Re: 2004 truck with 4.7
[Re: ksj]
#2199945
11/21/16 01:51 PM
11/21/16 01:51 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
I have an 01 Durango with the 4.7. runs great, just uses a lot of oil. It's at 190k and we've driven it all over. Keep an eye on the temp gauge though- itt it overheats once you may be done.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: ksj]
#2200045
11/21/16 05:06 PM
11/21/16 05:06 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
X2 on the overheating. They are bad about popping head gaskets and dropping valve seats. They also require very regular oil changes to prevent timing chain tensioner issues. I'd look for a hemi instead. Especially if you plan on towing anything larger than a riding lawn mower. They are gutless. My $.02.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: ksj]
#2200249
11/21/16 11:06 PM
11/21/16 11:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The timing chain guides are plastic and just break from the heat after some years, nothing to do with the oil change. Rockers comonly start falling off randomly by 150,000, that may be prolonged with very routine oil changes but I have seen it on some very well maintained ones. Head gaskets are pretty much gauranteed to blow if it ever overheats, they do not like overheating at all. They are dogs powerwise, the HO version is noticably better than the standard one though still lacking in the TQ department. The auto trans they used behind them seems to hold up really well, I replaced a solonoid in one and a rooster comb detent thingy in one is about all the internal problems I have seen.
[Re: ksj]
#2200381
11/22/16 01:52 AM
11/22/16 01:52 AM
Posts: 10,594 Freeport IL USA
poorboy
Freeport IL USA
Thanks everyone. Just curious about the rockers falling off.Whats the cause of that?Thats a weird thing to happen.Whats the cure for that?This truck has been well maintained,garaged and has just turned over 100k.And has NO rust over the fender wells. Mopar decided you needed to buy a new truck, or a new motor every 150K, so they made the rockers start jumping off about then. There are a whole lot of reasons not to buy a Mopar with a 2.7, a 3.7. or a 4.7, though some have had great luck from all of them, from what I hear, the odds are against you. Gene
[Re: ksj]
#2200661
11/22/16 06:01 PM
11/22/16 06:01 PM
HotRodDave
Kalispell Mt.
the rocker is held on by the lifter on one end, the valve on the other and is triangulated into place where the cam and roller meet in the middle of the rocker pushing down on the lifter (technically a lash adjuster), when the lobe is pushing down on the valve while parked it can slowly bleed down the lifter, when you start the engine and the lifter has been bled down the lobe goes off the rocker and there is about 1/4 inch slack so it just falls out. As the miles go on the lifter wears and can bleed down faster after a shutdown so it will fall out after a shorter interval of sitting. Also the oil pump and bearings wear and so you lose a tiny bit of oil pressure/volume and the lifters can't pump up as fast on start up so you got several factors that build up to cause the problem, that is why I say very dilagent oil change routines help, they keep wear and sludge to a minimum. I have seen some where a new set of lifters cure it and some where it didn't make a difference they just keep falling out. I have had some success draining the oil and putting in a gallon of diesel fuel and letting it idle for 20 minutes to clean em out then change oil and filter.
