383, I mean you could put it in your tow truck and let your grandma drive it.
Like Monte said, a 6.anything 1/8 mile is first round fodder in street car stuff anymore unless you get real lucky. Unless you're high 4s or bottom 5s you don't have much of a chance really. Last street car shootout I ran in I got beat in the 2nd round by the eventual winner who runs 4.70s. There's at least 3 that always show up that run similar times.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: racerx] #2199867
11/21/16 12:11 PM
11/21/16 12:11 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
That's honestly not a bad deal IMO,unlike some Monte isn't just a nitrous tuner he knows how to get a car down a track
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Monte_Smith] #2199878
11/21/16 12:31 PM
11/21/16 12:31 PM
UK
rb446 Offline
rb446  Offline
UK
I'm on your side Dom, all these "keep working at it" guys and you will get there. Get where? 6 flat, is that your ultimate goal? I doubt it, so put some gas on it, go fast and who cares what they think.
As far as your blended adapter, you could actually have spray bars put in that
Gotta go with that....learnt that a long time ago, we don't get many chances to win any £££'s in the UK but there was an event that had a £250 prize, it was H-Up all out affair. My 340 was a 12.4 NA car and long story short, I came up against a '70 440 Cuda in the final, running 12.3, the guy said to me don't use your Nitrous and make it a race, well reality kicked in and I thought, I've never won anything yet so go for it, being nice don't cut it...took all the boys down the pub that night on my winnings.....sorry for the long story.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: rb446] #2199895
11/21/16 12:51 PM
11/21/16 12:51 PM
PA.
"Little"John
"Little"John
PA.
You guys are STILL missing one point on this subject with Dom. He is in the process of starting a business building carbs and guys (yes guys on this site) send their carbs to Dom because of how well his car runs NA. As soon as he hits it with nitrous its a whole different story. I was in the same boat with my Duster and porting heads. Guys would see how it ran with Edelbrock heads and a simple combo NA and I picked up work because of it. I had all the work I wanted without advertising or ever needing to ship a set of heads. Its was nice being in a position to turn down work. He can and will make up his mind but until he gets his car track legal and a better stronger rear-end so he can really hit it I'm betting he will lose some work he may have picked up. If he's not promoting and using his car as a business expense he BETTER get a better tax accountant. After all advertising is a tax write-off.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199920
11/21/16 01:19 PM
11/21/16 01:19 PM
So let me get this straight...
He will lose business simply b/c he puts nitrous on his car and goes faster?
Everyone will forget how good it ran before on motor?
The carb is no longer important b/c the car has nitrous on it?
CHIP
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199935
11/21/16 01:36 PM
11/21/16 01:36 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you can build carbs, you can build carbs, nobody cares about your own car. I doubt anyone sends their carb to Dom because of how his car runs. They send it because he gives good advice in the carb threads, knows what he is talking about and guys who HAVE sent their carbs to him have had good results.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: an8sec70cuda] #2199942
11/21/16 01:46 PM
11/21/16 01:46 PM
PA.
"Little"John
"Little"John
PA.
Moparts gets new member everyday so no everyone will not remember how it ran NA. Thumpers car is not legal now to run the time he is and now you guys are saying to make it go faster. How about fixing the car to make it legal then really lay down a nice number. With or without nitrous. The trouble is that he will add weight making the car better so its not a win, win situation. We just had a racer die (in Texas) in a non-legal car. Lets try to make the sport safer, not worse.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Monte_Smith] #2199944
11/21/16 01:50 PM
11/21/16 01:50 PM
State of confusion
State of confusion
Again a nos and n/a tune are identical and if me spraying loses customers, then I guess I don't need those BUT I want as many as I can get. I DON'T RACE.............I compete w/ME only and the Dart is my vessel to test my tuning skills both good and bad and have NO desire to race in events EVER or go for the $$$$ so it's not about whoopin someone it's about getting my car to perform at it's peak and I'm not too far off imo w/more to come n/a FIRST then maybe a hit or three........... drive You are correct Pit, safety is a concern and I think about it on every pass and plan on caging it if I don't sell it.......... thumbs
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: an8sec70cuda] #2199955
11/21/16 02:13 PM
11/21/16 02:13 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This right here. As an example, Chad the guy that owns the black Buick has a 17 year old son just getting into racing. They built him a 72 Nova with a smallblock. Picked up the motor locally for a few grand. Really know nothing about it, other that it has a stock block with some aluminum heads. The Nova weighs around 3000lbs with the kid in it. Has 29.5s on leafs. On motor it goes 6.70s-6.80s and he can drive it to school or anywhere else. I dug around in my spares pile and we put a Big shot plate on it with a 175ish tune. We turn on the nitrous .4-.6 out with a timer and it goes 6.00 and he runs the 6.0 index class. Car is deadly consistent and kid is good on the tree. Always qualifies top of the ladder and he has won a couple races. Will win more once he learns to race the stripe better. When we spray it gate to gate it goes 5.70s with a nothing motor on a small shot
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199964
11/21/16 02:28 PM
11/21/16 02:28 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
6.70-6.80 is making way more than 500 crank HP at that weight. Not bad for a junk SB.
Sent you a PM Dominic but that was before I read about your adapter.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199974
11/21/16 02:54 PM
11/21/16 02:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
These days a 500hp smallblock is nothing. That's just a decent thrown together build. I think he gave $3500 for the motor. Like I said, its a stock block deal with some decent alum heads. We THINK it has a flat tappet cam, not even sure...........LOL!!!
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199977
11/21/16 03:00 PM
11/21/16 03:00 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
We will welcome you to the meetings.......
Hi,
I'm Bob and I'm a Nitrous-aholic...........
No BS buy a kit that you can grow into because 150 hit will only make you want to go to 250 hit and on and on and on....LOL!
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199978
11/21/16 03:00 PM
11/21/16 03:00 PM
UK
rb446 Offline
rb446  Offline
UK
And on the subject of racing for/ME as Dom says thats exactly what I did, I wanted to run a 9 with my old junk stock block motor....when I managed to get it to 10.7 NA, I hit it next run (same tune) with a 170 shot and went 9.96...job done....last run, nobody cares how you did it, what counts is the numbers and you did it for you.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Biginchmopar] #2199983
11/21/16 03:09 PM
11/21/16 03:09 PM
iagree w/ what Biginchmopar said...buy a big kit to start with or you'll regret it later.
CHIP
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: rb446] #2199985
11/21/16 03:10 PM
11/21/16 03:10 PM
State of confusion
State of confusion
It DOES matter to me how fast I go n/a and anything less than a 6.05 is acceptable and a 5.70 on a baby hit or not worth the effort........
